Everyone is buying the wrong CH341 programmer
+ More Options
Posts
  • Sparklingx
    • Jul 2024
    • 41
    • Bangladesh
    Everyone is buying the wrong CH341A programmer, I have learned from my mistake. Don't buy the Black one or Green one.
    Buy this one in the photo. Most stable and all your common problems (reading but not writing/erasing, software hanging, disconnects after attaching chip, test cable connected but chip not found/ device disconnected) will be gone.
    Otherwise you'll have to solder capacitor from GND to VCC if you have those symptoms in your black or green miniprogrammer.
    • 31102
    if it uses a different chip and can program 1.8v parts then good, otherwise i wouldnt buy any of them.
    invest in a T48 or T56.
    i know the T48 is 10x the cost but it's an investment
    • Sparklingx
      • Jul 2024
      • 41
      • Bangladesh
      No you shouldnt buy any of them. Try to understand what I am trying to say. Chip is not the matter here. That big electrolytic capacitor in important.
      • spleenharvester
        • Mar 2010
        • 903
        Thanks, good intel, I'm going to be buying my first CH341 soon.
        Do you happen to know the value of that cap? I am struggling to find the good one in the UK so may have to solder my own to one of the black ones
        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
        • Sparklingx
          • Jul 2024
          • 41
          • Bangladesh
          You will find the one I have recommended in ebay. Or if you face the symptoms I have mentioned you can solder a 10v 100uf or above cap(im using 10v 470uf) with it also you can solder a smd ceramic cap(1uf or above) parallally if you want. adding the electrolytic one will do the job just fine.
            • 21275
            Get one of these with adjustable voltage https://www.aliexpress.com/item/1005007083918895.html Better than the black PCB version.
            • spleenharvester
              • Mar 2010
              • 903
              Thanks both
              • Sparklingx
                • Jul 2024
                • 41
                • Bangladesh
                The one I have mentioned has 3.3v and 5v switch(adjustable) only lacking is 1.8v .... I know about this green adjustable version from aliexpress too but doubt it someone is not having problem without a big cap using the test clip, disconnecting the moment clip touches the chip or reading but not erasing or writing software hanging sudden connection drop etc unstable situation. . I dont trust chinese SMD caps. May be it is because of chinese low quality SMD caps and voltage dropping too low. Anyway its fixable so yes get between these two but know the symptoms and how to fix it. A big cap is necessary sometimes for the test clip to work.
                • CapLeaker
                  Leaking Member
                  • 8240
                  If I’d buy a programmer it would be an xgecu T48 or T56 as stj suggested.
                  • redbaron1007
                    • Jun 2021
                    • 107
                    I second this one it's worth the cost if you are programming chips more than once a year. Even then it's worth it because you'll know if it doesn't work its the code you're programming or the chip itself and not the programmer not doing its job right. Fought the cheap ones for way to long before I upgraded and it was worth it on the first chip I programmed. The software with the T48/T56 is also just so much nicer than the stuff that comes with the CH341's.
                    This being said I do still use a modified CH341 like the usb on in the picture with an X in the original post. I modified it to be compatible with reading error logs on the ps5 and reading/editing the NOR on the PS5. Works great for that since console service tool is basically built around that. I guess the BWE software technically is to but I steer clear of BWE software when I can.
                    • CuriousDave
                      • Aug 2024
                      • 11
                      I use the programmers to rebuild ME region for Intel Mac and read the most of the ROM from different device with MiniPro TL866A which can read Mac EFI without removing. I tried CH341A once but not again. The connector clip was burning hot and app froze.
                      I bought another one called SFLY model SP10A on eBay. It works well for the job and I used the 1.8V adapter came with the CH341A to read the T2 ROM and other ROM in the macs. Works flawlessly. I paid only $35 when I bought it but now $50+.
                      It is Sofi Programmer clone which is normal for china.
                      https://www.ebay.com/itm/355115942735
                      I bought the T48 and T56 with expectation for the device would be able to read the WSON8. Ended up returning the programmer. I think the programmers are okay for their own use and personal preferences.
                        • 31102
                        wson is the same pinout as soic, as long as you have the adapter the T programmers should be fine.
                          • 31102
                          btw, i got the T56 to repair a very high end gaming motherboard,
                          some boards now are using flash chips that are locked in QIO mode.
                          that means you have to read and write them 4bits at a time - the cheap programmers cant do that.
                          i know - i have atleast 7 different programmers here!
                          incidentally, if you dont want to brick a motherboard - dont update the bios from window$!!
                          i have seen so many machines with messed up bios updates because of windows it's unreal!
                          boot from dos off a usb stick to update bioses.
                          • Billy1690
                            • Aug 2024
                            • 46
                            • United Kingdom
                            Hi i got a ezp2023+ programmer to flash the bios on my hp spectre x360-13- i set it up and used the crocodile clip to read the chip on a working laptop when i took it off my laptop no longer posts it now has a flashing cap lock ive tried flashing recommended dump files still the same so im thinking the programmer could be faulty & pushing the wrong voltage and messing up the flash do you think the T56 or a CH341
                            would be a better option lads any advice would be great
                            • Sparklingx
                              • Jul 2024
                              • 41
                              • Bangladesh
                              t56 is obviously better but just for casual bios flashing 😒 ezp2023+ is more than enough imo. assuming you dont have a repair shop. 9 . Did you check your chip voltage? is it 1.8v?
                              • Billy1690
                                • Aug 2024
                                • 46
                                • United Kingdom
                                Hi buddy sorry for the late reply i think its a 1.8v ill have a look later i have a EZP2023+ at the moment but i think somethings not right with it if thats possable on just taking the first reading from the bios chip with the crocodile clip stopped the laptop from posting and now im getting flashing caps lock i tried flashing recommended dump files with the chip removed but no change still flashing so i was thinking of getting a different programmer thinking that would fix the issue
                                  • 31102
                                  post the chip part number
                                  • Billy1690
                                    • Aug 2024
                                    • 46
                                    • United Kingdom
                                    Sorry Great Sage the numbers worn off the chip but when i test the chip with the software it says winbond w25q64
                                    And the software default is 3v in device settings
                                    • lotas
                                      • Jan 2016
                                      • 4672
                                      • Russia
                                      Never use this crocodile type clothespin, throw it in the trash.
                                      • Billy1690
                                        • Aug 2024
                                        • 46
                                        • United Kingdom
                                        Yes i have done now beginning to think its trashed the motherboard if thats possible
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • dicky96
                                          CH341 Programmer - any good for 1.8V?
                                          by dicky96
                                          Hi guys
                                          I have a TL866 CS Eprom programmer and up until now it did everything I needed to do
                                          However for the first time I have come across a 1.8V Eprom and my programmer will not do 1.8V
                                          I need to program a 25Q64FWTG
                                          I could splash the cash and buy a V11.71 TL866II. These come with various attachments and the kit including a 1.8V adapter is either €62 with 12 adapters or €68 with 1 7adapters. I also have the option to buy just the programmer for €46.70, if I could get the 1.8V adapter separately and use the other eprom adapters from...
                                          01-31-2022, 06:14 AM
                                        • Teeheeze
                                          RT809H Programmer Firmware Corrupted
                                          by Teeheeze
                                          This is a shot in the dark, but I was just using my RT809H programmer and it got stuck in a certain state so I power cycled it. Now, the device LED just flashes quickly and does not connect to the software. I've tried to update the BIOS of it and it fails. I went so far as to remove the ROM from the programmer itself but it's some weird chip (I believe ATMEL, but I can't find any datasheet on it) so I've been unable to read the BIN from it w/ my other programmer. Chip has ATMLHC4C56BM CN written on it (I think). I'll upload an image. I have the programmer's BIN ready to program it manually. Anyone...
                                          02-13-2025, 04:51 PM
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • Jeff'sTech
                                          Dell Latitude 7420 BIOS Unlock Gone Wrong
                                          by Jeff'sTech
                                          Hello everyone.
                                          I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                          11-08-2023, 03:30 PM
