Intex Inflatable Spa - Pump Problems
  • mmartell
    • Oct 2013
    • 3189
    These pumps are known to fail. Usually the ceramic shaft holding the impeller breaks and if caught early enough another shaft can be fashioned from stainless or brass. I let mine go a little too long making noise and now after repair my pump has failed again and probably for good. I have not yet disassembled the unit to get to the pump to check for sure so this is a little pre-emptive.
    New pumps cannot be sourced and genuine parts are not available either. I do have on hand another pump of similar size and flow rate (specs on either pump are sketchy!) and if it comes to this I will test it in system to make sure it is a suitable replacement.
    THE PROBLEM:
    The old pump ran off 12v AC the new pump needs 12v DC. What is the best way to make this happen without adding an external power source ? Can I rectify 12v ac to obtain 12v dc or is that way too simple ?
    • 31199
    Re: Intex Inflatable Spa - Pump Problems
    if you rectify it, and smooth it, it will rise to about 15v.
    that may not be an issue - it depends how hot the pump gets.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8327
      If you convert AC to DC you have to multiply your AC voltage by 1.414
      12 x 1.414 = 16.968V DC.
      I don't think it is such a good idea, but I guess we need more details.
        • 31199
        i wonder if it needs to be smoothed - never done much with dc motors.
        • jazzie366
          • May 2016
          • 304
          THE PROBLEM:
          If you were to list how many A the pump needs, you can probably find a dc-dc step down converter, there are plenty of cheap ones on ebay that can handle 30A easily. The only thing you need to do is all a beefy rectifier. Get back to us on this and let us know so we can help you further.
          Popcorn.
            • 31199
            no, actually he may have a speed controller.
            mmartell - is it variable, or just on/off??
            • mmartell
              • Oct 2013
              • 3189
              It's on/off, controlled by a relay. I never shut off the circulation pump anyway - always leave it on, just like the pool pump.
              The specs on either motor are impossible to find.
              Hoping to investigate this further this coming weekend.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8327
                How about you run that DC motor with a external, variable PSU? Some Astron, Samlex or whatever...
                • jazzie366
                  • May 2016
                  • 304
                  You could grab an ammeter (unless you have a clamp style one) and then hook it up to a car battery, and see how much it draws? We're gonna need to know that in order to get a proper setup going.
                  Popcorn.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Was hoping to avoid that.
                    • mmartell
                      • Oct 2013
                      • 3189
                      Can a standard multimeter measure this without burning it up ?
                        • 31199
                        only up to the limit of the meter - usually 10A
                          Can we see the pictures of this replacement DC pump?
                          • mmartell
                            • Oct 2013
                            • 3189
                            Sorry bud I took pics but they need to be resized so let me figure that out first.
                            • mmartell
                              • Oct 2013
                              • 3189
                              Here you are bud - not much to see really.
                                G-EAST
                                Shenzhen Chenzhou Electrical Appliance Co
                                CP50 series
                                CP50-1230A: 12VDC 2.2A
                                BTW, pictures always help.
                                DC Brushless Pump CP50 series g-east
                                ● 12V~24V DC
                                ● Long life, ideal life for 10000 hours
                                ● Durable magnetic rotor and ceramics shaft
                                ● Low or no maintenance
                                ● Submersible or the diving installation
                                ● Low power consumption
                                ● Lift up to 7M
                                ● Flow rate up to 2600L/H;
                                ● Weight:385g
                                ● 0~5V Speed control I wonder if it has this function.
                                How many wires does it have?
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  12 - 24v
                                  Great, so slap together a bridge and have a working spa, OP.
                                  Follow the white rabbit.
                                    • 31199
                                    Originally posted by goontron
                                    12 - 24v
                                    no, 12v only - 24v is a different model.
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      ^ are you sure? The a tilde in the position it's used in the datasheet usually used for X to Y voltage...
                                        • 31199
                                        different model number
                                          ZD-915 vacuum pump motor mount service alert
                                          by sam_sam_sam
                                          If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                          One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                          Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                          The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                          09-19-2021, 02:15 AM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • jean luc ferre
                                          display screen problems after changing motherboard
                                          by jean luc ferre
                                          First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                                          I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                                          Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                                          Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                                          09-11-2025, 10:28 AM
