Transitor/ESR tester dead
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Transitor/ESR tester dead
    The docs say say something about the ADC can't clock that fast. I think. Also states there a difference between using a sine wave and a square wave, the tester uses square wave.
    • ben7
      Capaholic
      • Jan 2011
      • 4059
      Yep, you beat me to it.
      It needs a faster ADC so it can capture the waveform, then calculate the ESR based on voltages and time (I think XD).
      Of course, it could possibly do it with some external circuitry to trigger the ADC when it needs to measure a certain part of the waveform.
      -Ben
      Muh-soggy-knee
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        -Ben
        Yeah, also something about it taking 1.5 clock cycles of the ADC after the charge is applied and in that time the charge is already decaying in the cap under test. I've been looking at the documentation a bit lately.
        I don't know if ext ckt could speed up the process. I don't know enough about these chips but starting to learn a bit.
        Random thought - what if they could make this thing into a little o-scope? It'd need better graphics but that'd be fun
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Oh, plenty of people have done that! Not very good performance, but hey, it can at least give you an idea as to what a signal looks like!
          -Ben
          Muh-soggy-knee
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Really? Got links? Yeah, that's all you could expect but an imperfect measurement gives more information than none at all.
              • 31256
              all over ebay.
              btw, you could maybe add an SPI interfaced flash ADC chip.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #87
                http://www.ebay.co.uk/itm/DSO138-2-4...8AAOSw9r1WA5ep
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  STJ: Do you have wiring diag of the 10 - 6 pin adapter?
                    • 31256
                    yes
                    attached:
                    the common programmer,
                    the standard header pinouts,
                    and pics of an adapter from ebay - that i dont own btw, just saved the pics.
                      • 31256
                      btw, put something over the display before you solder a header on, so you dont get flux on the panel!
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        Ok. Will do. Finally ordered the rotary and programmer. I'll scrounge up stuff for the connections. Thanks.
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
                        • maleksa
                          Korg Kross2 Service Manual and LCD pinout
                          by maleksa
                          The LCD on my Korg KROSS2 keyboard is cracked and needs to be replaced.
                          However, the cost of a replacement LCD is almost the same as the price of a second hand Korg KROSS!
                          Does anyone have a copy of Korg KROSS2 Service Manual? I want to see the PINOUT for the LCD connection. Perhaps I can find a compatible LCD screen and not have to spend a fortune on an original replacement LCD.
                          From what I can gather, the LCD screen is a COG with serial interface (SPI). Is there any way I can ascertain (perhaps with the use of a multimeter or oscilloscope) the PINOUT by...
                          10-11-2024, 05:54 AM
                        • disorder
                          ps5 edm-033 dead after hdmi/usb ports destroyed
                          by disorder
                          hello guys,
                          i need help to repair a edm-033 ps2
                          history : as always hdmi port and usb ports destroyed after unplugged
                          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                          so i changed it
                          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                          i don't see any projection of liquid metal on pcb.
                          01-14-2025, 12:48 PM
                        • zunasthegreat
                          Chieftec GPS-450-AA with dead 20N60C3
                          by zunasthegreat
                          Hello everyone hope all doing well!
                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                          09-01-2024, 07:12 PM
                        • Beton
                          Finding a dead short component
                          by Beton
                          Hi guys!
                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                          I have a bench PSU and if I try to inject voltage the voltage...
                          12-10-2021, 01:05 PM
