New found hatred for Western Digital....
    • 31267
    Re: New found hatred for Western Digital....
    i'll tell you something funny,
    flash is rated in the datasheets as 10year minimum retention.
    dream-on in most cases.
    eproms were also rated at 10years minimum.
    i work with eproms all day - i regularly get stuff nearly 30years old that are 100% fine.
    25years is common before bit's fail.
    the only differences between eprom & flash are that flash has electrical erase - probably a gated drain-wire in each quantum-well.
    and flash (usually) has a higher density.
    i think the future is probably going to be ferro-electric ram.
    i'v done experiments with ferro-ram replacing battery-backed sram and the stuff is seriously fast and 100% reliable.
    datasheet claims 40years+ retention without power.
    if it manages 10 it will be better than flash!
    • Agent24
      I see dead caps
      • Oct 2007
      • 5084
      • New Zealand
      #82
      Yeah I saw that 10-Year retention on an 8GB USB drive I recently bought, I thought "Yeah, right!"
      What about EEPROM as used for Firmware\BIOS?
      Are you saying that leaving a motherboard for long enough without give the EEPROM a 'refresh' would result in the BIOS becoming corrupted due to lost data?
      -David VanHorn
        • 31267
        bios arent eeprom, they are flash.
        eeprom are very poor performance and small.
        but yes, leave a bios for several years and it may not run.
        and the data isnt refreshed when you power or read the chip - only when you write to it afaik.
        it is refreshed with ferro-ram i think.
        • Junk Parts
          Court Jester
          • Jun 2006
          • 8953
          Tiger direct has 1 TB Seagate Barracuda 7200 rpm SATA drives on sale for $39.00 if anyone is interested.
          "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
          Mark Twain
          "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
          John Paul Jones
          There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
          Rod Serling
          • bgavin
            • Jan 2007
            • 1355
            #85
            I'm burning in another set of WD Caviar Green 2TB -EARS drives for a client. The failure rate on all the big drives is so high, I want to make sure a full surface scan with WDC data lifeguard passes 100% before installing in the client's server.
            Two 640gb Caviar Black and two 2TB Green, each in a RAID1 group, should produce a reliable file system. I have a few others running this configuration.
            This is the first time with the Supermicro board. So far, I'm impressed with Supermicro for server boards. It is an XBN7 something or other, 3200 chipset, DDR2-800 at 1.8v fixed (yay!). It ran 36 hours of Memtest with G.Skill 4-4-4-12 2x2gb sticks. Very pleased.
            I'll set up the Intel RAID tonight after the last drive clears diagnostics.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5084
              • New Zealand
              #86
              Are those the ST31000528AS drives? I've got 2 of those and they're great.
              Any ideas why the 1.5TB and 2TB do have high failure rates? I bought the 1TB drives myself because I saw the Newegg reviews on the bigger ones showed up a lot of failures.
              -David VanHorn
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Originally posted by Agent24
                Interesting... now I really think I will stick to hard drives!!
                Bring on the 3TB and 4TB drives and may the 2TB ones drop their prices
                which brings me back to the idea of this post..
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5084
                  • New Zealand
                  #88
                  But is there any point though?
                  If they can get 4TB in 3.5" why bother making a bigger and slower drive?
                  Since the Bigfoot is a rather old drive design, updating or building a new design will cost more time and money in R&D, which may not be recoverable if the drive is big and slow and a lot of people don't buy it.
                  They may buy it if it was quite cheap, but then even with more sales the profits may still be just as low because of the lower selling price.
                  Remember the primary objective of a business is to make a profit...
                  -David VanHorn
                    • 31267
                    everybody has 5 1/4 bays,
                    if you can get 4gig in a 3.5 then you can get probably 8+ in 5 1/4
                    and the rotation may be slower but if the data is on the outer edge it will stream faster than a 7200
                    and you have a bigger frame to disipate heat.
                    big drives would be perfect for backup drives.
                    i'd take 2
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      I'm a fan of Supermicro boards.
                      Off the top of my head I have some X7DAL-E, X7DBE, and C2SBA+II in service.
                      I still don't use drives over 500Gb.
                      No faith in bigger drives being reliable.
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Going totally layman terms here....
                        High capacity drives have less physical space for each bit. [Less surface area.] As a result there is less 'mass' [area] to hold the charge representing a 1 or a 0 and the charges are weaker. - Since the spacing between the bits is also less, the charges are more likely to 'bleed' to each other across the disc. - And, as the bit-areas are smaller targets the mechanicals have less room for error to 'hit the spot' accurately.
                        - Dr Seuss
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5084
                          • New Zealand
                          #92
                          i'd take 2
                          Yeah, well mine are all full of DVD writers etc so wouldn't be much use to me actually.
                          Still, it does seem like a clever idea to increase capacity, maybe after the 4TB drives they will have to do it.
                          I just don't think they will until they know they can make a profit from it.
                          I understand that but I think the problems (on Newegg reviews) were more of the drives completely failing than just random data loss.
                          -David VanHorn
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Mechanicals and target size as with my last sentence.
                            - Dr Seuss
                              • 31267
                              buying 500gig drives wont help,
                              if you look at the mfr datasheets you will see the 500gig drives are the same as the terabyte ones - just less platters fitted.
                              • acstech
                                GrumpyModerator
                                • Jul 2007
                                • 1432
                                I'll admit that I haven't read the whole thread, and I apologize if this has come up before, but I wonder how much Universal Package Smashers (UPS) has to do with this? They even say your package is subject to a 6 foot drop.
                                A man convinced against his will is of the same opinion still.
                                • seanc
                                  • Nov 2008
                                  • 1319
                                  #96
                                  I've probably mentioned my batch of 25 500GB Seagate drives before... one just failed with supposed thousands of bad sectors. Data seems irrecoverable, MHDD is powerless to it's issues. I can see folder structure, anything else = I/O error.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5084
                                    • New Zealand
                                    #97
                                    Good point. I now always pick my hard drives up from shops myself and take utmost care in transporting them home.
                                    I haven't had any problems with any of those drives yet. Interestingly enough a 250GB Western Digital which I did have couriered to me has recently reallocated a few sectors...
                                    -David VanHorn
                                    • dood
                                      Deputy dood
                                      • Mar 2004
                                      • 2462
                                      Uh... and how did those drives get from Thailand to your local computer shop?
                                      Ludicrous gibs!
                                        • 31267
                                        on a forklift,
                                        i can assure the that the bulk-box wasnt dropped off a covayor at the airport or courior sorting center.
                                        big boxes are "handled", it's the smaller ones that are thrown down chutes and off conveyers.
                                        • dood
                                          Deputy dood
                                          • Mar 2004
                                          • 2462
                                          on a forklift,
                                          *chuckle*
                                          Ludicrous gibs!
                                          • evilgenius31
                                            Zephyrus G14 GA401QH-211 reaches bios but has no serial number and can't detect NVME drives
                                            by evilgenius31
                                            Hi Everyone -
                                            I'm working on a Zephyrus G14 GA401QH-211. I bought it on ebay, knowing it only boots to the bios. The serial number is missing when I enter the bios. I've also attempted to use multiple NVME SSDs, but the bios can't detect them.
                                            Does this seem like a software issue, or a hardware issue with the nvme slot / pcie controller?
                                            Thanks!
                                            Today, 07:17 AM
                                          • eccerr0r
                                            It's 2025: do you know where your 5¼" floppy drives are?
                                            by eccerr0r
                                            Oh wow.
                                            As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                            Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                            Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                            Weird. Seems the PC drive is having trouble clamping...
                                            07-07-2025, 12:49 AM
                                          • kjchatman
                                            how to recover data from a western digital passport
                                            by kjchatman
                                            I was trying to recover the data from a 4tb drive that was bought last september and it stopped working after a couple months. I bought a drive of the same model with the intention of using the pcb but after swapping the firmware, it still isn't recoverable or even usable. both pcb boards will work with the new drive as long as the firmware from the new drive is used. In disk management, the size of the drive doesn't show at all. is this corrupt firmware or worse?...
                                            04-11-2022, 02:38 PM
                                          • goodpsusearch
                                            Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                                            by goodpsusearch
                                            Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                                            First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                                            05-05-2024, 02:04 PM
                                          • dmill89
                                            Chieftec Dragon LGA1366 Build
                                            by dmill89
                                            I recently got ahold of a bright green Chieftec/Chenming "Dragon" case (I've always liked these cases, especially in "oddball" colors) and decoded to throw together a period correct-ish build.
                                            Components:
                                            Motherboard: Gigabyte GA-X58A-UD3R:
                                            CPU: Intel Xeon W3680
                                            RAM: 24GB DDR3-1333
                                            GPU: Nvidia GeForce GTX1060 (I know a GTX1060 is a bit too new, I was going to use a GTX780, but it was too long to fit with the lower HDD cage installed, and the GTX1060 provides similar performance)...
                                            02-26-2024, 06:32 PM
