Everyone is buying the wrong CH341 programmer
  • lotas
    • Jan 2016
    • 5398
    • Russia
    Measure the voltage in the laptop between 4 and 8 pins, and then you will know what voltage the spi flash is designed for.
    • Billy1690
      • Aug 2024
      • 46
      • football fishing
      Hi buddy im getting 3,353 is that about right
      • lotas
        • Jan 2016
        • 5398
        • Russia
        Yes, its supply voltage is 3.3v
        • Billy1690
          • Aug 2024
          • 46
          • football fishing
          Ive been flashing recommended dump files on the chip with 3.3V and still get the flashing cap lock is it possible this programmer isn't detecting the correct chip as i cant see the number on the chip as its worn away to put it in manualy
          • lotas
            • Jan 2016
            • 5398
            • Russia
            First you need to look at what the protection (status register) is (remember, it may be useful in the future), remove the protection (status register), then erase and write dump...
            • Billy1690
              • Aug 2024
              • 46
              • football fishing
              #26
              Can i use the protection status register settings on this ezp2023+ or is it something i would need to read up on
              • lotas
                • Jan 2016
                • 5398
                • Russia
                #27
                I don’t have such a “programmer”, and in my opinion it cannot work with status registers.
                • Billy1690
                  • Aug 2024
                  • 46
                  • football fishing
                  #28
                  Does this programmer XGecu T48 support status register
                  • lotas
                    • Jan 2016
                    • 5398
                    • Russia
                    #29
                    Yes, maybe CH341A can do it too with the program "NeoProgrammer V2.2.0.10".
                    • Billy1690
                      • Aug 2024
                      • 46
                      • football fishing
                      #30
                      Brilliant Lotas looks like im gonna get the XGecu T48 ill look on Aliexpress shortly thanks again for all your advice
                        • 31938
                        you can test the T48 software in demo-mode to see if it has the features you want.
                        http://forums.xgecu.com/viewthread.php?tid=20
                        here is the goods
                        https://www.aliexpress.com/store/480...26abbperbperpr
                        • Billy1690
                          • Aug 2024
                          • 46
                          • football fishing
                          #32
                          Cheers Stj as soon as I get one you can help me set it up 👍😄
                          • Billy1690
                            • Aug 2024
                            • 46
                            • football fishing
                            #33
                            That’s it ordered thanks buddy 👍😉
                            • CuriousDave
                              • Aug 2024
                              • 11
                              lotas is right about the clips. If you work with the BIOS often or not, better have the adapters. I bought the adapters cost less than $10 each and some are selling less than $5. The pins do not have enough space to use alligator clips.
                              • harp
                                • Jun 2022
                                • 728
                                • Planet Earth
                                #35
                                "The pins do not have enough space to use alligator clips." Here is method how to overcome this issue http://www.youtube.com/watch?v=SrAzVT1OKEA
                                • Billy1690
                                  • Aug 2024
                                  • 46
                                  • football fishing
                                  #36
                                  Yes i binned the alligator clips and got adapters and a T48 programmer great bit of kit ive programmed a W25Q64FVSSIG bios chip not fitted it yet but fingers crossed
                                    • 31938
                                    nice.
                                    the software can run in Linux btw - you just need an extra DLL file i can post.
                                    • Billy1690
                                      • Aug 2024
                                      • 46
                                      • football fishing
                                      #38
                                      Dont have Lunix im on windows buddy but thanks anyway good to know are there any special settings i use for the T48 programmer to copy & wright a bios file or will default settings be ok
                                        • 31938
                                        just select the chip - thats pretty much it.
                                        • Billy1690
                                          • Aug 2024
                                          • 46
                                          • football fishing
                                          #40
                                          Brilliant pal thank you im gonna fit the chip tomorrow so fingers crossed this flashing cap lock thing disappears and it boots up ill keep you posted pal thanks again for your help
                                          • chazzo
                                            CH341 programmer advice, including jumpers seemingly reversed
                                            by chazzo
                                            I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
                                            [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
                                            I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
                                            10-12-2025, 08:15 AM
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • TonyCajeta
                                            SAS Programmer rev 4.0 SAS JIG3 Issue
                                            by TonyCajeta
                                            This is my first time trying to use my SAS programmer; I downloaded the software recommended by the seller (ioprogrammer-com on eBay), but it seems to require an additional registration that costs +$50 (It was never mentioned in the purchase description) So ... I can't find any other way to get the programmer working, and I need to flash an ENE EC (KB9542Q) that is not outputting the EC_ON signal (3v LDO is present, no shorts present on 3VALW rail nor EC_ON line, nor open circuit). Does anyone know anything about this?...
                                            07-02-2026, 02:08 PM
                                          • capes
                                            Can't read BIOS chip Winbond 25R256JVEN
                                            by capes
                                            I'm working on a Dell XPS 13 9305 LA-K461P
                                            I suspect that the BIOS is corrupted/bad. The laptop turns on after power button press but no fan spin, CPU is cold and only keyboard backlight LEDs come on. Voltage rails 3V3, 19V, 8V all present.
                                            So, I attempt to read BIOS chip - I have desoldered the chip from the board and put it on a breakout board and into socket of CH341B programmer, but NeoProgrammer, AsProgrammer and CH341 programmer all freeze when attempting to read the chip.
                                            I thought perhaps the CH341B is bad and tried to use another method with a raspberry...
                                            07-07-2026, 03:23 PM
                                          • dicky96
                                            CH341 Programmer - any good for 1.8V?
                                            by dicky96
                                            Hi guys
                                            I have a TL866 CS Eprom programmer and up until now it did everything I needed to do
                                            However for the first time I have come across a 1.8V Eprom and my programmer will not do 1.8V
                                            I need to program a 25Q64FWTG
                                            I could splash the cash and buy a V11.71 TL866II. These come with various attachments and the kit including a 1.8V adapter is either €62 with 12 adapters or €68 with 1 7adapters. I also have the option to buy just the programmer for €46.70, if I could get the 1.8V adapter separately and use the other eprom adapters from...
                                            01-31-2022, 06:14 AM
