Cheap meters.
    • 31084
    Re: Cheap meters.
    bit pointless,
    most people choose a battery by the word "Alkaline" followed by the price.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Re: Cheap meters.
      Actually it's kind of weird for PP3 batteries, the mAh of PP3 per cost is a bit higher for alkaline for some reason... If Wikipedia is correct (and that multimeters are indeed low drain devices):
      Potassium hydroxide electrolyte = 550mAh
      Ammonium chloride electrolyte = 400mAh
      Now finding alkaline for less than $2 a pop is tough, and these NH4Cl for $0.50 a piece?
      This is probably moot anyway as PP3 is probably going to be as hard to find as A23 some day...
        • 31084
        Re: Cheap meters.
        the chinese will make adapters that look like a pp3 with space for 3 lithium coincells in it!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Re: Cheap meters.
          Actually three lithium coin cells will cost more than manganese and zinc, wouldn't it?
          A CR2032, probably cheapest because of mass production, only holds 240mAh or so, but assembling it into a PP3 case will require some effort.
          However you might be on to something, if I can get six CR2032s into a PP3 case for less than $1, that might be a good long term solution for finding PP3s. I have a few PP3 shells ready
          • junktv
            • Nov 2010
            • 3065
            Re: Cheap meters.
            This is a little more than most in this thread but it looks like fluke has models for chinese market not sold other places that are under $100.
            Here are some vids on the 12+e model
            www.youtube.com/watch?v=XDm5BfRrAsg
            www.youtube.com/watch?v=rJm9iCha-jM
            www.youtube.com/watch?v=FUmbsBYVTQ0
            There is a few vids online of the different models and yall know more than I do but figured i'd post in case no one else knew.
            Testing the 17b version.
            www.youtube.com/watch?v=wiiii0gdcbM
            • gearhead63
              • Jul 2014
              • 14
              Re: Cheap meters.
              I bought a couple Uni-T UT890D meters from Gearbest.com, about $20 each, work great, and I got an HY-19 (whatever that is) for $15.00 from gearbest on sale. It's actually a decent meter, fully fused with HRC fuses. Glad I got it on sale cause they aren't that cheap now.
              file:///G:/ELECTRONICS/HY-19%20Digit...Amazon.com.htm
              • TechnicsHiFiFan
                • Mar 2018
                • 13
                Re: Cheap meters.
                There used to be a chain electronics store here in Australia called Dick Smiths, after the guy who created the electronic stores
                I have a cheap Dick Smith, not sure its probably a rebranded model of a known brand, but checking it on 1.5v batteries it seems spot on. I just wished it had ESR and Capacitance measuring capabilities
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  Re: Cheap meters.
                  Horror Fright "updated" the cheap multimeter you can sometimes get for free with a coupon.
                  Here are some of the things they changed.
                  The probes are now 24 inches long instead of 32 inches long probes the older units had but they're also using 18 gauge CCA wire (Copper Coated Aluminum?)(It's what the box says at least) unlike the older units with their wire size being somewhere around 24 gauge or thinner.
                  They lowered the max voltage and current specs, the new max AC and DC voltages are now 250v, unlike the old units where the max AC voltage was 750v and the max DC voltage was 1Kv. The max number of amps this thing says it can do is now 5A, unlike the old units which were all rated for 10A max. (My only guess as to why they did this is liability reasons)
                  They changed the design a tiny bit, they also removed the Cen-Tech name so now it's just a '7 function digital multimeter'. The manual is also way smaller. (They also put Diisononyl Phthalate into the plastic to make it more flexible, the only reason i know this is because of the Prop 65 warning on the back of the box (thanks, California lol))
                  And those are the most notable changes to this thing, i also posted some photos of a side by side comparison of the older (left) and newer (right) units.
                  I'm not a expert, I'm just doing my best.
                    • 31084
                    Re: Cheap meters.
                    does the new manual say "centec" on it??
                    it may have been moded to order by the seller.
                    btw, i just ordered a similar one to hack up for a project idea:
                    https://www.aliexpress.com/item/DT83...798720621.html
                    be interesting to compare against these.
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      Re: Cheap meters.
                      The manual does not have the Cen-Tech name anywhere in it.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Re: Cheap meters.
                        Nice... gosh hazard fraught tools should just remove the transistor tester if they want to cheap out further. I don't see a person going to HFT to buy a meter to test transistors...
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Re: Cheap meters.
                          ... also a good excuse to get another one when one screws up and blows that soldered on board 0.5A fuse...
                          On another note, I just had one of hazard fraught tools' "better" multimeters die on me. Once again the annoying dual sided board with tracks running underneath components and the contact-on-board selector switch... ugh! Symptom is that there's no power going to the COB I think, need to see what happens if I force power to it and see if it at least still lives...
                            • 31084
                            Re: Cheap meters.
                            well the one i ordered is losing all that, i'm hard wiring it for 200vdc to make a new zener tester.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              #54
                              Re: Cheap meters.
                              ^^ That is actually a good use for those.
                              A working TV? How boring!
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Re: Cheap meters.
                                I just need to find something to buy at hazard fraught tools so I can get my free PP3 battery and COB 7106...
                                else a flashlight with 3x AAA...
                                Abuse of coupons?
                                • redwire
                                  • 3910
                                  Re: Cheap meters.
                                  I use a disposable camera strobe DC-DC and two-transistor current source, for checking zeners/TVS in my pile.
                                  The 328 Tester can measure up to 50V if you add a converter but I've never tried it out or found a 50V boost converter for it.
                                    • 31084
                                    Re: Cheap meters.
                                    at the moment i use a 100% built circuit i posted the schems for here,
                                    but i'm wondering if i can use the invertor for those ccfl pc lights instead because it's more compact.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      #58
                                      Re: Cheap meters.
                                      Abuse of coupons?
                                      ^ This, lol
                                      I do the same too. Though, I have to say, their free 6-piece screwdriver set is probably the most worthwhile free thing I got from them that has also lasted a good time. The thing is, you only need so many screw drivers. Multimeters, on the other hand - one can never have enough of those. I use my two HF meters quite often for quick low voltage, low current, and sometimes also resistance measurements. With my hot-glue-modded stock probes (to prevent them to braking within 5 minutes of opening the package), these meters actually work OK..... that is, provided I rotate the dial a few times prior to use. Otherwise, the poor contacts in the dial cause all kinds of bogus readings. This happens on both meters. And yes, I've tried cleaning the contacts before. It works, but only for a few weeks at best.
                                      Cool, thanks for sharing that.
                                      I guess HF had too many complaints about these meters not meeting their specs, so they finally changed a few things.
                                      Regarding the probes: good to hear they are using thicker wires now, even if the probes themselves are shorter. I'll take that over the old crappy thin noodles they pass as wires. On those old probes, pass anything more than 3 Amps, and they got warm real quick.
                                      Regarding the plastic improvement: yup, about time. One of my meters is literally held together by *sigh* more hot glue, because all of the internal screw posts were cracked from the factory. And it's not due to assembly error - the plastic of the older meters really is much more fragile.
                                      • RukyCon
                                        A Fake Rubycon
                                        • Jan 2017
                                        • 816
                                        Re: Cheap meters.
                                        I found out a few days after making the post that the probe wires on the older meters are also 24" long even though the box said 32" probes.
                                        Also, the plugs on the new meter (the ones used for the connecting the probes to the meter) are much looser on the new meter versus the old meter.
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          Re: Cheap meters.
                                          The free meters have six different models : 63604, 63758, 63759, 69096, 90899, and 98025. As far as I found, the 63xxx models are the ones with 250V limit and 5A.
                                          The 69096 has 29" leads, 90899 has 32" leads, but the 98025 has 24".
                                          I don't know the differences between the 63xxx meters.
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                          • eccerr0r
                                            lowest current galvanometer/analog meter (passively powered!)
                                            by eccerr0r
                                            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                            04-16-2025, 12:41 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
