When I first plugged it in I heard it click then nothing, no standy light or blink code. Now it's not doing anything. I checked most obvious parts with no sign of a short. I'm getting 120VAC thru the fuse, but I am only seeing about 4VAC between the center pins of the rectifier. Not much info out there on this model, any one have any thoughts?
Panasonic TC-32LX85 Dead
Tags: None
Re: Panasonic TC-32LX85 Dead
https://www.badcaps.net/forum/showth...X85#post341781
See the link for the service manual.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Thanks Bud, I found that thread earlier but that file is not there anymore. I did find the SM and uploaded to Tom's SM email on the site, if that email is wrong Tom let me know please.
Here is a screen shot from the schematic, I get 120VAC and 165VDC at D7001, but the large rectifier D7003 is where I get 4VAC and 8VDC.Attached Filesif you find these attachements useful please consider making a small donation to the site
If the relay is not on, you will not get AC feeding the D7003 bridge.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809Comment
OK I see that now. So I'm not getting the 5v standby though I'm getting 1.3V.
Bud that SM you show is a different model, this is the correct one, power supply on pages 36 and 37.
Just disconnected the main board connector and the 5V standby comes up to normal, so a problem on the main board right??Comment
The one in your link matches the chassis?Never stop learning
Well the PS is the same, the main board is a TNPH0757S which is different. Ill have to check the main board # in the other SM.Comment
OK, let me download the one from your link and see what the test points to use.Never stop learning
can you use 10 Ohms resistor as a 1/2A load to see if will maintain 5V?Never stop learning
Is that just a 10 ohms resistor attached to 5VSTBY on the PS side but not to anything else?Comment
I hooked up my bench power supply and set to 5V and connected to STB5V on main board (removed from TV). I'm just a little unsure of the readings on the PS. The current keeps going from 100mA up to about 400mA and then repeats, is that going into protect from overload?
While it's on I checked the voltages on the DC-DC and got 3.3V and 1.8V from the 2 regulators, so they seem to be working normally.
Does the PS fluctuating current indicate a problem? What should I expect to see for a load? Any tips from here?
Could this still be a problem with the PS? I wasn't clear on how to test with a load on it.Attached Filesif you find these attachements useful please consider making a small donation to the site
400mA sounds ok for a standby rail, at least to start. How much current can your power supply provide? Did you try testing the PSU board like budm suggested, using the resistor?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Its a 30V 5A power supply. Should it be fluctuating like that though from 100mA to 400+ and then back down, it may be going higher but happening too fast to see.
No I didn't try the resistor I don't know what to, just solder one end of it to the STB5V pin without the main board connected? The other end of the resistor is open? I have a 100 ohm resistor handy will that work?Last edited by kevinm34232; 10-04-2014, 12:55 PM.Comment
What will a resistor do if the other end is open...? You need to connect it to ground. The resistor is load for the PSU, it will get hot. It needs to be around 10 ohms, 5W rated.
Make sure you've set the current limit on your power supply up from the default.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Ok thanks I found one in an old Y-SUS board.
For this test I'll be plugging the TV into AC without the main board connected, and checking the standby voltage correct?Comment
Yep. That's correct, this seems to indicate the PSU cannot supply 500mA load, so I would consider it may be faulty.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Well that saved me a lot of time thanks for that process and thanks Bud for suggesting it.
This is the first time I've run into this problem, is there something in general that would cause it to drop under load?Comment
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
by badcappoHello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
Diode type G972s6 - D101 with a short
Mosfet 06N90E - Q301 shorted
Fuse T5AH 250V - F103 blown
Diode D301 shorted
Relay DG1U-17VDC II - RL001 blown
I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check π... -
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπ€?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting π.
...1 Photo11-20-2024, 08:52 PM -
by Super360Hi everyone I have a plasma here that is absolutely dead no power light. When I press the power button the relays click the fan spins for a second then it's dead and nothing happens on the screen. Anyone have any suggestions?
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... - Loading...
- No more items.
