Caseless Cheap Chinese electronic tools
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    "Caseless Cheap Chinese electronic tools" I mean things you get from banggood, ali, fleabay, Am-Zon, etc. like AVR-Transistortester, miscellaneous signal generators, frequency counters, (variable) power supplies, oscilloscopes, low resistance meters, etc., etc. that comes optionally with a case, or comes only with a cheap piece of plastic that barely provides protection to the PCB.
    Just wondering what of these (generally flimsy) tools you actually find use (almost) everyday and find indispensable for the price, compared to buying a Fluke or whatnot, if there is an expensive option.
    Must be more than just these listed here... Any other neat gadgets found that meet and even exceed expectations?
    Don't include things like relay boards, raspberry pi hats, amplifier boards (unless it has a specific use), fixed voltage power supplies including soldering iron controllers, etc. - don't include things that weren't meant to be a standalone tool.
    I just find my AVRTransistortester of somewhat limited use. As threadjacked in the other thread, it's cute and fun to play with, but doesn't completely fit my style I suppose. Seeing if there are more interesting stuff out there...
    • 31063
    Re: Caseless Cheap Chinese electronic tools
    most used is my component tester,
    then my usb-serial(3.3v) adapter,
    then probably my €12 8digit frequency counter!!!
    i also have a fully programable pwm generator - but that dont count because it is partially cased like a panel-mounted part
      • Jul 2011
      • 6040
      Can you please post a picture of what you are talking about cheap plastic enclosure and the other thing that you also talking about
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Well I'll put it this way, if you can buy it without an enclosure, it counts.
        I've seen some devices come with acrylic or just slabs of plastic to cover the PCB on both sides using standoffs but debris could easily fall in the sides - like https:// www.ebay.com /itm/294448317833 - it has "case" but not really (spaces added to prevent "seo").
          • Jul 2011
          • 6040
          I would not call this and enclosure I would call this a ( faceplate and a backplate ) which only protects the face and the circuit from directly being shorted but not from what you have decried and I do not think that you can really call them enclosures
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Correct, I classify these as "caseless" because they are crap cases, and are qualified...
            Just want to ignore the devices that have actual full cases or rather, cannot be purchased without a case at all.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Oh man, is that it? AVRTransistorTester is the only tool to have?
              I guess I should someday get another frequency counter else i need to upgrade the one I have, need to jury rig some decade counters and get a few 7447's...
                • 31063
                my counter goes to 2.4GHz
                the tools you buy will be dictated by what your doing.
                my usb-serial convertor is mostly for flashing routers.
                my frequency counter is for checking radio's
                my pwm generator was for checking fans - but it never got to see any because people stopped scrapping modern desktop pc's
                you could also check servo's with it, but i dont deal in RC stuff
                • clearchris
                  New Cheap Chinese Soldering Plates
                  by clearchris
                  I was browsing on ali, and I'm seeing a bunch of these super cheap soldering hot plates. I was going to make one, but it's really hard to justify DIY when you can buy a plate for under $10.
                  Most look pretty functional, one looks like it needs to have the plate flipped, and they could all stand to be countersunk and swap the screws for flat head ones. Would be nearly trivial to install an arduino, thermocouple and ssd for fine control.
                  https://www.aliexpress.com/item/1005003127491986.html
                  https://www.aliexpress.com/item/1005001445767919.html
                  https:/...
                  10-29-2021, 11:27 AM
                • evilkitty
                  Tools and supply reconndations
                  by evilkitty
                  Is this still a/the recommend iron?
                  https://www.amazon.com/KSGER-Tempera.../dp/B07PYFSCJ9
                  *For use at a desk w/ cheap replacement tips available (if i need to get brand names ones for a specific use that is fine)
                  i would like something good for SMD parts on boards (not messing with BGA comments)
                  a tip recommendations would be nice
                  where should i get some flux and low melt solder from?
                  other tool recommendations?
                  Other tools i have or ordered:
                  ZD-915 de-soldering gun
                  Atten ST-862D...
                  11-21-2024, 02:59 PM
                • blero
                  Repairing cheap chinese Led bulbs
                  by blero
                  I'd like to try to repair these corncob shaped chinese bulbs with tens of Leds on them.
                  I know they're bad quality and fail fast, because of the Leds or the capacitor(s).
                  So I plan to try to replace the main capacitor 15uF-400V with a good quality one.
                  I've used in the past some capacitors of this eBay vendor which is well known on this site: egekecu. I'm still daily using a monitor I repaired with his products.
                  I know it has been said he sells good and real brands but outdated capacitors. He's actually 3 times cheaper than RS-Online...
                  01-31-2021, 07:06 PM
                • valente222
                  help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                  by valente222
                  Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                  05-12-2025, 03:42 PM
                • Hexram
                  Tools - Order of purchase
                  by Hexram
                  Hey guys,
                  I am new to the electronics repair game & have stumbled into some tools to get my workshop (garage) started.
                  I managed to get my hands on a low budget multi-meter, soldering iron, de-soldering gun, oscilloscope and a variable voltage/amperage DC power supply.
                  With this being a new hobby i am thinking of investing in some tools to make it a little easier.
                  When i get paid next i was thinking of buying a Peak Atlas ESR 70 gold.
                  I am after suggestions on what order to buy things because i don't have the money...
                  04-24-2023, 04:03 AM
