iMac 27” 2020 Boot issue
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I removed all the ram and tried one ram to see if it was a ram issue. Nothing. I removed the screen to investigate and nothing seems abnormal. Does anyone have any suggestions? I could do board repair but I wouldn’t know where to start on this machine. Anyone’s experience with this would be great
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 667
    Pulled up a thermal camera found a short on the board
    sigpic
    • reformatt
      Intel iMacs, 3rd party SSD failures and Fusion setups
      by reformatt
      I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
      As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
      So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
      12-18-2024, 10:34 PM
    • abajor
      Alienware Area-51 R2 Boot Loop issue.
      by abajor
      I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
      It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
      To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
      Right now I'm trying to dig through the PDF schematics and Board...
      03-08-2024, 10:08 PM
    • Safio
      Asus Rog Strix g15 g512LI BOOT ISSUE
      by Safio
      Hello
      My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
      i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
      thank you
      06-08-2024, 08:43 PM
    • bastien
      Apple MacBook Pro and iMac 820-02652 820-02935 820-02009
      by bastien
      Apple MacBook Pro and iMac Schematic & Board Vie
      A2991 2023 820-02935 16 M3
      A2780 2023 820-02652 16 M2
      A2439 2021 820-02009 iMac 24​...
      03-08-2025, 12:28 AM
    • fr0n1k
      Apple iMac A1311 Mid-2011 (820-3126-A) NO BOOT
      by fr0n1k
      Hello. Got an iMac after a power surge. The PSU survived, but the motherboard did not. Symptoms - after connecting the power, one LED (the rightmost one) lights up, 3.28-3.3v hangs on all legs of the bios flash drive, except for 4. The PCH is heated, low resistance PP3V3_S5 - 30 ohms, PP1V05_S0_PCH - 10-15 ohms. Powered through laboratory power supply 3V 1A to PP3V3_S5, the hub heats up wildly. USB data lines have the same resistance, not underestimated. There is no response to the power button.
      PP12V_S0 - 0.05V (should be 0), PP1V05_S0_PCH - 0.5V (should be 0)
      I've checked...
      10-22-2022, 04:10 AM
