Butane pen torches?
  • fullsmoke
    • Jun 2015
    • 9
    Butane pen torches?
    Anyone have experience w these micro/pen torches for soldering or as a hot blower?
    FS
    • 31198
    Re: Butane pen torches?
    yes, DONT USE THEM!
    • SteveNielsen
      Retired Tech
      • 2327
      Originally posted by stj
      yes, DONT USE THEM!
      +1 They are good for jewelry and perhaps detailed glass work, electronics work not so much. Every time I've seen someone try to work on electronics (or even splicing a wire) with a pen torch they wind up burning the shit out of things and themselves.
      • R_J
        • 9588
        we used the weller portasol with the hot air attachement to change 208 pin dsp chips in dvd players without a problem, but if you have no experience with them people should not use them.
        • ChaosLegionnaire
          HC Overclocker
          • Jul 2012
          • 3264
          • Singapore
          just posting the following information on what wikipedia has to say about butane torches:
          Originally posted by wikipedia
          A butane torch is a tool which creates an intensely hot flame using butane, a flammable gas.
          Consumer air butane torches are often claimed to develop flame temperatures up to approximately 1,700 K (1,430 °C; 2,600 °F). This temperature is high enough to melt many common metals, such as aluminum and copper, and hot enough to vaporize many organic compounds as well.
          Source: https://en.wikipedia.org/wiki/Butane_torch
          therefore, butane burns at too high a temperature for soldering. most soldering irons have a max temp setting of only 450°C at most. even silver soldering, hard soldering or brazing needs only a max temp of around 750°C. 1400°C+ is much too high a temperature and is more closely into the realm of welding instead!
          so i hope the above information is useful to newbies (like myself!) who are thinking of using butane torches/pens for soldering and/or reflowing like a hot air gun. like stj and homer simpson said, DON'T/DOH!
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            I had a weller one that my uncle gave me and it ran out of gas sooooo fast would not recommend them.
              • 31198
              to get an idea of how hot some get, i'v seen chinese ones sold as "can melt glass"
              maybe good for specific criminal entry scenario's but not soldering.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Haha lol
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  I have an iroda gas soldering iron that has changeable ends, great upside down in cars for imobilisers and the blower for heat shrink. Ok at a push for doing laptop charging sockets.
                  I also have one of the larger butane torches that chefs use for browning the tops of meringue that i've used for soldering copper pipes.
                  I wouldn't want either of them near electronics.
                  • zomi
                    • Nov 2011
                    • 509
                    Used antex and portasol variants before
                    To lift chips etc..
                    Soldering as well
                    If you know what you are doing they are excellent.
                    Very good for bios chips etc.
                    If you are not skilled, then its an accidenet waiting to happen.
                    Just boils down to how skilled you are to be honest.
                    • SteveNielsen
                      Retired Tech
                      • 2327
                      The alternatives are much safer.
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        I use a butane powered one.... It's all about what skills you have. Butan irons have a much shorter recovery time, but also go to much higher temp like to the point of a glowing soldering tip. They are dangerous, but if you skilled in one they are as controllable as a hakko, and more powerful.
                        Follow the white rabbit.
                        • SteveNielsen
                          Retired Tech
                          • 2327
                          I don't dispute your skill at all. For someone asking about it and not indicating their experience the best answer is still probably a no.
                            • 31198
                            a friend of mine who does car work has a cheap temp controlled iron with the 24v transformer removed and a lithium battery of some large size from a drill - it works perfectly!
                            • Behemot
                              • 4845
                              • CZ
                              I use one from time to time as well. But only those which are actually cigar lighters even though here they sell them as soldering torch lol. They never handle such usage if you use them regularly for even two years. I RMA'd couple of them than just broke the vent on the bottom and added more pressure. I think the flamers get obstructed over time, carbon maybe.
                              I tried those chinese aluminium, long pen-like torches. Blue sticker (which colors everything it touches). Their bloody filling vent is made so stupid than when you pressure butane bottle into them, you just press the whole frelling vent inside. The result is all the gas vents and it's screwed. Because the went is just pressed in a tube. I managed to solder one, it works since. Just a stupid beginner design flaw…
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Speaking of which, what's the cheapest place to get butane for these things? I suppose it's best to use the same kind of butane as the refillable butane lighters?
                                • Behemot
                                  • 4845
                                  • CZ
                                  Yeah orinary cans for lighters. I remember how I bought some biger can from a company supplying smoke shops, I think I still got it. Than I bought some at Aukro (auction site like fleebay), like a ten of them so I am supplied for the rest of my life…
                                  • teletwanger
                                    • Oct 2012
                                    • 9
                                    Believe it or not, the cheapest cans of butane actually seem to burn cleaner than the expensive ones. Do not buy Ronson or Bernzomatic brands of fuel. They are too pricey and I have found that both of them do not really burn clean and can clog up the valves and nozzles. My bet is they both have additives in the fuel. I have the best luck with the big cans of the cheap stuff sold at 7-Eleven for $3.99. You also get about 2 1/2 times the fuel for half the price of that Ronson garbage.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      Need to find which ones are actually clean and which ones are not... I doubt that they put any additives. I bought some of the Ronson stuff and it seems actually good, it doesn't have any mercaptan in it. However I'd imagine most larger cans for cooking would have mercaptan in it. Now I don't know if Bernzomatic has mercaptan or not, might need to sample it but it indeed is expensive compared to the cheapest butanes out there.
                                      What brand does 7-Eleven sell? Does it have mercaptan in it?
                                      I was thinking about getting some of the cooking butane from cooking stores, but I'd imagine it'd have mercaptan in it.
                                        • 31198
                                        i use SWAN for lighters - it's not got mercaptan or any other marker in it.
                                        it wont help with flameless pens though, they use a catalyst - the byproduct is a sticky tar-like substance.
                                        • Taurus12
                                          Optiplex 3050 micro 2 blinks followed by 3 blinks issue
                                          by Taurus12
                                          Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
                                          I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
                                          i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
                                          Any recommendation on what I have to do next? Thanks in advance
                                          06-10-2025, 05:05 PM
                                        • Isabella91
                                          Possible to convert eMMC Socket to a micro SD Card socket?
                                          by Isabella91
                                          I have seen many posts where the eMMC can be read via a SD card reader, however can the opposite be achieved?
                                          Read/Write a Micro SD Card from an eMMC Socket.
                                          I have a Motherboard with a Kingston BGA153 ball socket, using HS400 bus mode, which is 8bit, as Micro SD is usually 1bit or 4bit mode, I accept that a loss of speed in read/write will occur, but I would sill like to convert.
                                          Theoretically speaking, Im thinking if I hard solder DAT0-3 from eMMC to SD Card Reader, this should force 4-bit mode, or only DAT0 to force 1-bit mode.
                                          Not to remove...
                                          01-14-2024, 05:10 PM
                                        • Stunt
                                          Dell Optiplex Micro 7010 Computrace
                                          by Stunt
                                          Device: Laptop
                                          Brand: Dell
                                          Model: Dell Optiplex Micro 7010
                                          Board : 212045-1
                                          S/T : 2RP6VX3
                                          Request : Computrace Unlock
                                          08-12-2025, 06:15 AM
                                        • Altemon Moura
                                          Optiplex 3000 micro
                                          by Altemon Moura
                                          Unfortunately, when removing the chip
                                          (GIGADEVICE 25R256EYIG)
                                          It broke in the hot air.
                                          Will I be able to buy this same model?
                                          (GD25R256EYIG)
                                          "Can I burn the Bios?"
                                          motherboard
                                          DELL Optplex 3000 - 202040-1 D10NK$HA
                                          Optiplex 3000 micro
                                          Service tag: C7CG7T3
                                          SERVICE CODE: 26565563271​
                                          05-20-2025, 06:35 AM
                                        • tracks
                                          Dell 3080 Micro BIOS dead
                                          by tracks
                                          Hello all,
                                          I have a Dell 3080 Micro with a problem. As it is right now, it seems to be boot looping, maybe... There's no output, just fan on and power led lights up and blinks off every 2 seconds or so.
                                          Previous owner told me he bought it with a BIOS password, he tried to use a CH341A programmer with some random test clip and tried to mess with it while it was powered on. Now it won't boot.
                                          I tried to dump the bios with an EZP2023+ but I can't get a consistent read. Every time the dump is different, so it's unusable. I think the BIOS chip is fried.
                                          04-19-2025, 03:42 PM
