Optiplex 3050 micro 2 blinks followed by 3 blinks issue
  • Taurus12
    • Jul 2023
    • 15
    • Philippines
    Does anyone have an idea of what might be the issue with my 3050 micro? I have tried replacing new cmos battery but still the same
    I am not sure if its the powersupply that I'm using is the issue since its the original powersupply. its a laptop powersupply with the same specifications with the 3050 micro so i guess it should be fine.
    i also tried replacing the bios but with no avail, everytime i try another bios it gives a different blinking lights
    Any recommendation on what I have to do next? Thanks in advance
    • 24912
    A Reference Guide to the Dell OptiPlex Diagnostic Indicators
    https://www.dell.com/support/kbdoc/e...s#2012_to_2020
    • Taurus12
      • Jul 2023
      • 15
      • Philippines
      I have tried to replace the memory with a working one from my laptop but still the same issue already tried 2 rams actually. Im looking for a bios that might work and checked some post here but none of them works
      • Taurus12
        • Jul 2023
        • 15
        • Philippines
        everytime i try a bios it gives me different blinking codes, maybe its just not compatible with the 3050 micro that I have
        • DynaxSC
          • Apr 2021
          • 559
          • Poland
          Replacing bios by hard with programmer or by exchanging SPI chip on Dell motherboards is as far as concerning my experience a bad idea. Dell is somehow pairing the bios with the chipset during production process with some code and burning fuses in the chipset. So if you exchange the bios image to one without the specific code (eg. stock image, or image from another board), the board will not POST giving only some blinking LED. Hopefully you made a backup of the image, before replacing the BIOS or you have the original chip. Otherwise I suspect that only way to overcone this, is to exchange the chipset for a new one, without programmed code and burned fuses, and this is a quite expensive and difficult work. However I never confirmed this experimentally, so even this might not work with a Dell bios.
          So the chipset OS, the Management Engine on Dell boards is highly secure, good for commercial appliances, but for repairing it's a nightmare. As far as I know only Dell is doing this, maybe HP too, but I'm not sure.
          Power supply shouldn't be the issue.
          Do you know the history of this board ? If someone messed around with the bios already before, maybe this is the issue.
          • Taurus12
            • Jul 2023
            • 15
            • Philippines
            Hi Dynax thanks for the response. Actually, I have save the original bios file before I reprogram the bios chip, the prev issue was it will boot to Bios setup but it really take time before it boots and when ever i exit the bios settings it will try to restart but din shuts down and will never turn on again. For me to turn it ON again is to remove the powersupply and cmos battery for a couple ug minutes din try again, sometimes it boot faster but then again once you exit bios settings i will try to restart and shuts down again even if I have a ssd with working OS
            Thats the reason that made me think that it might be the bios, I tried to ask for a bios for it with service tag and original bios file but I dont have any response yet to that request. sadly
            • DynaxSC
              • Apr 2021
              • 559
              • Poland
              Looks not good, my suspicion would be degraded/failing chipset, this happens quite often on older boards, and DELL uses very small or even no radiators for chipsets. If so repair almost makes no sense for such board.
              Regarding bios upgrade, you should be able to download newest bios with the service code on the DELL support site. However its sometimes difficult to find, try better to google for a direct link. However DELL supplies some exec to upgrade the bios, not a simple bios binary file, so board must work at least going into bios to be able to upgrade the bios. This company always must make easy things difficult, I don't check this why they do so. Same like russians, which must have wider train rails when the whole rest of the world.
              Last thoughts: Did you check if the RTC/CMOS battery is not empty ? Did you check the service jumper on the board to be in correct position for normal operation ? You can also use the service jumper to reset the bios, maybe this will help.
              • Boardview and Schematic Bot
                DELL OptiPlex 3050 OptiPlex 3000 i5-7500 Specification for Upgrade or Repair
                This specification for the DELL OptiPlex 3050 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OptiPlex 3050 boardview and OptiPlex 3050 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                09-12-2024, 03:44 PM
                09-12-2024, 03:36 PM
                DELL OptiPlex 3050 OptiPlex 3000 i5-7500T Specification for Upgrade or Repair
                DELL OptiPlex 3050 OptiPlex 3000 i3-7100 Specification for Upgrade or Repair
