The "Indestructible iMac" v2.0 - Poly revision 2
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: The "Indestructible iMac" v2.0 - Poly revision 2
    Originally posted by shovenose
    so i can use mobo-grade caps in a psu with using lower-capacity as well? cool!
    Not really. The output caps of a PSUs are in series with a toroid or coil more often than not - basically they form a LRC circuit. Changing the capacitance and ESR can significantly change the operation of this circuit (i.e. resulting in more ripple), so generally polymer and motherboard-grade capacitors are not recommended for PSUs.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Agreed. You can get away with it sometimes, but its not recommended. I've never tried polymodding a psu, just because the ESR is so low, atleast on the motherboard-grade polies I have in stock.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        ploys are in use in some more expensive psus. is there such thing as a psu-grade poly?
        • yyonline
          • Jul 2009
          • 692
          I've seen Chemicon PSA in some Seasonic PSUs. So, that's the same polymer I see used on many motherboards. So...that points to no. I'd bet that the PSU was designed with polymers in mind. So my guess here is that the PSU design probably has more to do with it than the exact type of polymer caps used.
          • seanc
            • Nov 2008
            • 1319
            Aye, there's one in my Seasonic S12-II 500w PSU. It shares the same layout as the Antec EA-380 - which doesn't have any polymer. They must have adjusted other components accordingly.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              is it true if you use a ploymer in a psu it willshort out and explode?
              • seanc
                • Nov 2008
                • 1319
                #27
                Considering mine has been working fine for 2 years and came from the factory this way...
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  Usually those power supply's output filter are designed around solid caps. They are usually found after the coils where they can actually help reduce ripple a bit. They are used on the DC-DC VRM cards in power supplies that use them as they work out much better there.
                  I believe there was a AcBel psu made for Gigabyte that used all solid caps on the output. It had high ripple and poor transient response.
                  I still want to find out if those cheap psu's with no pi-filters would benefit from using ULESR caps.
                  • Logistics
                    • Apr 2007
                    • 721
                    Ah, HAH! So I made a wise decision in ordering the LG's. I was a bit confused because in my Digi-Key catalog the Nichicon LG is not categorized as a polymer capacitor, nor does their catalog describe it as one, but the ACTUAL Nichicon datasheets say it is a polymer so I ordered them, anyway.
                    *sigh of relief*
                    Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      FWIW I still have the 17" I was sent to test... It sees almost no use though thanks to shoddy PPC software support. It still runs well.
                      sigpic
                      (Insert witty quote here)
                      • godonr
                        • May 2009
                        • 111
                        #31
                        Too bad progress made these obsolete. We've sent several hundred to the grinder. They still make a great first computer for kids! Glad you got to enjoy my castoffs for a while anyway.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          What a shame! Perfectly good hardware ruined by software "progress" (I call it software planned obsolescence).
                          I just poly-modded an old Pentium 4 HP DC5000 SFF computer today. Probably not worth the time and effort to anyone these days, but I think they still make decent office PCs. Coupled with old indestructible 80 GB HDDs from WD and Seagate, I think these will last quite a while. There's a big pile of them at work. I think I might fix them up.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            I still have 3 working iMacs. I finally had to get my wife something a little faster....she got the garbage find EEE all-in-wonder C2D/4GB ....still cranking along like a champ!
                            Team : 49813
                            Join in!!
                            Team Stats
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              Still have my Poly prototype... not in service though (nowhere to use it right now). But it runs 100% stable so I have no doubts about the cap blend.
                              sigpic
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #35
                                What a shame!
                                I agree... I've been meaning to set up a Hackintosh so I can run Sweet16 to emulate a IIgs.
                                Up till now I've been using Kegs on Windows but it's not that good at all. Maybe I need a faster CPU.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  #36
                                  tc you need to have a part of your store dedicated to selling shit you fix.
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    I should....I have a ton of crap here I need to sell.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • Logistics
                                      • Apr 2007
                                      • 721
                                      Both the 17" and the 20" I recapped run fine, but even with a fresh install of 10.4.11 they seem like they aren't all that fast. You know that fast feeling you got when you installed that new copy of windows on the best hardware available during that time... just don't get that with these iMacs.
                                      • JuniperSprouts
                                        Solder Soldier
                                        • Aug 2010
                                        • 119
                                        #39
                                        I would HIGHLY recommend maxing out your RAM on those PPC models.
                                        Also:
                                        http://mintppc.org/
                                        http://penguinppc.org/about-2/distributions/
                                        Another idea:
                                        Gut the G5 iMacs & install a Raspberry Pi or a U-ITX or a M-ATX board...anyone know if it would possible with a PC motherboard's VGA (or DVI or ?) & the iMac's controller & inverter & ??
                                        • Logistics
                                          • Apr 2007
                                          • 721
                                          Yeah, the 1.8GHz 20" I recapped is for me, plus the wife got the 17" G4 she wanted. On the 20" I'll probably load Lubuntu or perhaps Mint since I want it for more utilitarian reasons like research. But I'll look into maxing the ram like you said.
                                          • ryogadan78
                                            iMac A1418 - No LED, no power after overvoltage on Ethernet port
                                            by ryogadan78
                                            Hi guys, I need your help again.
                                            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                                            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                                            06-10-2025, 03:49 AM
                                          • Stephen
                                            iMac M1 DFU restore issue
                                            by Stephen
                                            iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                                            this is the message it gives me with the error
                                            Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                                            Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                                            03-07-2025, 12:19 PM
                                          • Stephen
                                            iMac 27” 2020 Boot issue
                                            by Stephen
                                            Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
                                            08-16-2024, 09:32 AM
                                          • tommy97
                                            iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
                                            by tommy97
                                            we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
                                            Any ideas what might've...
                                            04-20-2024, 04:48 AM
                                          • CapLeaker
                                            Poly VVX-250 VOIP POE problem not booting fix
                                            by CapLeaker
                                            I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                                            Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                                            11-25-2023, 10:46 AM
