Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
    First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow the drives going bad.
    I decided to check every single cap on that machine with my ESR/capacitance meter.
    All the caps on the power supply board were found OK.
    On the green PCB that hosts the back panel audio connectors all the caps were found OK except a visibly bulging Licon capacitor that is located next to the relay, so I replaced that cap.
    Then, very carefully removed the 2 optical drives. You should try to remove the 2 CD drives and the PCB bellow them all together as 1 piece and not do as I did. There are flex cables bellow the optical drives that make it very difficult to work while the PCB and the drives are still inside the device.
    Anyway, after carefully disconnecting the flex cables and removing the optical drives, I checked every SMD electrolytic capacitor with my ESR meter and found several of them to be bad, most of them totally open! I am really grateful that none of them leaked electrolyte on the PCB.
    I decided to replace the caps with used capacitors I have pulled out of other machines, because the device is of no special value to me, economical or sentimental, so I didn't want to spend money on the repair. I also replaced only the caps that were found bad upon testing in circuit. There is a chance that there might be more bad caps there but due to being connected in parallel with other caps, the ESR meter was not able to detect it.
    If your unit is important to you, it's better to try to replace all the capacitors on that board, using caps from known Japanese manufacturers rated for 105C, general purpose or entry level low ESR and definitely not ultra low ESR as that might detune the circuit. I used a mix of 85C and 105C capacitors that I first tested to make sure they didn't go bad in storage. Total number of caps replaced: 14
    Number of caps left alone: 20
    After the recap, reconnected everything paying attention not to damage the flex cables or break a connector.
    Finally, I connected it to AC mains and made sure both drives now work without any issues!
    The only issue that I found is that when I play extremely scratched CDs I get audible jitter, mainly on the repaired drive but also on the recorder drive on some occasions.
    I attach some before and after pics of the repair for reference​
  • guy_fixit
    sony VGN-G2 no USB drives
    by guy_fixit
    I have here a Japanese market Sony VGN-G2ABNS. By the specs this ultaportable laptop is very similar to a Sony VGN-TZ series but with a 12 inch XGA display. U7700 cpu, 945GMS chipset, 1 to 2 GB DDR2 RAM, 1.8" pata-ZIF hdd, etc. As received it came with windows 10 - Japanese language. After I noticed my problem I swapped in a TZ hdd with winows 7 pro 32 bit.
    The problem I have with it is most USB devices do not work on it. Plug in a mouse or keyboard to either external port and that works fine. Any other device, either internal or plugged in will not work. Windows says "there...
    01-01-2024, 01:17 AM
  • eccerr0r
    It's 2025: do you know where your 5¼" floppy drives are?
    by eccerr0r
    Oh wow.
    As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
    Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
    Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
    Weird. Seems the PC drive is having trouble clamping...
    07-07-2025, 12:49 AM
  • dkneyle
    Sony KDL-46HX850 Can't upgrade/update firmware
    by dkneyle
    Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
    Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
    09-25-2024, 10:44 PM
    Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
    This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
    09-06-2024, 05:27 AM
  • zen
    FH7 Sony cass deck service manual & gear required.
    by zen
    Hi all
    This deck keeps jamming.
    Took a chance & ordered an upgraded FF cam gear, plus slider sold on Ebay, as I thought it might be a common cause of issues being that it was sold a repair kit.
    Well, that's what I get for making assumptions.
    Stripped down & discovered a large black intermediate gear with worn teeth.
    Can anyone help to source it?
    10-10-2022, 08:07 AM
