Cheap ESR meters on fleaBay, what do you think?
  • withalligators
    • Jun 2013
    • 267
    Hey guys, what do you think of all the cheap ESR type meters on ebay from China? The ones that look like a hobby board with an LCD screen soldered on there for like 15 bucks shipped. I need a meter for testing caps, but not enough to want to buy anything significant if I can get away with a cheapo unit.
    If not those, can anyone suggest something decent?
    Cheers,
    Alex
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Cheap ESR meters on fleaBay, what do you think?
    I got one similar but cost about $24
    http://www.amazon.com/gp/product/B00D6BNDWM
    It works fine for what I need and it's very useful for me. I soldered some curved wires to connect alligator test leads to so I don't have to fuss with the little pin jacks and that helps. It's a little clumsy not being in a box but it's useable.
      • 31283
      that's the old design.
      i think he meant these:
      http://www.ebay.co.uk/itm/251581148174
      or these:
      http://www.ebay.co.uk/itm/251471851226
      they look good - i plan to get one.
      they do sell them cased btw.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        Yeah, those look nice. If I didn't already have the one I have I'd want one of those too.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Ive got the same one as you have steve does the job ok for me.
          • jetadm123
            • 2169
            Just curious, but on their specs page, they list the capacitance range of 30pf-100mf. Is the 100mf their way of stating 100uf?
              • 31283
              i think it is.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                yes, a good example is valve radio diagrams where you will find caps marked as mf instead of uf.
                Follow the white rabbit.
                • jetadm123
                  • 2169
                  Interesting.... I looked a little more closely at the links stj posted and in one of the photos the cap measured at 408uf. Not bad if the ESR meter is rated at 100uf!
                    • 31283
                    100uf is probably an error because it's way to low to be practical.
                    10,000uf would be more likely.
                    • ReverendJones
                      Resurgam
                      • May 2010
                      • 49
                      1 mf = 1000 uf
                      100 mf = 0.1 farad
                      Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
                      • withalligators
                        • Jun 2013
                        • 267
                        coolio. ordering one. tired of replacing every single cap on a board just cause.
                        Thanks guys.
                          • 31283
                          search sellers other items - get the one in a case for a few $ more.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            You do realize that in order to get a reliable reading, you have to desolder the caps off the board (or lift one leg) in case they are in parallel (or possibly affected by some other components in circuit)??
                            --- begin sig file ---
                            --- end sig file ---
                            • predator0357
                              • Jul 2014
                              • 159
                              • Israel
                              What do u think about this ESR meter?
                              http://www.ebay.com/itm/Big-LCD-Tran...-/181164691633
                                • 31283
                                same as my links - just more expensive.
                                there are 2 styles of that meter, big display and compact display.
                                and you can get it in a case.
                                and there are several sellers - do some searching before you buy.
                                • predator0357
                                  • Jul 2014
                                  • 159
                                  • Israel
                                  Its the same as yours the second one and cost the same
                                  But do u know if its good?
                                  Cuz i checked the feedback and all say good things about it.
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    Nobody knows if those new big screen ones are good - no-one has one.
                                    • predator0357
                                      • Jul 2014
                                      • 159
                                      • Israel
                                      Hey,
                                      If i desolder the wire of the 9[V] jack and put there a 9[V] 200[mA] power supply like this one it will work fine yes?
                                      http://www.ebay.com/itm/AC-Converter...-/221232824063
                                        • 31283
                                        i will be getting the compact one, because the big one is not avalable in the case.
                                        i think the display is the only difference though.
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • eccerr0r
                                          Caseless Cheap Chinese electronic tools
                                          by eccerr0r
                                          "Caseless Cheap Chinese electronic tools" I mean things you get from banggood, ali, fleabay, Am-Zon, etc. like AVR-Transistortester, miscellaneous signal generators, frequency counters, (variable) power supplies, oscilloscopes, low resistance meters, etc., etc. that comes optionally with a case, or comes only with a cheap piece of plastic that barely provides protection to the PCB.
                                          Just wondering what of these (generally flimsy) tools you actually find use (almost) everyday and find indispensable for the price, compared to buying a Fluke or whatnot, if there is an expensive...
                                          11-23-2021, 03:44 PM
                                        • evilkitty
                                          When your mom is complaining about her new cheap lights
                                          by evilkitty
                                          My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                          well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                          lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                          07-23-2024, 01:27 PM
                                        • aaronkatrini
                                          by aaronkatrini
                                          - Autorange
                                          - DC volts up to 30V
                                          - Accurate Resistance
                                          - Diode test (Beep mode)
                                          - Frequency up to 200MHz
                                          - Capacitanze up to 5000uF
                                          - as cheap as possible
                                          05-06-2024, 09:54 AM
                                        • Dan81
                                          The Cheap Duo - Two SiS machines
                                          by Dan81
                                          Just as the title states. Two cheap SiS machines, surprisingly stable.
                                          What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                          The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                          CPU - P3 1100MHz Coppermine...
                                          04-16-2022, 12:28 PM
