Bob Parker ESR Meters
  • Bob Parker
    replied
    Re: Silicone Chip's ESR meter kit @ DSE (AUS)
    Originally posted by tazwegion
    Just picked mine up (thanks for the tip), shop assistant said the $79.95 -> $24.95 price drop reflected the low interest in this particular kit project, hence it was his belief that this was a product run out special
    So folks... come get 'em while they're HOT!
    "Low interest"....? The guy's a fool. It's simply because DSE's management has made the executive decision to stop production of all kits and they're trying to get them all out the door so they can use the space for more phone answering machines, MP3 players and vacuum cleaners.
    There's still a lot of interest in ESR meters!!
  • Bob Parker
    replied
    Re: EVB ESR Meter (Bob Parker Design)
    Originally posted by starfury1
    Humm a quick look at the meter comparison at Anatek reveled this....
    Not sure if its in ref to MKI or MKII Kit maybe both
    They were not specific as to what this "degradation in the components" was?
    (apart from "Good, quality of components has degraded recently")
    Still at $80 AU it might be something to winge about at $25 AU guess not
    Anatek Comparison of ESR Meters HERE
    Suppose the short answer is replace any parts you consider are lower quality with a better spec device.
    If you think it really needs it.
    I didn't see this info till now or other wise I would have posted it along with the original post on the $25 deal
    All that's 'degraded' that I know about is that the 7 segment displays they've put in recent kits aren't very bright. For those lucky enough to be in the USA, Mouser Electronics sells Kingbright SC56-11EWA ones for about $1 each, which should be much better and they just plug into the socket.
    I'm not sure if they're available Down Under....
  • Bob Parker
    replied
    Originally posted by willawake
    welcome to crapcapland Bob!
    thanks for designing the meter it brings troubleshooting to another level.
    As I told kc8adu, I've been looking at what's going on here whenever I see a lot of visitors to my ESR meter web page coming from this forum. He talked me into joining up, so you can blame him for me making a pest of myself here!!
    Before I forget, I really appreciate the nice things people have been saying about the little ESR meter I designed way back in the middle of 1995. It's that old now! Thanks!
  • willawake
    replied
  • Spacedye69
    replied
    Thanks for the info, Bob!
  • Bob Parker
    replied
    Originally posted by Spacedye69
    I will agree about the probes. The jacks seem to be pretty good, but the tension on the banana plug is low and the do not make a stable conection. I have to hold real still and wait 5-10 sec for the reading to stabilize.
    If you've got some completely-evaporating contact cleaner like CRC CO, spray it all over the plugs and jiggle them around in the jacks before it evaporates. That usually helps. Also give the probe tips a brushing with a wire brush occasionally.
    The problem is that on the bottom range, the meter's reading 1/100ths of an ohm, and varying contact resistance shows up real bad.
  • starfury1
    replied
    Hi all
    Yes gdement you are right re the silkscreen being a mod for MKII according to info
    Sorry to hear of your drama's
    I have Both MKI MKII
    The MKII I bought first few months ago see pics on page 2 its is marked as the MKII version PCB (10/03)
    I think I got a dud cause it didn't have holes for the 220 uF Cap either
    (I had to mount it on the back)
    I paid $70 odd AU for it..it was $10 off normal price if memory serves me.
    I bought the MKI for the fire Sale price it was the last one in the shop.
    I don't think there is any component or circuit changes
    (Haven't absolutely checked thought)
    Apart from I knew firmware and the use of 1V5 batteries as opposed to the 9V one used in the MKI
    MKII is the improved version of the MKI
    As to your problems with the bannana leads, well see if you can source better quality plugs or leads is one idea.
    If you go the other way, use a grommeted hole and a stain relief clip or you could possibly try on of those screw down cord clamps but you may not have enough room for one on them I think.
    The zero function should take care of any spurious capacitance etc with the leads
    if you want a pic of what I am talking about let me know.
    I use my multimeter leads or the leads that come with my capacitance meter
    Bit better quality then the cheapies supplied
    So yeah best advice buy some good quality leads or plugs
    (sockets and probes for that matter if you don't think they are up to it).
    I suppose the big question then becomes were do you get decent quality connectors these days?
    If you don't mind, Post some pics of the mod if you go with that
    Cheers
    Per keep us posted mate
  • Spacedye69
    replied
  • gdement
    replied
    Congratulation's mate
    WOW you got a silkscreened overlay should have make construction much easier for you so I am glad especially since this was your first kit I think you said.
    The silkscreened overlay was one of the changes for the Mk2 version. If I understand correctly, you got the Mk1 so that wouldn't have had the silkscreen.
    Mine arrived a couple days ago and is now working. I spent a crazy amount of time trying to debug something that wasn't broken - the startup diagnostic just isn't as easy to use as the directions make it sound. I thought it was frozen at the "-" but it really wasn't. I also had problems with the meter turning off when I tried to zero it.
    My current problem is the probes. I figured out that the meter is working fine when I put pieces of wire or resistors directly into the banana plugs, but the probes produce wildly unstable readings making the meter unusable.
    I've decided to solder them directly to the board, but I'm trying to figure out how best to provide strain relief. I don't want the probes to get yanked off the PCB.
  • Per Hansson
    replied
    Got mine yesterday, will assemble it in the weekend and post pics, mine too had a silkscreen...
  • starfury1
    replied
    Yours might well have been an early production run since it appears to be 1 or 2% resistors
    The overlay on the PCB should help others who like me weren't lucky enough to get one.
    Cheers Mate, may it serve you well and save you lots of time
  • Spacedye69
    replied
    I am now an owner of a WORKING ESR meter! WOOHOO!
    I started by making sure all the parts were there, and they were. I checked the board for bad/ missing traces, bridges, etc. I then began to install components, starting with the resistors. I found it easier to keep track by installing values that had multiples, then worked my way down to singles. I did the same for transistors
    When all the components were on the board, I just followed the testing procedures spelled out in the instructions. To my amazement, everything worked the first time!
    Calibration with the supplied resistors and instructions was fairly straight forward. This was the first device I have assembled from a kit, so I was pleased overall.
  • willawake
    replied
    well i think they should offer both. bob should go into business himself for this product.
  • starfury1
    replied
    There is a pole running on Bob's web site about the possible demise of the Kit from DS
    Apparently Dick Smith Electronics have stopped making ESR meter kits
    (some are still in stock).
    I need to know if people prefer a kit meter or a fully-built one,
    to know how we're going to fill future demand for them.
    Please take the time to vote in my little poll. Thanks!
    (scroll down a bit if you don't see it)
    So please go "Vote your preference on this matter
    Bob's site Here
    I don't know of anything cheaper then the Kit for a Digital one
    but could be wrong too.
    For those who don't have a Variable DC supply
    Here's Bob's page on how to do it
    Cheers all
  • starfury1
    replied
    Further to willawakes.... question here the info from the manual.
    Please also note:
    The typical ESR values are different on each meter for value of capacitance, reflecting improve technology in making them from the blurb on the MKII manual.
    So Testing and Calibration....this is much the same (if not exactly) for the MKII version.
    For Calibrating, Battery low a DC PSU Variable would be ideal but if you haven't got one there are ways to do it without have to buy one.
    Cheers all
  • starfury1
    replied
    Hi Willawake, All
    It came with 2 resistors
    (1% think they are suppose to be)
    5R6 and 82R
    You adjust VR2 from memory
    (Bit of a procedure to it)
    BTW the above method of placing components leads is NOT the Accepted correct method
    They should be flush (flat) to the PCB pad and yeah there would be technical reasons as to why.
    Since I am the only idiot ever going to fix this and its mine I did it that way for 2 reasons.
    Easier and less chance of PCB damaged if I have to remove a component.
    Less chance of solder bridges.
    Thats my excuse
    cheers
  • willawake
    replied
    how did you calibrate it?
  • starfury1
    replied
    Hi all ok
    Finished building the ESR Meter MKI EA Version So here are a few photos of the construction.
    If you are building the Silicon Chip MKII Version see the photos of in my post way above.
    Yes I made a few Boo Boo's so make sure you check your work...
    It all working fine now
    I highly recommend you have a Mag glass and or Jewelers loupe
    First off I checked I had everything
    DS forgot 1 resistor....(good thing I had one)
    Then gave the PCB a good going over to make sure of no dags or broken tracks.
    if you are not sure of a resistors value measure them
    I next mounted Resistors (id start with the 1% ones) Diodes Sockets Transistors/Reg Capacitors LED's
    IC's are left till last and thats after testing for +5V DC on correct pins of sockets.
    These can be damaged by static so so take usual precautions with CMOS.
    Check you work as you go along,
    it really is very easy to make a mistake or create a solder bridge.
    (why I scanned the PCB above, for reference)
    A photo of both version is below too.
    As the CMOS Cook Book says ...
    Blame Your Self First and the IC's Last!
    Good luck
    Bob Parker's Design
    Electronics Australia Version
    ESR\Low Ohms Meter MKI
  • starfury1
    replied
    Thanks Guys for the update
    BTW with the MKII I build I had to put the 220 uF cap on the back of the PCB
    Next To the two 1N4004's
    Pads were there but no holes in the pcb I got.
    Haven't started construction of MKI yet but will soon
    Cheers
  • Per Hansson
    replied
    Think Per was the other person that said he ordered one...
    let us know how you go too Per.
    Cheers
    It was shipped the 6:th
    So it'll probably be arriving any day now...
  • chth96
    Is it possible to test small ceramic disc capacitor with analogue meter?
    by chth96
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue...
    03-09-2024, 10:03 PM
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
  • eccerr0r
    lowest current galvanometer/analog meter (passively powered!)
    by eccerr0r
    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
    04-16-2025, 12:41 AM
  • chth96
    How Can I test PWM DM0365R?
    by chth96
    Hello
    I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
    So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
    I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
    I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
    06-18-2025, 04:14 PM
  • khelane
    test active pfc power with lamp test
    by khelane
    Hello
    I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
    Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
    Is there a way...
    06-03-2025, 01:00 AM
