Samsung LN46C630 Thin Vertical Lines on entire screen
  • twilliard
    • Aug 2014
    • 29
    • US
    Samsung LN46C630 has Thin Vertical Lines on entire screen.
    Checked connections looked ok
    anyone seen this before?
    Attached photos of problem
    Thank You for your Time
    Happy New Year!!
  • mmartell
    • Oct 2013
    • 3189
    Re: Samsung LN46C630 Thin Vertical Lines on entire screen
    Looks like a bad main board to me. Try to heat up the main processor on it with a hair dryer to see if it improves.
    • twilliard
      • Aug 2014
      • 29
      • US
      No Change
      • sordids999
        • May 2013
        • 2161
        • uk
        Pictures of the boards ? Have u tried gently pressing on the processor with the end of a insulated screwdriver could be a bad panel though ?
        • twilliard
          • Aug 2014
          • 29
          • US
          Attached Board Photos
          • twilliard
            • Aug 2014
            • 29
            • US
            Pressing and tapping on main board did make a change Lines, some times they disappeared and came back, they are not there now, but if I tap again its back
            • sordids999
              • May 2013
              • 2161
              • uk
              Proberly a bad bga like the 46 samsung that I had
              • twilliard
                • Aug 2014
                • 29
                • US
                Is there away to repair this?
                Thank You for your help
                • mmartell
                  • Oct 2013
                  • 3189
                  Did you try heating other areas of the main board ? Perhaps the processor is not the problem.
                  • sordids999
                    • May 2013
                    • 2161
                    • uk
                    it might not be the bga but i remember i bought a tv off this guy with picture problems once i opened it up he glued 2 pence pieces onto the heat pads to apply more pressure when the cover went back on
                    • nates90
                      • Jan 2015
                      • 1
                      My LN46C630k1FXZA Version: AA02 has the same problems, sometimes when I unplug the HDMI cable and plug it back in, it will fix the lines for a little while. I have been looking on the net for Main Boards and found that it takes a BN94-02701J, but you cant find those anywhere. It looks like they make a substitute board BN94-04564A. I was just wondering if these lines are the main board, or a different board.
                        By accessing the service menu you can activate separate main board and T-con board test patterns. Put the TV in standby, then on the remote press in succession Mute, 1, 8, 2 followed by Power. When the TV powers on the service menu should appear.
                        • twilliard
                          • Aug 2014
                          • 29
                          • US
                          After reading about REFLOW I decided to give it a try
                          Placed spacers under board to keep it off the pan
                          Placed pan and board into oven
                          Checked to make sure the board was level
                          Turned the oven and heated it up to 300°F, once at 300°F stay at that Temp for 1 minute
                          Then up to 350°F, once at 350°F stay at that Temp for 1 minute
                          Then up to 390°F, once at 390°F stay at that Temp for 1 minute
                          Then up to 450°F, Once at 450°F, stay at that Temp for 5 minute
                          Then Turned off Oven,
                          I Did NOT MOVE UNTIL IT COOLED DOWN
                          Put back into TV now it's working Fine now( For how long , who knows)
                            It did not deform the plastic parts on the board at 450?
                            Please let us know too how this TV works out for how long.
                            • twilliard
                              • Aug 2014
                              • 29
                              • US
                              Note: I Covered all plastic components with aluminum foil
                              TV Been on for Hrs. Still OK
                              • twilliard
                                • Aug 2014
                                • 29
                                • US
                                No deformity of the plastic parts
                                Note: I Covered all plastic components with aluminum foil.
                                The board did change in color slightly from the heat.
                                • jose6326
                                  • May 2013
                                  • 707
                                  You should of posted pics of your reflow procedure
                                  Glad it worked
                                  • SergeyR
                                    • Feb 2015
                                    • 10
                                    Ouch! I have same exact problem. I will try to upload a pic or maybe make a video soon.
                                    I already disconnected a cable between PS and Main, then turned TV and I saw a backlight which was steady (no flickering). Then I connected that cable, but disconnected a cable between Main and T-Con. Same thing - backlight was steady.
                                    I will now connect that cable back and will turn TV on and I want to load test picture. then I'm going to make photos and possibly a video.
                                    • SergeyR
                                      • Feb 2015
                                      • 10
                                      Here are some pics showing the the problem with my LN46C630.
                                      When I turn on TV everything is OK for a several minutes. Then after it warms up first I see some flickering then I see vertical lines.
                                      Also when a test picture turns off you can see that "no signal" message doesn't properly moves on the screen. There is a lag.
                                      2 pics show how everything looks like BEFORE my TV warms up and another 2 pics show the problem AFTER it warms up.
                                      I also made a small video and will start uploading it to YouTube right away.
                                        That looks like tab bonding issue.
                                        What happen if you try flexing the panel?
                                        • Falki
                                          Colorful LCD Vertical Lines on Samsung ue55es8090
                                          by Falki
                                          Hello there, ive recently found an older 55inch Samsung SmartTV.
                                          Sadly it has vertical lines at the left and one line in the middle-right.
                                          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                                          I have factory resetted the TV as well but also with no luck.
                                          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                                          A similar issue has been posted as well but also with no actual response ...
                                          08-12-2025, 04:19 AM
                                        • Stanley1843
                                          Screen Display Vertical Multicolor Lines
                                          by Stanley1843
                                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                          06-29-2024, 11:54 AM
                                        • pni
                                          LG 49uf695v vertical coloured lines
                                          by pni
                                          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                          11-14-2025, 03:15 AM
                                        • x_orange90_x
                                          Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                          by x_orange90_x
                                          I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                          The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                          09-04-2023, 12:09 PM
                                        • polaro
                                          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                          by polaro
                                          Greetings,
                                          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                          08-27-2022, 08:46 AM
