What equipment??
    Re: What equipment??
    Another key point for locating shorts is that you have the schematic to see how the signal lines or power lines are distributed.
    • newtothis
      • Mar 2013
      • 1556
      • england
      #42
      Yeah this is the issue budm, Rarely can I ever find schematics for graphics cards... Cheers everyone else for the input too...
      I may get a bench PSU and inject voltage through after putting IPA over parts of the board.... I do know that the IPA will evaporate a lot quicker with even the slightest heat change and should see the general area at least
      • retiredcaps
        • Apr 2010
        • 9271
        #43
        Wait, I thought any liquid on top of powered on electronics could cause problems including shorts?
        I recently received a Dell laptop that would not power on. The history was unknown and after several hours of troubleshooting, I finally narrowed down the problem to the keyboard. Some probably spilled liquid on the laptop while it was powered on and cause the keyboard to short out. Removing the keyboard allowed the laptop to power on and function correctly.
        --- begin sig file ---
        --- end sig file ---
        • diif
          • Feb 2014
          • 6978
          • England
          #44
          IPA of a decent purity isn't conductive. I've used this trick a couple of times.
          • newtothis
            • Mar 2013
            • 1556
            • england
            #45
            Yeah IPA won't conduct. I have Gallons of it as I use it for cleaning off flux after BGA rework
            • retiredcaps
              • Apr 2010
              • 9271
              #46
              Hmm, I guess I'm overly cautious then and letting IPA cleaned boards dry overnight before powering them on.
              However, I don't have the 91%+ IPA. I have the 70% stuff.
              • newtothis
                • Mar 2013
                • 1556
                • england
                #47
                Mines 99.9%
                Not sure what 70% would do so yeah best let it evap first
                • SteveNielsen
                  Retired Tech
                  • Jun 2012
                  • 2327
                  70% rubbing alcohol contains lanolin so don't use that, if it's not rubbing alcohol then it's probably just 30% water and can us a hair dryer to evap the water off.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    #49
                    This is seriously giving me a headache... Attempted to input current into the circuit and see if IPA evaps faster... No component is heating up :S
                    So seems using an ESR is useless... I have no schematic... Inputting current doesn't yield any clue...
                    What else can i try other than tearing components off one by one?
                      Great Sage é½Šå¤©å¤§č–
                      • 30978
                      what voltage is shorted?
                      if it's a very low one then start by lifting the gpu
                      • newtothis
                        • Mar 2013
                        • 1556
                        • england
                        #51
                        I have no clue what is shorted, Just 12v rail to ground is <1 ohm.
                        • Behemot
                          • 4845
                          • CZ
                          #52
                          Its some graphics I understand? Often the MOSFETs go bad, and they are pretty special ones, often impossible to get and you need reflow station to replace them. What graphics it is?
                          SMD is unlikely, if it blasted fuses on 150W connector, 0402/0201 SMD component would vaporize if it was shorted.
                            • 30978
                            12v line doesnt have much on it, just some caps and fets usually.
                            got a good pair of front/back foto's of the card near the 12v connector?
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #54
                              I will have to take some.
                              All inputs are 12v so I am not sure after that what line the short will be on. Just know there are 2 connectors both 8 pin, One side shows no short but the other does.
                              • Behemot
                                • 4845
                                • CZ
                                #55
                                What card?
                                • newtothis
                                  • Mar 2013
                                  • 1556
                                  • england
                                  #56
                                  Sapphire R9 290 4GB Tri-x
                                  • newtothis
                                    • Mar 2013
                                    • 1556
                                    • england
                                    #57
                                    I have IR reflow station BTW, I also have a 800x microscope and fine pitch soldering equipment. Pretty much no soldering Job I can't do.
                                    If I can find whatever shorted then I can get a donor card and use parts
                                    • Behemot
                                      • 4845
                                      • CZ
                                      #58
                                      Quite possible, very high consumption card. It has those bloody special transistors, see http://images.bit-tech.net/content_i...p290xoc-7b.jpg
                                      • newtothis
                                        • Mar 2013
                                        • 1556
                                        • england
                                        #59
                                        I will get pics soon, My card is different layout
                                        • chth96
                                          by chth96
                                          03-09-2024, 10:03 PM
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          by jorpec
                                          Hi
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • Stephan Mathers
                                          EDMI ATLAS MK10 Electronic Meter Discussion
                                          by Stephan Mathers
                                          Greetings, new guy here but always interested in the crazy universe of modding
                                          We just finished construction of around 25 vacation houses, all inside the same private area.
                                          Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                          The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                          Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                          05-20-2025, 09:09 AM
