The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
  • STKR123
    • Jun 2023
    • 12
    • Country
    Greetings badcaps community,
    I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
    So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
    Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
    I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
    These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
    I learned that desoldering and reflashing the chip would be the best way. But I dont have steady hands anymore.
    So, Im looking for a cheap but durable allround BIOS programmer with a clamp, so I wont have to desolder the chip, as my hands arent able to do that anymore.
    If I understood correctly, old BIOS files operate at 3,3v, newer ones at 1,80v. I can see there ar 80$ programmers and 12$ programmers.
    For now I cant afford a 80$ programmer. And Im not sure which cheap one to purchase regarding the Elitebooks.
    If I understood corectly I:
    1.) Dump the original BIOS file 1st, using a software (and a programmer)
    2.) Run RCUnlocker by dragging the dumped .bin files onto the .exe (compatible with older Elitebooks)
    3.) Reflash the now fixed .bin, as it no longer would have a password.
    4.) Be happy.
    I also read about the 2MB EC chips as well, DMI and ME region and again, I havent worked with BIOS files for a long, long time.
    Hence Im still unsure how, for example, the EC, DMI and ME region chip might be involved, regarding the BIOS password / flashing issue here.
    I read on badcaps that donor BIOS files are "dirty" and only run on the original device. So I have to do it on my own, with hopefully some support from the badcaps community.
    For now I was hoping that someone could point me at the right programmer and the right software to dump the Elitebooks BIOS files
    to use RCUnlocker and be able to reflash it.
    But I also read some people still had a password protected BIOS after reflashing it.
    I tried to read most of the Elitebook 820/840 threads here, I read about 16mb, 32mb and modded 16mb chips.
    Still a lot to read (and to understand), but Id love to dive back into this. At least partly. ;-)
    If you reached this line, thank you!
    In short my questions would be:
    a.) Which "cheap" programmer with a clamp would you advice to me?
    b.) Which software would be the most fitting/compatible and easy to use, to dump the BIOS with the programmer?
    c.) 820 G1 / 840 G2 should be compatible with the RCUnlocker and I shall not worry regarding EC, DMI and ME Engine when attempting to remove the password. (?)
  • hotcrossedbuns999
    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
    by hotcrossedbuns999
    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
    3. I could only locate two chips that look like bios chips. Could someone verify this
    01-03-2025, 12:32 PM
  • Wutru
    HP Elitebook 820 G4 BIOS repair assistance required
    by Wutru
    Hi guys,
    If someone would be able to provide some expertise, I'd be very grateful.
    BIOS Corruption - Cause
    So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
    After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
    09-06-2025, 10:32 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • Guest
    Elitebook 850 G5 BIOS bricked
    by Guest
    I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
    I assume the BIOS update failed, so I searched for the BIOS chip.
    I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
    However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
    Can the corrupted...
    03-24-2025, 01:21 AM
  • TopPop
    Dell Latitude 5530 BIOS Password Removal Attempted but I Broke the Laptop
    by TopPop
    Sorry for the long story. I have a Dell Latitude 5530 (i7) laptop (South Peak 15 MLK MB DDR4 203102-1 FK8VG$JA) with an admin BIOS password that I want to remove. Service Tag: HYKFPT3. Other than that the laptop worked OK.
    I found a CH341A Black and went looking for the BIOS chip on the motherboard. After trying to read one chip that was a firmware chip but not the BIOS I think I found the BIOS chip labeled Winbond 25Q256JVEN. Altogether I think I found 4 different firmware chips in the laptop. The BIOS chip is a WSON8 6x8. I used the CH341A, NeoProgrammer, and a cheap pogo pin clip...
    12-14-2025, 09:40 PM
