Led backlight tester is it worth getting ?
  • comptek
    • Aug 2013
    • 606
    • uk
    https://www.youtube.com/watch?v=EiyoxcP6uWI
    Safe to use cant get a shock off it either
    ebay >>>>
    http://www.ebay.co.uk/itm/0-300V-Out...MAAOSwubRXKb39
    Re: Led backlight tester is it worth getting ?
    Looks interesting, probably cheaper than trying to build one yourself.
    • comptek
      • Aug 2013
      • 606
      • uk
      prob lol
      it seems to adjust from strips to single led's and you can test them without stripping the screen down im seriously thinking of getting one
      • SLK001
        • May 2014
        • 264
        It looks like it slowly increases voltage until a set current is reached, probably 80 to 100mA. If you are testing a single LED, the current will be reached at low voltages. If you are testing a string, the current will be reached at much higher voltages.
        • chrismurphy
          • May 2014
          • 251
          • australia
          Yes if you service many TV's
          Brought one 1 month ago
          Works brilliantly and have tested many sets , voltage goes down to the working voltage when the LED strips when they are good , otherwise it stays high . Fantastic unit saves so much time diagnosing backlight issues
          • comptek
            • Aug 2013
            • 606
            • uk
            im going to order one i have been thinking about it for weeks now lol
            cheers !
            • flocko
              • Nov 2012
              • 1121
              • uk
              sorry dont see the point/ will only show if a string is working or not,if its not you going to strip the set anyway . It does no more than you can do with your meter and the power board that is fitted in the set? just more kit you do not need
              • diif
                • Feb 2014
                • 6978
                • England
                Even cheaper here, if you already have test probes.
                http://www.aliexpress.com/item/High-...663222550.html
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Dont be lazy and use your DMM like I do lol if not start a build project for a variable Psu
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    A good stock of 9v batteries for cost and ease of use is all you need.and allways a replacement at hand when your meter starts to give you odd readings as the battery dies
                    • comptek
                      • Aug 2013
                      • 606
                      • uk
                      oh guys but i like it
                        • 31288
                        you can never have too much chinese test gear.
                        i just ordered one of these for checking crystal circuits
                        http://www.ebay.co.uk/itm/181573121672
                        • Pragmatiko
                          • Jul 2013
                          • 468
                          • IT
                          i have it, and it's very very good.
                          • zomi
                            • Nov 2011
                            • 511
                            Thanks for the link
                            ordered one will save some time.
                            • comptek
                              • Aug 2013
                              • 606
                              • uk
                              Originally posted by zomi
                              Thanks for the link
                              you are very welcome
                              • comptek
                                • Aug 2013
                                • 606
                                • uk
                                are Aliexpress trust worthy ? dont like doing by card id rather do paypal
                                  • 31288
                                  no different to ebay - your dealing with an end seller *through* aliexpress
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    I've ordered no end of stuff from Aliexpress.
                                    I've ordered approximately 130+ items over the last 3 years and have had three issues. Once a part didn't arrive, once they sent 100 wrong micro USB sockets and some mosfets didn't turn up. Each time i politely emailed and was either refunded, sent the correct parts and allowed to keep the wrong ones and the mosfets were resent.
                                    I bought my BGA rework machine from Aliexpress, some of the bigger stuff i've found is already in the UK so there was no import duty and it arrived in 2 days.
                                    You are covered by the Aliexpress guarantee and sellers are rated like ebay.
                                    If I want something now I buy off eBay, if I can wait I get it from Aliexpress which is where most of the eBay sellers buy their stuff more anyway I'm guessing.
                                    That tester you liked too is about £14 cheaper buying from Aliexpress.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      The one I ordered has arrived and I have had an opportunity to test it out. I agree that you don't need it but as a quick method of checking I'm happy with my purchase. Just another piece of kit in my toolbox.
                                      • SLK001
                                        • May 2014
                                        • 264
                                        Dick,
                                        Tell us where the voltage starts when testing. I assumed that it started low and increased the voltage until a set current was reached. A poster in this thread said that it did the opposite - started high and went low. I figured that that way would pop many a single diode.
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
                                        • gabrielA7
                                          Macbook pro A1706 / Backlight flex cable compatibility
                                          by gabrielA7
                                          Hey guys!!
                                          I’ve got a question here!
                                          I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                                          Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                                          Here’s what the bot told me:
                                          I said to him: “I’m going to install the 821-01229-A.”
                                          ChatGPT replied:
                                          Understood — but before you solder or install the 821-01229-A,
                                          11-11-2025, 03:26 PM
