Sylvania LC320SS9 Flashing Green LED
  • Mr Bill
    • Nov 2011
    • 648
    A friend of mine pulled this tv from a dumpster. When you turn it on the green led flashes then goes back to standby. I pulled every cap and checked the capacitance and esr and all are below 1 ohm. Only the 10uf and smaller caps were higher (1-2 ohm). Then we started checking diodes and 3 that are right above the transformer were shorted out (0.001), this is in and out of circuit. The numbers on the diode were 867-15. Pulled a datasheet and it states its a high voltage schottky barrier diode (3 amp). On an impulse he went to radio shack and picked up 3 (3 amp) diodes and we soldered them in. The tv did come to life but for only 10 seconds. The 3 radio shack diodes are now shorted out.
    So now i'm trying to find the correct replacement from digi key and mouser and i'm not feeling real comfortable that i'm finding the correct replacement. And, is there anything that could cause the diode to blow other than the radio shack one wasn't rated for the job? I uploaded the datasheet for quick reference.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Sylvania LC320SS9 Flashing Green LED
    In the datasheet it says "super high speed switching". Afaik, Radio Shack doesn't sell special diodes like that, only general purpose parts suitable for rectifying mains and not more than that.
    The datasheet is pretty scarce, it does say high speed switching but doesn't mention reverse recovery time, a lot of stuff is missing... Anyway, i did a parametric search at digikey and this is the only diode i came up with that is in stock and you can buy in quantities of 1. It's a schottky but it should work just fine, it matches the original in all aspects. http://search.digikey.com/us/en/prod...16-1-ND/654568
    A working TV? How boring!
      Ugh. That looks awful for a power supply. It looks like the three diodes are in parallel. Great way to encourage thermal runaway. And those tiny heatsinks. It's clearly built worse than a Vestel, I thought I would never say that but it is. If you fix it, it would be highly advisable to make the heatsinks bigger, or add a fan to cool it. I can't imagine any of these cheap sets living past 2-3 years.
      • Mr Bill
        • Nov 2011
        • 648
        Tom do you think thermal runaway would be a likely cause for the 3 original diodes to have failed?
          Highly likely. But you can check for shorts. After removing the diodes, check the cathode end to case ground. Should be high resistance.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            Just by the way... The insides of this thing look one heck of a lot like a 22" (1680x1050) Funai LCD TV I dumped about a year back
            That one had a cracked panel, and the T-CON was part of the mainboard, with 2 flex cables going to the panel. No replacement LCDs available anywhere, and you couldn't mount a standard 22" PC monitor LCD because of the T-CON being part of the mainboard..
            Made to be thrown away..
            Mine had a massive hackjob in the PSU. There were single diodes like in yours scattered all over the place in the PSU, but they each had another identical diode tacked in (soldered to their legs).
            No idea if that was a desperate repair attempt from before I got it or if it came like that from the factory... either way..:
              Well Funai makes FUNAI, EMERSON, and SYLVANIA TV's. It bought the rights to use these AMERICAN name TV's brands a long time ago.
              http://www.funai.us/brand/index.html
              Schottky Didoe has low Vf and fast recovering time (tR) for switching power supply, regular diode will burn up fast.
              • heavymachines
                • Mar 2011
                • 1028
                hi all this i have same tv with same problem and yes its horrible design, however has anyone fixed this set? i am willing to give this one a shot if anyone is willing to try to troubleshoot this beast lol, thanks any help would be great. looks like this thread is dead but before i start new one i figured this thread is appropriate considering i have one with exact symptom not trying to hijack it but if i need to start a new one i will.... Thanks for any help or reply's..
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  You already have the location of the diodes, check them for shorts. If they're shorted, replace, and see if that fixes it.
                  • heavymachines
                    • Mar 2011
                    • 1028
                    not shorted tested out of circuit reads one way and not the other way when i switch the leads on dmm on diode test.... Thanks for your reply that was quick, well what to do next on this odd ball tv?.
                    • Mr Bill
                      • Nov 2011
                      • 648
                      what is it doing? This tv the led was flashing for about 10 seconds then the tv went to standby. I had and emerson EM9 that the led would flash very fast continuously.
                      • heavymachines
                        • Mar 2011
                        • 1028
                        Same exact model symptom is almost identical, power led flashes rapidly for 10 seconds it will display digital television on bottom for a brief second then kicks to standby and just before standby i get 2 brief quick flashes....
                        • Mr Bill
                          • Nov 2011
                          • 648
                          a bad inverter transformer on the power board can cause this symptom. Check the resistance readings at the ccfl plug with your multimeter in the OHMS setting. There was a thread within the last couple of days and a cracked solder joint was at fault too.
                          • heavymachines
                            • Mar 2011
                            • 1028
                            sorry i am lil green at this, however i am fully capable to learn, anyways where do i stick the probes and my dmm has lots of ohm settings, and where would i stick red and black probes so far i get no readings at 200ohm setting, Again thanks for helping me here.....
                            • Mr Bill
                              • Nov 2011
                              • 648
                              You would put your red and black probes on the 2 pins at the connector. The reading is going to be higher than 2k ohms. I think it'll be in 9k range. Does your meter have a 20k range?
                              • Mr Bill
                                • Nov 2011
                                • 648
                                I just checked my spare board and it's higher than 9k. Put your meter in the highest OHM setting it has.
                                • heavymachines
                                  • Mar 2011
                                  • 1028
                                  yes it does..
                                  • heavymachines
                                    • Mar 2011
                                    • 1028
                                    that would be 200 ohm highest setting. I am sure i did that, and it reads nothing but will double check in the morning when i go into work where the set is....
                                    • heavymachines
                                      • Mar 2011
                                      • 1028
                                      ok on 200 ohm setting its reads nothing i tried all ohm settings and can only get a reading if i set my dmm to 20m ohm and there it reads 5.3 m ohms at the bulb output connectors sorry took so long to reply got tied up with some things....computers and more computers anyways made some time...again thanks for you help, any ideas?
                                      • Mr Bill
                                        • Nov 2011
                                        • 648
                                        Do all the transformers read 5.3 Mohm with your meter set to 20M?
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • STKR123
                                          Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                          by STKR123
                                          As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                          I wonder if re-flashing the BIOS might be of any use here.
                                          As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                          There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                          11-03-2024, 06:58 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • beetle1303
                                          Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
                                          by beetle1303
                                          Sharp TV flashing green light 2x per second at constant rate. Various reset methods do not have any effect on it. Search here and found flashing green 2x per second indicate bad power supply, which I am quite certain now.
                                          I am seeking help with basic trouble shooting to find the short-circuit on the secondary side that I believe is the cause:
                                          The main PD connector:
                                          PD-1 (PNL12V) : 0.02V
                                          PD-2 (PNL12V) : 0.02V (fluctuating)
                                          PD-3 (SGRN) : 0V
                                          PD-4 (SGRN) : 0V
                                          PD-5 (UR13.2V) : 0.05V (fluctuating)
                                          PD-6 (UR13.2V) : 0.05V (fluctuating)...
                                          04-19-2022, 09:26 AM
                                        • jimjoe123
                                          LCD TV Green/Pink screen problem
                                          by jimjoe123
                                          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                          Then each time...
                                          02-23-2020, 01:29 AM
