MacBook Pro A1990 stuck at 5v .592 amps
  • Fisher8865
    • Apr 2024
    • United States of America
    Hi guys
    I have a MacBook Pro A1990 that takes 4.9 Volts and .592 to .615 amps on one port. The other port on the left side power cycles with about the same amount of volts an amps but quickly power cycles. The same thing happens on the other side but opposite. So on the left side the bottom port stays on and on the right side it's the top one. I think it is a CD3215 chip but I am not sure how to test it or where to get one. I have checked for voltage at ppbus_g3h and it has 12.6 V which is also on fuses f7000 and f7001 I checked pp1v2_s3 and it has 1.2 V then I checked pp1v2_s3 and it is stuck at 0 and I didn't know how much further down the checklist I should go. I don't know if I'm getting sidetracked with that or not. Also the mosfet (q7065) which is near the battery connector it has 12.6 V on one side and 150 mili amp on the other which is on the connector side and it also has 150 mili amps on it as well. I have the board removed from the laptop doing this testing. Any help is greatly appreciated.
  • Fisher8865
    • Apr 2024
    I thought that I should also mention that I looked over the board under a microscope and found no physical signs of heat or damage no liquid damage. There are also no shorts I could find and looking at it under a thermal camera only showed the cd3215 chip getting warm after a few mins. It’s been a challenge for me and any help is appreciated.
    • reformatt
      • Feb 2020
      • 1533
      Review the wiki here with power sequence for T2
      https://repair.wiki/w/Apple_T2_platform
      Old wiki guide for A1990 here:
      https://old.repair.wiki/w/A1990_2018...ar_MacBook_Pro
      Rule out shorted caps near the edges on either side of the board. Most commonly affected are the SSD 2.5V power rails due to dust accumulation from the fan intakes.
      • silver60618
        Macbook Pro A1990 - Battery not detected after connector torn off
        by silver60618
        Hi Gang, Im working on Macbook Pro A1990, the battery connector was torn off during friend trying to replace battery. I soldered on the connector back, and created traces. The battery does charge (according to amp meter), and does power on battery only. But the signal detect line maybe done incorrectly, and the macbook shows "X" over battery icon, and "Service Recommended" on new battery
        Can somebody point me to which of these connector pins is responsible for battery detect/data line? Pin 4 on schematic had a nub on the trace, im not sure if that is important,...
        Yesterday, 06:36 PM
      • mr.Data
        Macbook A1990 stuck on logo
        by mr.Data
        This Macbook Pro 2018 boots up and then gets stuck on the logo.
        All the normal methods of resetting this Macbook have been tried but do not work.
        I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
        Any help would be greatly appriciated....
        04-18-2024, 11:51 PM
      • alfredodinolfo
        MacBook Pro 2019 (A1990)
        by alfredodinolfo
        mb code:820-01827-A;
        sn:C02Z349ALVDR;
        i9 32GB Ram 1TB
        Hi, I found short on one of 6 black nand (total 1TB).
        i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
        I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
        macbook with A2141 configuration run on recovery but don't complete it.​
        anyone can help me?
        05-26-2025, 09:27 AM
      • DATATECH85
        Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
        by DATATECH85
        I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
        The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
        I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
        However, I can't work out exactly why I don't have the PPBUS_G3H rail.
        Here are the values...
        07-24-2024, 06:34 AM
      • conghuyms
        MacBook Air A2179 stuck logo , pls help me !
        by conghuyms
        Hey everyone,
        I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
        When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
        I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
        11-05-2025, 08:30 AM
