multimeter help
  • testas86
    • May 2010
    • 140
    multimeter help
    hey i got 2 of these multimeters and the voltage reads find but i cant get anything with the amps, it flashes for a second saying around 1 amp then goes to 0 am i just using it wrong? any help would be great thanks!
  • selldoor
    Slow Learner
    • 7870
    Re: multimeter help
    Try google??
    securitest pro meter instructions
    • testas86
      • May 2010
      • 140
      Re: multimeter help
      on the site all i get is this which doesnt help
      http://www.idealindustries.com/prodD...?prodId=33-892
      • vinceroger69
        • Mar 2012
        • 6714
        Re: multimeter help
        ignore same link you found
          • 30985
          Re: multimeter help
          what the fuck are you doing?
          you dont set a meter to Amps and short a psu with it!!!!!!!
          that could trash the psu or meter or blow the meter fuse!
          • selldoor
            Slow Learner
            • 7870
            Re: multimeter help
            Ok well it is some help, bearing in mind we have no idea what you are doing.
            If we assume you have the leads in the correct sockets there is are 3 manual settings for current testing so I think you should have it on 10A.?
            If you have I guess where you may be going wrong is that you are testing a portable dc power supply which may be rated around 4A ? You havent given us many clues.
            I believe that these type of psu only output the amperage required by what it is connected to. So connect to a portable hard drive say 2A and it will output 2A- connect it to a TV it will output say 4A. and so on up to its maximum.
            Try testing the amps with a load connected
              • 30985
              Re: multimeter help
              let me explain how the current function works,
              you conect the meter in between the power source and the device being powered.
              as if the meter was a fuse.
              it then reads how much power is flowing across the leads.
              you DO NOT put it across the power source.
              • selldoor
                Slow Learner
                • 7870
                Re: multimeter help
                Here is a youtube - using a simple meter but the same applies to yours
                http://www.youtube.com/watch?v=7lwZkl0yBqA
                • testas86
                  • May 2010
                  • 140
                  Re: multimeter help
                  its a 1 amp output sorry i though i included that photo and yes i had the meter set to 10 amps unfused. so if thats not how you test the output amps of a PSU then how do you test them? i have tons of PSU that i need to test to make sure they are putting out what they rated at before i can connect them to any devices.
                    • 30985
                    Re: multimeter help
                    energy doesnt work that way.
                    the rating on a psu is how much you can pull from it without it overheating or blowing up.
                    they dont "push" power out.
                    if you want to stress them you need a variable load - maybe a reostat.
                    but your only risking the psu's because your going to be winding up the load till they do something bad.
                    and it's not much use to know that a 4a psu can go to 4.8a if you blew it up in the process.
                    you also need 2 meters.
                    one to watch the current your pulling,
                    the other to watch the voltage incase it suddenly jumps or more likely drops.
                    • mariushm
                      • May 2011
                      • 3799
                      Re: multimeter help
                      So to recap.
                      A power supply produces energy on its output which is defined by voltage and current.
                      The rating on the power supply is simply saying that the power supply is designed to be able to output up to that much current to a device connected to it.
                      You can't measure with a multimeter the maximum current in a simple way, you have to attach something to the power supply that will "eat" energy and connect the multimeter in the circuit to measure the current.
                      So you measure voltage by putting the multimeter on Voltage and one lead on + and one lead on -
                      You measure the current by placing the multimeter in series with the power supply :
                      power supply + -----> multimeter probe black ---> multimeter ---> multimeter probe red ------> + device - -----> power supply -
                      In order to measure how much power supply is capable of, you have to measure voltage AND current at the same time.
                      As the device starts to consume more energy, some power supplies slowly lower the voltage so that the total output stays below a certain level.
                      For example, the power supply in your picture is saying on label 12v 1A, which would imply it's designed to output up to 12v x 1A = 12w.
                      However, if your device needs 1.1A, the power supply may lower the voltage to 11v in order to keep the total power below 12w (11v x 1.1A = 12.1w).
                      Other power supplies are overrated, they could in practice only be capable of 8w, so when your device goes above 0.75A, the voltage may go down all of the sudden.
                      You need a device that would eat up that energy. You could build or buy an electronic load, but if you're not good at electronics or don't feel like paying, you can fake it.
                      If you want to test a 12v power supply, you could simply buy a few 12v light bulbs. By adding bulbs in parallel, you increase the power drawn from the power supply.
                      Search for such bulbs at a cars/motorbike store, you'll find plenty. Even on amazon there are many.
                      For example, here's one rated for 12-14v 1watt : http://www.amazon.com/Eiko-40478-Min...dp/B002CYUADE/
                      1w/14v = 0.07A so one of these lightbulbs will consume about 0.07-0.1A from your power supply. Now you can add one bulb at a time to the circuit (put bulbs in parallel) and with each step, the power supply will have to deliver up to 0.1A more current to the circuit.
                      There's also 3w lighbulbs : http://www.amazon.com/Eiko-40304-Min...dp/B002CYS8MY/ 3w / 12v-14v = ~ 0.21-0.25A for each bulb
                      Another method is to use resistors, which are basically lightbulbs, same thing. Lightbulbs have the resistive element inside a bulb and it gets so hot it produces light, resistors have the filament inside a cement or epoxy body and doesn't produce light.
                      You can put a resistor between + and - of the power supply and that resistor will consume power.
                      You have basic formulas : voltage equals current times resistance and power equals current squared times resistance ( V = IxR , P = IxIxR )
                      So let's say you have a 27 ohm resistor rated for up to 7w of power.
                      voltage (12v) = I x R (27 ohm) , therefore current I = 12v / 27 ohm = 0.444 A
                      The power dissipated in resistor is P = 0.444 x 0.444 x 27 = 5.33 w
                      So a 27ohm 7w resistor (cheap, you can get 5 for a dollar or something like that) is equivalent to a 12v 5w lightbulb.
                      If you want finer control, you increase the resistance value.
                      For example, 100 ohm means I = 12/100 = 0.12A , P = 0.0144 x 100 = 1.44w so you buy a 100 ohm 3w rated resistor (the rating of the resistor must be above the power dissipated in resistor otherwise resistor breaks down) and you basically have a 1.5w lightbulb
                        Re: multimeter help
                        I had a guy trying to find out if the AC OUTLET is puttIng out 15A or not by hooking up his meter setting to AC amp, should have seen what happen! It blew up and he blamed it on the meter. Basic knowledge is a MUST.
                          • 30985
                          Re: multimeter help
                          too bad he wasnt testing a 415v 3phase 63amp outlet with a friend recording it.
                          it would have been a smash on utube.
                          probably better than the guy dropping a steel bar across a car battery!!!!!
                          • dj8452000
                            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                            by dj8452000
                            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                            02-18-2025, 08:28 AM
                          • Fisher8865
                            MacBook Pro A1990 stuck at 5v .592 amps
                            by Fisher8865
                            Hi guys
                            I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then...
                            05-30-2024, 07:36 PM
                          • trex66
                            Craftsman 82345 Multimeter broke!
                            by trex66
                            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                            03-04-2025, 04:26 PM
                          • Stephen
                            MacBook Air 13" A2179 2020. 5Volts .250 amps issue
                            by Stephen
                            Customer came in with shorted USB C chips, replaced and the chips are now responding beautifully HOWEVER, I am only getting 5Volts .25 amps (sometimes .243 amps) I see that the T2 chip is turning on, but I am not seeing any voltage at the SSD rails for example,
                            PP5VG3S_EN is not present which would somewhat indicate a PMIC U7800 issue, but I checked the voltage on the PMIC and that is present and not shorted. I tested for PP5V_G3S and those rails are not present.
                            ISL9240HI is present, I am also getting 12.30 volts at PPBUS_G3H so no shorts there. Both CD3217 chips were successfully...
                            02-18-2025, 05:54 PM
                          • Sofian75
                            Things not to do with a multimeter?
                            by Sofian75
                            I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                            I fixed some of them and some I ve made things worse by blowing components.
                            Every time while taking measurements with my multimeter.
                            Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                            So my question is are there things I should not do with my multimeter?
                            Or measurements I should do only with the charger and battery unplugged?...
                            06-27-2024, 05:13 AM
