Vizio M370NV Powers on for 2 seconds then shuts down
  • MisterD
    • Oct 2012
    • 668
    Has a normal Amber Vizio Logo, goes to White Logo when powered on, screen lights up and displays that Vizio logo on screen, stays on 2 to 3 seconds then powers down by itself. this happens each time it is powered on. I haven't disassembled it yet. I'm thinking possible LED strip open or shorted. any thoughts? Thanks.
  • nomoresonys
    • 12323
    • U.S.
    Re: Vizio M370NV Powers on for 2 seconds then shuts down
    With tv unplugged from outlet, unplug cable from powerboard to mainboard, plug tv back into outlet, see if backlights come on and stay on.
    • MisterD
      • Oct 2012
      • 668
      Thanks, I will get to that as soon as possible, other things going on right now. I just got this Vizio from a garage sale and haven't had a chance to disassemble it yet. hopefully Tuesday of this week.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        probably bad LED(s) in the backlight.
        • MisterD
          • Oct 2012
          • 668
          .........I Unplugged Cable from Powerboard to Mainboard and just as I thought no power to Mainboard therefore TV would not power on at all.
          • MisterD
            • Oct 2012
            • 668
            This camera is not very high quality but here are some pictures
            • MisterD
              • Oct 2012
              • 668
              I have an isolation transformer, can this be used on this TV at a lower voltage setting? maybe set it at 90 or 100 volts or would that not be advisable on these flat screen tv's? we used this method on the older CRT TV's when they had a shutdown problem and could keep them powered on at a lower voltage for troubleshooting purposes.
              • R_J
                • Jun 2012
                • 9633
                Your isolation transformer/with switched output, won't help, this power supply is universal input 100~240vac input and it will have no real effect on the power supply voltages.
                You should be able to check the power supply/backlights by:
                disconnect the cable between main and power supply boards
                using a few 470Ω~1kΩ resistor
                Connect one between 5.1VSB and REMOTE_ON/OFF (this should turn on the power supply)
                Connect one between 5.1VSB and BL_ON/OFF (this should turn on the backlight but may need dim signal)
                Connect one between 5.1VSB and DIM_PWM_SIGNAL ( this should turn on the backlight)
                • nomoresonys
                  • 12323
                  • U.S.
                  The tv isn't meant to turn on and work, it's a test for certain psu and backlights, comprende?
                  • MisterD
                    • Oct 2012
                    • 668
                    I will have to see if I have the resistors if not I can get them from a local TV Shop, too bad Radio Shack closed down. CN201 doesn't have anything plugged into it.
                    • MisterD
                      • Oct 2012
                      • 668
                      The tv isn't meant to turn on and work, it's a test for psu and backlights, comprende?
                      Yes, I understand post #8 using the resistors. Thanks
                      • R_J
                        • Jun 2012
                        • 9633
                        Check the value of R341 and R327, if their value is over 500Ω you can omit the resistor I suggested and connect the pins direct to the 5.1VS
                        After looking closer at the board, DIM_PWM_SIGNAL may not be used on this model and the backlight should come on with the BL_ON/OFF line.
                        This board uses pulldown resistors so without the main connected the power supply stays in the OFF/standby state
                        • MisterD
                          • Oct 2012
                          • 668
                          R327A is 1 k ohm and R341 is less than one ohm and it has only one black stripe.
                          • R_J
                            • Jun 2012
                            • 9633
                            Ok, you won't need a resistor between REMOTE_ON/OFF, so connecting CN202 pin 11 to the 5.1VSB directly will be ok, that will turn the power supply on. I'm just not sure about the BL_ON but you may not need a resistor for it either.
                              The reason I always suggest to use the resistors for force on incase you jump the 5.1VSB to the wrong pin.
                              • MisterD
                                • Oct 2012
                                • 668
                                I had a 4 pack of 560 ohm resistors, I have connected them with small alligator clip leads and this did force on the power supply and backlights are on now...I did have backlights prior to this test but the tv would power itself back off in about 2 to 3 seconds...now that I have these resistors in place what would be the next step???? I tried to see if all led's are on but it's hard to tell from the back side, but it appears as if they are.
                                • MisterD
                                  • Oct 2012
                                  • 668
                                  Here's how I jumped in the resistors. Yellow 5.1 VSB supply to resistors. red to pins 11 & 12 used one resistor here, and green to touch one side of pin 14 being careful not to touch pin 13.
                                  • MisterD
                                    • Oct 2012
                                    • 668
                                    Thanks Bud.
                                    • MisterD
                                      • Oct 2012
                                      • 668
                                      Thanks Bud.
                                      Thanks budm
                                      • MisterD
                                        • Oct 2012
                                        • 668
                                        • riki_22
                                          ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                          by riki_22
                                          Hi everyone,
                                          I’m working on an ASUS B5402CEA notebook.
                                          B5402CEA_MB_R2.2
                                          HA4YT LA-L861P
                                          REV:1B
                                          The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                          I suspect the BIOS might be corrupted.
                                          Could someone please check and clean (repair) the attached BIOS dump?
                                          I’ve also attached a few photos of the motherboard for reference.
                                          Thanks in advance for your help!
                                          11-03-2025, 04:38 AM
                                        • survivalbloke
                                          Dell laptop powers up with kb backlight about 10 seconds, then shuts off
                                          by survivalbloke
                                          I've got a Dell Latitude 5580 which came in for no power. It's not exactly a no power issue though. The battery was puffy so I replaced that, but the symptom is that when the power button is depressed, the keyboard backlights will come on for about 10 seconds then go back off. Before depressing power button, I am drawing 112ma and oddly, there is no change in current draw once the button is pressed and the keyboard backlights illuminate.
                                          Any ideas?
                                          01-08-2024, 12:12 PM
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • APOPAP
                                          Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                          by APOPAP
                                          Hello everybody,
                                          First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                          The same question is also posted on another site, here it is:
                                          Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                          I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                          08-25-2025, 10:12 AM
                                        • tec3000
                                          Sony LED 65X9005A shuts down after few seconds - looking for help
                                          by tec3000
                                          Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                          I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                          03-20-2024, 07:29 AM
