Led backlight tester is it worth getting ?
  • victor_cj
    • May 2015
    • 90
    Re: Led backlight tester is it worth getting ?
    G2J2C LED TV Backlight Tester open circuit voltage, it starts with 176V and ends with 300V:
    https://youtu.be/5wBlcSJjGKo
    G2J2C LED TV Backlight Tester in circuit voltage with an LED connected:
    https://youtu.be/8u_F73qdGK8
    The art of fighting without fighting
    • chrismurphy
      • May 2014
      • 251
      • australia
      It starts at 295v approx and when the leds conduct it reduces to the running voltage approx ,current slowly increases as does the brightness of the led or leds
      • victor_cj
        • May 2015
        • 90
        GJ2C LED TV Backlight Tester
        https://www.youtube.com/watch?v=vroEf_GtIow
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
        • canadaboy25
          LG Flatron 24EN33TA No Backlight When Cold
          by canadaboy25
          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
          03-07-2023, 12:23 AM
        • gabrielA7
          Macbook pro A1706 / Backlight flex cable compatibility
          by gabrielA7
          Hey guys!!
          I’ve got a question here!
          I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
          Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
          Here’s what the bot told me:
          I said to him: “I’m going to install the 821-01229-A.”
          ChatGPT replied:
          Understood — but before you solder or install the 821-01229-A,
          11-11-2025, 03:26 PM
