New found hatred for Western Digital....
  • Wizard
    • Mar 2008
    • 2296
    #61
    Re: New found hatred for Western Digital....
    is it G1 or G2 intel SSD? probably G1 or value version (40GB) is even slower.
    Cheers, Wizard
    • Scenic
      o.O
      • Sep 2007
      • 2642
      by the way... nice job falsifying the values
      hdtach: 1MB = 1000KB
      hdtune: 1MB = 1024KB
      • Colt45ws
        • Jan 2009
        • 174
        Crystal disk shows 190MB/s sequential read for a Crucial M225 64GB.
        • bgavin
          • Jan 2007
          • 1355
          #64
          Originally posted by Wizard
          is it G1 or G2 intel SSD? probably G1 or value version (40GB) is even slower.Cheers, Wizard
          The SSD is at least 80gb, if that helps on the model.
          I'm an Intel contractor and they provided the laptop. Considering the price of the 6930p and docking station, it does not seem likely the SSD is a bargain unit.
          No matter, they still die prematurely, and without warning.
            • 31262
            just get a 4gig fast CF-card and a chinese CF>IDE or CF>SATA adapter.
            • Agent24
              I see dead caps
              • Oct 2007
              • 5084
              • New Zealand
              #66
              I have always suspected that SSDs die without warning etc but have not seen it firsthand or read stories etc
              Don't suppose you know any good websites detailing specifics on SSD failure?
              -David VanHorn
                • 31262
                ssd is just like a big cf-card.
                i'v had a big cf-card fail being used as a boot-drive.
                it just lost it's flash without warning.
                just the controller i'd ing the make and size, then it freezes when you try to read or write.
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5045
                  • US
                  #68
                  my mother had a gigabyte 939 motherboard (via chipset). would not like any segate sata drive, all other brands just fine. updated firmware, no go. took a wd sata drive just fine
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5084
                    • New Zealand
                    #69
                    Does it use the VIA VT8237 Southbridge? The first revision is known to have issues with some SATA-II drives...
                    -David VanHorn
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5045
                      • US
                      #70
                      Its actually an asus a8v-x with an 8251 chip. even at that I used the sata 150 jumper on the drive and still same thing
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        I had a problem very similar to that with a new Seagate drive. This was a few years back. A call to Seagate tech support, and they sent me a revised firmware for the drive which fixed the issues once applied from a PC that wasn't effected.
                        Ludicrous gibs!
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          SSDs [like any RAM] are basically banks of tiny capacitors in a grid that are charged for a '1' and discharged for a '0'.
                          With SSDs and flash memory they [the caps] have a very limited number of charge/discharge before they fail [as compared to RAM used for system memory].
                          They may have improved since I looked but when I did a 'normal' PC user [8hr/day 'office use'] could only expect about 3 years use out of an SSD before it would need to be replaced.
                          - High cost and short life makes SSD not worth it to me.
                          Mann-Made Global Warming.
                          - Dr Seuss
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5045
                            • US
                            #73
                            yeah and lets get tc to replace a few million of these microscopic capicators hehe
                            yeah its better to come up with some high rpm raid solution. there are some ways to extend the life of ssd's like disabling the paging file in windows if you have enough ram, but even at that the registry is written to on a constant basis
                              • 31262
                              most failed flash chips dont have bad cell's - they just die!
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Dead = bad cells.
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  I researched SSD's looking a fast drive to use as dedicated page file drives in a server setup.
                                  Keeping the page files off the OS and data drives [and the interface that goes to the OS and data drives] speeds things up quite nicely if the cost of the extra drive is worth it for the project.
                                  When I found out that would kill SSD's real quick I settled on WD Raptor 36GB drives for that.
                                  If I ever trip over one cheap I might switch to a sata based RAM drive [one that uses actual RAM chips] for that purpose, but those are rare and usually MO $$$ when I've seen them.
                                  - Dr Seuss
                                    • 31262
                                    dead doesnt = bad cells.
                                    bad cells = verify errors.
                                    dead = failure in the buffers or the matrix decoding.
                                    the buffers & decode circuits are hammered far more than the cell's
                                    i'll add this, retention on flash seems like shit - and getting worse.
                                    i used to get stuff 4-6 years old with corrupt or intermittant data in the flash,
                                    now i'm seeing stuff only a year+ in age.
                                    both fixed by a re-flash.
                                    so the flash chips have higher leakage, or the higher density is resulting in a lower electron-per-cell count.
                                      • 31262
                                      double post.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Verify errors occur due to bad cells.
                                        The buffers are caps [aka cells] too.
                                        Dead = bad cells.
                                        "fixed by a re-flash"
                                        - Even a bad cap will hold a charge for a little while after you cycle it's voltgae.
                                        - Dr Seuss
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5084
                                          • New Zealand
                                          #80
                                          Interesting... now I really think I will stick to hard drives!!
                                          Bring on the 3TB and 4TB drives and may the 2TB ones drop their prices
                                          -David VanHorn
                                          • eccerr0r
                                            It's 2025: do you know where your 5¼" floppy drives are?
                                            by eccerr0r
                                            Oh wow.
                                            As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                            Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                            Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                            Weird. Seems the PC drive is having trouble clamping...
                                            07-07-2025, 12:49 AM
                                          • kjchatman
                                            how to recover data from a western digital passport
                                            by kjchatman
                                            I was trying to recover the data from a 4tb drive that was bought last september and it stopped working after a couple months. I bought a drive of the same model with the intention of using the pcb but after swapping the firmware, it still isn't recoverable or even usable. both pcb boards will work with the new drive as long as the firmware from the new drive is used. In disk management, the size of the drive doesn't show at all. is this corrupt firmware or worse?...
                                            04-11-2022, 02:38 PM
                                          • goodpsusearch
                                            Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
                                            by goodpsusearch
                                            Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
                                            First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
                                            05-05-2024, 02:04 PM
                                          • dmill89
                                            Chieftec Dragon LGA1366 Build
                                            by dmill89
                                            I recently got ahold of a bright green Chieftec/Chenming "Dragon" case (I've always liked these cases, especially in "oddball" colors) and decoded to throw together a period correct-ish build.
                                            Components:
                                            Motherboard: Gigabyte GA-X58A-UD3R:
                                            CPU: Intel Xeon W3680
                                            RAM: 24GB DDR3-1333
                                            GPU: Nvidia GeForce GTX1060 (I know a GTX1060 is a bit too new, I was going to use a GTX780, but it was too long to fit with the lower HDD cage installed, and the GTX1060 provides similar performance)...
                                            02-26-2024, 06:32 PM
                                          • wolf1976
                                            is there any univarsal wifi motherboard that supports and digital tvs ?
                                            by wolf1976
                                            hi i want to convert my simple digital tv because the motherboard is dead to wifi motherboard but with the ability has and tuner for digital channels DVB-T compatible in europe
                                            is there ?
                                            do you have to suggest me one ?
                                            thanks on advance...
                                            01-05-2025, 04:29 PM
