bargain test gear!
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    bargain test gear!
    hey guys ,just managed to get a scope,hameg203-4 20mhz,a signal generator,farnell lfp1,and a power supply manson ep-613 all for £60!
    will be my first scope to play around with but need want to get a probe for it,the one that came with it was a standard type one,but would like to get a proper probe for it,which one would i need to get?.
    havent a clue what to use the sig gen for yet and if it will be any use for tv repair.
    the power supply will be handy,i already have one,but will come in usefull im sure.
    will put up some more pics soon. of the insides for anyone who may be interested.
    what do you guys think of this stuff?,i know the scope is 20mhz,but should trigger up to around 40mhz i guess?
    the guy threw in a large breadboard with power supply connections,art of electronics,and some digital books also!,so i think it isnt a bad buy
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: bargain test gear!
    on the sig gen,what would the jack socket marked "amp in" be used for?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      looks a good buy dual trace at that price theres a manual here if you need it i was thinking about getting a 20mhz scope but would have no idea how to use it lol.
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        i use the scope at the moment for checking crystals in my tv sets,its found 2 faulty with no output sine wave so far,will get more into scopes and there uses for tv repair soon.
        20mhz should be fine for tv repair it triggers up to 40mhz which i think is more than enough.
        thanx for the hameg link that will come in handy as i want to service the scope,clean all the pots switches etc,replace worn dodgy components.
        just need to get my head around the signal generator and its uses,how to use it,for tv/amplifier repairs etc.
        just waiting for my fluke 87v to turn up next weeklooking forward to it,like a kid in a sweet shop lol
          20MHz is fine for 1080p plasma, let alone most electronics repair. It'll likely trigger up to 100MHz, but remember, past around 20MHz, the amplitude scale is completely inaccurate.
          What frequency can the generator go up to?
          Looks like you got a nice bargain!
          • Kiriakos GR
            Banned
            • May 2012
            • 940
            • Greece
            You just reminded me the Matrix movie.... load to me the software for driving a military helicopter... Loading ... Ready .. I am driving the helicopter.
            I have the feeling that this is an common sound generator, even so if you do not repair stereo preamplifier so to compare their output, you will not find it as interesting.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              manual for signal generator
              http://archive.org/stream/FarnellLf1...ge/n0/mode/2up
                "on the sig gen,what would the jack socket marked "amp in" be used for?" You can use external source to drive the power amplifier inside the generator, the amp can drive the load down to 3 Ohms, so you can connect the the speaker (4 Ohm or 8 ohm pseaker) to the output terminal and use it to amplify the signal such as audio source through small DC blocking/coupling capacitor (10uF /50V or so, the amplifier uses direct couple with input Z around 100K). I.E. the TV does not have sound through speakers, you can take the Audio line out from the RCA jack (Red and White) one at a time and feed into the amp input, if you do get the sound from RCA jacks, then the problem is down the line after the pre-amp section.
                The Square wave out put function can be set to about 150Hz to drive the PWM Dimming control signal pin on the backlight inverter board (if the inverter uses the PWM for dimming control), at 50/50 Pulse width, the backlights will be at about 50% brightness.
                  1MHz maximum -- not too shabby at all! I need to find deals like this...
                  • multimeter
                    • Jan 2011
                    • 739
                    • united kingdom
                    great read bud and interesting,ok,i do quite a lot of repairs on guitar amps as well as tv's and other electronics,on the guitar amps could this generator output as a tone generator then?,to trouble shoot scratchy pots,intermittant dodgy jack inputs or even troubleshooting the pre-amp and final amp stages?.
                    im assuming if the output from the sig gen was plugged into the input of an amp,and putting a scope on the output of the amp i can trouble shoot that way by looking at the waveform?or am i thinking of this all the wrong way?
                    id love to know other uses for this, it really is exciting stuff,its just getting my head around using it and the techniques to apply to it and aid in troubleshooting.doesnt seem a lot rumaging around you tube as far as amps repair using a sig gen.
                    @tom, il keep my eyes open for a deal,seem to get them popping up quite a bit il drop you a mail if i see something that may be of interest.by the way when you say on the scope that the amplitude will suffer if going up to a 100mhz trigger,do you mean the sine wave etc will look "flatter"on the scope?more of a straight line than a wave.
                      You can use the sig gen and scope to do exactly that, it's easier than trying with music sources because it's more predictable.
                      The sine wave amplitude will fall, it will not be particularly distorted but it will represent around 1/3rd its actual amplitude at 100MHz, still, this is not usually a problem.
                      • chth96
                        How Can I test PWM DM0365R?
                        by chth96
                        Hello
                        I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                        So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                        I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                        I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                        06-18-2025, 04:14 PM
                      • khelane
                        test active pfc power with lamp test
                        by khelane
                        Hello
                        I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                        Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                        Is there a way...
                        06-03-2025, 01:00 AM
                      • chronic519
                        Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                        by chronic519
                        Hello.
                        GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                        Found issue with a RAM block
                        Replaced, green lines gone.
                        Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                        Used a good card to test and same results low errors 32+.
                        I am just search for some form of command to do a full test on the GPU.
                        I just ran the mats command with my good GPU and passed after roughly 40 min.
                        The repaired one, ran...
                        05-20-2025, 07:56 PM
                      • alltvrepairs
                        Lg TCon test pins for screen test
                        by alltvrepairs
                        i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                        Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                        Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                        Appreciate your help....
                        06-13-2025, 06:33 AM
                      • render1967
                        Problem with the Logitech G27 gaming steering wheel gear lever
                        by render1967
                        Hello! First, please excuse me if my English is not good enough because it is not my native language!
                        Now let me describe my specific problem. For two days, the gear lever on my Logitech G27 has shown the following defect. When switching in the game (for example ETS2) it often does not detect 1st, 3rd and 5th gear - in these positions it shows neutral or flashes between the specific gear and neutral (for example - 1st <> neutral). When I press the gear lever to the left or right while it is in a position, it still manages to guess the gear and engage. In addition, instead of rear...
                        11-13-2021, 01:35 PM
