how to recover data from a western digital passport
  • kjchatman
    • Dec 2012
    • 213
    • united states
    I was trying to recover the data from a 4tb drive that was bought last september and it stopped working after a couple months. I bought a drive of the same model with the intention of using the pcb but after swapping the firmware, it still isn't recoverable or even usable. both pcb boards will work with the new drive as long as the firmware from the new drive is used. In disk management, the size of the drive doesn't show at all. is this corrupt firmware or worse?
  • petehall347
    • Jan 2015
    • 4446
    • United Kingdom
    Re: how to recover data from a western digital passport
    https://www.easeus.com/resource/disk...itialized.html
    • reformatt
      • Feb 2020
      • 1525
      Usually it's physical damage internally to the drive. If the data is important, I recommend you send this to someone who has the correct tools and experience to handle it. The jigs, clean room and software alone get into many thousands of dollars. You are either doing this full time or you aren't.
      Check out this software...it's like 10K.
      https://www.acelab.eu.com/
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • TheUser
        Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
        by TheUser
        Hello to everyone ,
        This is my first post here, and i would like to share with you a small story in case you can help me.
        Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
        All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
        I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
        02-10-2024, 02:07 PM
      • gurj1979
        Ubiquiti firmware help. US-8-150W POE
        by gurj1979
        Hi guys.
        I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
        Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
        So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
        Got New chip and writes good.
        THE PROBLEM...
        It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
        Does anyone have a Good Firmware I can have?...
        07-22-2024, 05:13 PM
      • ivanh
        Western Digital My Book 3TB firmware dump
        by ivanh
        Hi All,
        Does anybody have / or is able to provide a dump of the U2 chip (SOP8) in the WD MyBook for MAC 3TB enclosure? Its the chip on the SATA to USB internal interface card.
        Background - I have an enclosure which was not functioning correctly. It was only providing 2TB of space as opposed the original 3TB, no matter how i formatted it. Disabling chip U2 (cutting pin8) restored capacity to 3TB however with the loss of the useful WD drive functions.
        Hence the desire to fix the enclosure by replacing the faulty U2 (25LD020 OP8) with a new one, programmed with...
        12-28-2020, 05:13 PM
      • Slapito
        Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
        by Slapito
        I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
        Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
        I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
        I already downloaded the BIOS update file from msi official...
        10-09-2025, 02:00 AM
