The "Indestructible iMac" v2.0 - Poly revision 2
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    #41
    Re: The "Indestructible iMac" v2.0 - Poly revision 2
    Yeah i got a 17 inch i ordered the regular kit from here long ago and its still running, but i never touched the psu, i have a spare psu with bloated caps i should recap it.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      If it is a a spare, I would. It's easy and IMHO a good idea.
      After you recap it, I'd pop it in the iMac and recap the PSU that came out... that way you have two "good" PSUs, not two "time bomb" PSUs.
      sigpic
      (Insert witty quote here)
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16951
        ...i ordered the regular kit from here long ago and its still running...
        Now thats what I like to see!!
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • LLLlllou
          • May 2011
          • 201
          I finally got around to ordering the last of the polies I needed to recap mine (a 17 inch iSight G5 iMac) so I was re-skimming these iMac threads, and re-Googling. I have two questions:
          1) Has anyone actually measured the voltages on any of these caps? Looks like most, if not all the 6.3v caps should be running at well under 2V. I have a butt-load of 2.5V 1500uf polies, but I'm not sure I want to chance it. There's no way to measure the voltages without taking the whole damn thing apart, soldering wires, putting the whole damn thing back together, measuring, taking the whole damn thing apart again, recapping, then putting the whole damn thing together again . . . MASSIVE PITA!
          2) I see quite a few of the logic boards on sale on ebay as-is, that have either all Panasonic caps, or a mix if Panies and Rubies. Has anyone actually seen Apple use Panies in any of these, or are these all unsuccessful recaps?
          If so, I wonder if the boards have other issues, or if the surplus FL/FJ caps just don't have low enough ESR to make an Apple happy. I'm assuming they're FL or FJ, all I can see is the vents.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            #45
            The caps in the low side of the VRM see CPU Vcore - this is well under 2v on all CPUs made in the last 15 years or so. And most of today's CPUs are powered from the 12v rail, so the high side caps are easy to spot, they're 16v. All 6.3v caps in the CPU area can be safely replaced with 2.5v ones - in fact, if you look on a motherboard that has polies from the get go, you'll find 2.5v caps.
            A working TV? How boring!
            • ryogadan78
              iMac A1418 - No LED, no power after overvoltage on Ethernet port
              by ryogadan78
              Hi guys, I need your help again.
              I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
              When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
              06-10-2025, 03:49 AM
            • Stephen
              iMac M1 DFU restore issue
              by Stephen
              iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
              this is the message it gives me with the error
              Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
              Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
              03-07-2025, 12:19 PM
            • Stephen
              iMac 27” 2020 Boot issue
              by Stephen
              Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
              08-16-2024, 09:32 AM
            • tommy97
              iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
              by tommy97
              we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
              Any ideas what might've...
              04-20-2024, 04:48 AM
            • CapLeaker
              Poly VVX-250 VOIP POE problem not booting fix
              by CapLeaker
              I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
              Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
              11-25-2023, 10:46 AM
