Sharp LC-32D59U - Need Fuse Part number.
  • jstiene
    • Feb 2013
    • 148
    Hello. I have a Sharp LC-32D59U that is completely dead. No standby,etc. Found out that all 4 fuses are open. Assume it was hit by a surge. They are little square fuses. 250V/5A. I am trying to determine a part number to order these and they are odd sized. Does anyone have any part numbers for these? I found some previous threads where budm provided manuals,etc but I could not find a part listing.
    Thanks!
    Re: Sharp LC-32D59U - Need Fuse Part number.
    Can you show the pictures of the fuses?
    • jstiene
      • Feb 2013
      • 148
      Hi Budm,
      Sorry about that. Forgot to uploads the pictures. Here you go .
      • R_J
        • Jun 2012
        • 9627
        T5A 250V 392 series Square Type Radial Leads Miniature Micro Fuse
        also check that VZ801 VZ803 VZ804 and VZ805 are not shorted,
        • bammbammfran
          • Apr 2014
          • 476
          digikey.com
          pn: WK6333-ND
          • jstiene
            • Feb 2013
            • 148
            Thanks for all the responses. It is much appreciated. I did check VZ801 VZ803 and VZ805 and no shorts are present. I guess all the fuses blew and there doesn't seem to be any other damaged. Check all obvious diodes..etc.
            • Ow5856ba
              • May 2014
              • 3
              Did replacing fuses fix problem
              • jstiene
                • Feb 2013
                • 148
                Ow5856ba,
                replaced all 4 fuses and poof the moment I plugged in the AC. All other components seem to test good. I am obviously missing something. Has anyone else worked on this particular model?
                  Need straight shot pictures of both sides of the board so I can trace out the connections on the bottom side.
                  • R_J
                    • Jun 2012
                    • 9627
                    Here is the ac input and part power supply
                    • jstiene
                      • Feb 2013
                      • 148
                      Hi Budm,
                      Here are the pictures.
                        So what resistance do you get when measure between the two inner pins of the bridge rectifier? The resistance be tween the two outer pins of the rectifier?
                        • chrismurphy
                          • May 2014
                          • 251
                          • australia
                          Replace board ,i suspect the board has too many faults on it
                          • jstiene
                            • Feb 2013
                            • 148
                            Budm, I wasnt sure which were correct so I did two readings:
                            outer pins - .9 ohms on 200 ohm setting / 0.0 on 20K setting
                            inner pins - Inifnite on 200ohms / 4.79ohms on 20k setting
                              OK, you do have shorted circuit, so remove the bridge and take the reading on the same place (the pads on the circuit board where the legs of the bridge are attached to) as before to see if the shorts still present.
                                Well, we will not know until we look further.
                                • jstiene
                                  • Feb 2013
                                  • 148
                                  Hi Budm,
                                  So here are my updates.
                                  1st off - only Fuses F802 and F804 are shorted. F801 & F803 did not shorrt out (yet)
                                  Removed rectifier and there is a short across outer pads. All readings remained on the same on the pads. Recitfier does not seem to have short across outer pins.
                                  Removed Diode D802 and verified it as shorted.
                                  with diode removed, there is a momentary short across diode pads. Short still remains across outer rectifier pads.
                                  Then removed C808 as it showed shorted in circuit. C808 tested good, and with one end removed from circuit, short still remains.
                                  So currently, recitifier, diode and capacitor all all out of circuit at this time. Short remains.
                                  I followed traces and must be missing something that is shorted...any suggestions where to look next?
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    Not sure about Fuses being shorted? If you mean they show a resistance near to zero ohms end to end then they are good. If not they are bad/open
                                    It would probably be better if instead of saying something is shorted to state
                                    the resistance in ohms.
                                    • R_J
                                      • Jun 2012
                                      • 9627
                                      Have you checked Q801 yet? I uploaded the part of the schematic that should make it easy to find the shorted component. I also see some very bad soler connections (circled) that may have been the source of the failure.
                                      • instarep
                                        • Jul 2014
                                        • 28
                                        Using your square fuse picture i saw a part of my actual problem. In upper left corner there's a fuse made of glass with both end in red. I figured out those were kind of circuit protection and i have 1 out of 5 in my Sharp Aquos that is open. Part in my LC-32D43U is SG7006. Can someone help me find this part and value?
                                        thanks in advance!
                                          Surface Mount Fuses Fundamentals Datasheet
                                          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                          10-07-2024, 06:07 AM
                                          TF-FUSE Thin Film Surface Mount Fuses (Very Fast Acting), 0603 Size Datasheet
                                          FF Series (Very Fast Acting), 0603 Size
                                          Features
                                          ● Very fast acting at 200% overload current levels
                                          ● Low DCR
                                          ● High inrush current withstanding capability
                                          ● Fiberglass enforced epoxy fuse body
                                          ● Copper termination with nickel and tin plating
                                          ● Halogen free, RoHS compliance and lead-free
                                          Applications
                                          ● Notebook computers and tablets
                                          ● Digital cameras
                                          ● Memory cards
                                          ● Toys
                                          ● Bluetooth earphones
                                          ● Portable electronic devices​...
                                          10-07-2024, 05:50 AM
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • G-Sting
                                          iPad Pro A1876 SHORT Part Identify Help Needed
                                          by G-Sting
                                          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                          SO My main concern is what part should i order what should i search the name for ?
                                          on Ipad...
                                          05-15-2025, 09:30 AM
                                        • eidam655
                                          GPU 1206 SMD fuse markings & replacement fuses
                                          by eidam655
                                          I need to replace a fuse on one of the graphics cards I am working on. It is a 1206 SMD fuse, white in color and has a "10" written in a blue rectangle on it.
                                          How do I find a suitable replacement? What is the general rule to identifying fuses' parameters? I found something in an eshop near me (see photo) but am very hesitant to use this as a replacement....
                                          04-14-2022, 12:46 AM
