Re: New found hatred for Western Digital....
i'll tell you something funny,
flash is rated in the datasheets as 10year minimum retention.
dream-on in most cases.
eproms were also rated at 10years minimum.
i work with eproms all day - i regularly get stuff nearly 30years old that are 100% fine.
25years is common before bit's fail.
the only differences between eprom & flash are that flash has electrical erase - probably a gated drain-wire in each quantum-well.
and flash (usually) has a higher density.
i think the future is probably going to be ferro-electric ram.
i'v done experiments with ferro-ram replacing battery-backed sram and the stuff is seriously fast and 100% reliable.
datasheet claims 40years+ retention without power.
if it manages 10 it will be better than flash!
