Post your system.......
This is a sticky topic.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Post your system.......
    Originally posted by Dan81
    I think ASUS cripples down the BIOS on microATX boards. At least I can only find AI overclocking but that's about it. Also I'm on stock cooling...
    I know that back in the single-core era, Asus liked to severely cripple their micro-ATX motherboards. Especially models that end with "-VM".
    (Locks you out of virtually everything!)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • RJARRRPCGP
      • Jul 2004
      • 6304
      I usually go for the screw-mount heatsinks that also use a backplate...
      Arc A770 16 GB
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        • Romania
        #683
        Just did a few upgrades again.
        Also,replaced the stock heatsink finally. It's some Acer/Foxconn heatsink that comes with a backplate.
        Specs:
        ASUS P5QL PRO w/ Xeon BIOS
        2GB RAM
        Radeon R7 240 2GB DDR3
        Pentium E5200 2.5GHz
        Allied AL-A400ATX 120mm
        2x H-L Data Storage DVD-RW drives
        1TB Samsung HD103SI 5400RPM SATA II HDD
        AVerMedia AVerTV Super 009 TV tuner
        Windows 7 Ultimate SP1 x64
        Delux MG760 case (BMW-styled case made out of Zinc.)
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • Agent24
          I see dead caps
          • Oct 2007
          • 5085
          • New Zealand
          #684
          Carrie called, she wants her computer case back
          -David VanHorn
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            • Romania
            #685
            Lies,Chuckie brought me the case himself.
            Main rig:
            Gigabyte B75M-D3H
            16GB DDR3-1600
            Delux MG760 case
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #686
              ^ Lol, what's with all the red paint inside the case? Or is that blood from someone cutting their fingers on the cheap case?
              ... Or perhaps this came from some place where there was a zombie apocalypse?
              Anyways, good build, though. Looks like you finally have a pretty decent system now.
              I've taken pictures of a few of my rigs. Will share soon when I have time. They are all ratchet / laughing stock, but they serve me well for now.
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                • Romania
                #687
                It was some failed case mod - I had an red spray paint can that was past its expiry date and using it quite gave that result. I didn't bother to paint the metal chassis again so I just painted the plastics (front panel and top handle (since this case has a handle) and the side panels and left the chassis like that.
                Also it's not that bad. Unlike every case on the market that is made out of thin tin,I was told this thing was built using Zinc,and just the case itself (without anything in it) was heavy as hell.
                Main rig:
                Gigabyte B75M-D3H
                16GB DDR3-1600
                Delux MG760 case
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  Finally stuck a drive(that actually works) in my Dell Inspiron E6520.
                  160GB HDD(maybe temp)
                  everything else is stock
                  Service Tag: CTXH4R1
                  Permanently Retired Systems:
                  Kooky and Kool Systems
                  sigpic
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    Specs:
                    2GB RAM
                    The Asus P5QL Pro was the motherboard I used to have. From September 24, 2008 to February 11, 2013, it was my best motherboard in service!
                    I first had a Pentium E2180. (Core 2 Duo-based and 65nm) (Also a Conroe)
                    On August 17, 2009, I dropped a 2007 Core 2 Duo "Conroe" E4500 (65nm) onto the Asus P5QL Pro motherboard. And probably during the tail end of 2012, was when it got a Core 2 Duo "Wolfdale" E8400 (45nm) in there!
                    Arc A770 16 GB
                    • grss1982
                      • Mar 2007
                      • 225
                      • Philippines
                      #690
                      Just did a rebuild of my main rig after the death of key components:
                      Intel i7-3770
                      16GB of RAM (4x4)
                      MSI B75MA-P45
                      ASUS GTX 660 Ti DirectCU (2GB DDR5)
                      Seasonic S12II-620 PSU
                      2x1TB HDD (Seagate and Western Digital)
                      1x500GB (Western Digital)
                      ASUS DVD-RW
                      Antec 300 Case
                      CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
                      GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
                      Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
                      • Dan81
                        SNES-powered
                        • Oct 2013
                        • 1866
                        • Romania
                        #691
                        I got this system from a dumpster. Anyone know what GPU should I replace the MX440 with?
                        ASUS P4B533
                        1GB RAM
                        80GB HDD
                        300W Deer DR-A300ATX
                        GF4 MX440 64MB
                        JNC case w/multicolor leds
                        Pentium 4 2.8GHz Northwood core
                        Pioneer DVD-117 DVD-ROM
                        3com 10/100 NIC
                        Windows 2000 SP4
                        Main rig:
                        Gigabyte B75M-D3H
                        16GB DDR3-1600
                        Delux MG760 case
                        • jiroy
                          • Jun 2016
                          • 2416
                          • Lebanon
                          #692
                          ASUS P4B533
                          1GB RAM
                          80GB HDD
                          GF4 MX440 64MB
                          3com 10/100 NIC
                          Windows 2000 SP4
                          MX440 is an AGP card , so you don't have Pci Express slots . Anyway , I would go for VisionTek Radeon 3450 , because it can support directx 10 .
                          Here's a web link where you can choose :
                          https://www.lifewire.com/best-agp-graphics-cards-834107
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            #693
                            I finally got around to using my AMD Athlon 64 FX-57 CPU!
                            Just in case anyone still remembers... YES, this is indeed that CPU with the broken pins that I posted about several years ago in the Ghetto Mods thread:
                            https://www.badcaps.net/forum/showpo...5&postcount=54
                            It took me a few tries to get the CPU going, mainly because a few years back, I tested it in a motherboard that had gel flux in the CPU socket, so the flux had some of the pins slightly corroded. But after cleaning the pins and testing the CPU in various motherboards to try to figure out why they wouldn't detect it, eventually it did come back to life. I now have it in my "Team Red" ATI-AMD 64 classic gaming PC. And boy, that CPU flies! Windows XP is extremely snappy. Even internet browsing is fine, despite this being a single-core, single threaded CPU.
                            Then again, this is after all one of the fastest single-core CPUs one can buy (and certainly the fastest for Socket 939).
                            After the upgrade, though, I did have to use a lower-TDP GPU in that PC. The FX-57 is a 105 Watt TDP CPU, and I am using a 250 Watt HiPro with 16 Amps rating on the 12V rail. There was no way I could keep my HD3870 in there with that CPU, because that would require 210 Watts on the 12V rail (and that's without factoring the HDD or anything else). I was already close to maxing out the PSU's 12V rail even with the AMD Athlon 64 3500+ that was in there before the FX-57. So that PC is still not quite finished yet. But I do have some work-in-progress pictures... just need to get them off my camera and organize them a bit. I've been a bit sloppy with file management lately.
                            Lol. That mod actually turned out awesome, though. You now have a proper Halloween-themed PC.
                            I doubt it is purely made of Zinc. Zinc is rather hard and brittle. Probably just thicker steel.
                            ASUS P4B533
                            1GB RAM
                            80GB HDD
                            GF4 MX440 64MB
                            3com 10/100 NIC
                            Windows 2000 SP4
                            Well, the question is, what do you want to do with that PC? General internet browser? Or just a classic gaming PC?
                            I personally wouldn't use a Pentium 4 CPU without HT for an internet browser, because the P4 architecture will struggle without HT on just about every website. If you do want to use it as an internet browser, then I suggest going with a GeForce 6 or 7 series video cards, because those support H.264 and will off-load the CPU quite a bit on flash/video-heavy websites. An alternative to the GF 6 and 7 series are the ATI HD3x00 series, as those are the first generation of cards that offer somewhat better H.264 decoding/encoding.
                            Otherwise, if you are building a classic gaming PC, something like an older mid/high-end AGP GPU like the GeForce4 ti4400/4600 or Radeon 9500/9600/9700/9800 would do quite alright. If you can find one of these for cheap, definitely snatch it - the value of those video cards has gone up quite a bit in the last several years. And it will go up probably even more as AGP gets older and older. Just look up the price of any VooDoo video card now, and you might get an understanding.
                            • Dan81
                              SNES-powered
                              • Oct 2013
                              • 1866
                              • Romania
                              #694
                              My bad. It's actually galvanized steel. (which I think it has Zinc in its composition)
                              I might source a Radeon 9500 or any of these. One of my friends runs a 2.8GHz Pentium 4 w/ FX5200 as his daily driver (he couldn't afford anything better) and Firefox 50 and Youtube ran okay,without stuttering. I have to mention,it has a 2GB DDR400 Kingston KVR stick in it,so that may be the reason internet browsing was pretty easy for him on that P4.
                              Main rig:
                              Gigabyte B75M-D3H
                              16GB DDR3-1600
                              Delux MG760 case
                              • dmill89
                                • Dec 2011
                                • 2534
                                It does, galvanized steel is steel that is dipped in molten zinc (or in some cases electroplated) to provide a corrosion resistant coating.
                                • ChaosLegionnaire
                                  HC Overclocker
                                  • Jul 2012
                                  • 3266
                                  • Singapore
                                  #696
                                  yea that makes much more sense. last i checked the commodity prices of base metals in the stock market, zinc is half the cost of copper per pound and more expensive per pound than lead or aluminium. a full zinc case might end up getting stolen by thieves lol...
                                  • gg1978
                                    • Dec 2004
                                    • 431
                                    Just recently upgraded to Skylake from Haswell, and from mini-ITX to microATX at the same time, as i figure it'll be the last 7 box for me. Just did a test clone of 7 to a fresh SSD and it migrated cleanly over, with just a reactivation needed since all the hardware changed.
                                    So far i've been impressed by Skylake's overclocking ability and cooler temps relative to Haswell, with roughly equivalent cooling. So far seeing CPU temps about 15 to 20 C cooler relative to Haswell when redlined in latest version of Prime95 with 200MHz minimum clock speed advantage .
                                    Core i5 6600K (4.5GHz in single/dual, 4.2GHz in triple/Quad) , + 100mV Vcore offset, so peaks about 1.27V in single/dual mode.
                                    Asrock Z270M Pro4 microATX Z270 motherboard
                                    16GB (2x8GB) Crucial DDR4-2133
                                    Sapphire RX480+ 8GB videocard
                                    Samsung 850Pro 512GB SATA boot SSD
                                    Samsung 850Evo 500GB SATA SSD
                                    Samsung 750Evo 500GB SATA SSD
                                    Crucial MX300 750GB SATA SSD
                                    Samsung XP941 M.2 X4 128GB PCIe SSD
                                    Intel 600p M2 M.2 X4 512GB NVMe SSD
                                    Seagate 4TB 7200 HDD
                                    Hitachi 3TB 7200 HDD
                                    Seasonic M12II 520W Bronze PSU
                                    Cooler Master N200 microATX chassis.
                                    LG bluray burner
                                    PCIe x1 addon card for 4X SATA ports
                                    120mm Tower CPU cooler, i forget the brand, but replaced the stock fan with a decent Noctua fan, 3000 RPM max, but it doesn't get hot enough to run the fan 100%.
                                    I'll probably eventually throw in a 2X hotswap 2.5" bay in it, and use a couple more of the SATA card ports.
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      If you really like Skylake, then Kaby Lake shall really rock!
                                      Arc A770 16 GB
                                      • Dan81
                                        SNES-powered
                                        • Oct 2013
                                        • 1866
                                        • Romania
                                        #699
                                        My systems as of now:
                                        Main rig:
                                        ASUS P5QL PRO
                                        Pentium Dual Core E5200 2.5GHz
                                        2GB RAM
                                        Windows 7 x64
                                        Delux MG760 case (galvanized steel)
                                        2x H-L DVD-RW (IDE)
                                        Radeon R7 240 2GB PCI-E
                                        AVerMedia AVerTV M733A TV Tuner (PCI, Phillips based)
                                        1TB Samsung HD103SI
                                        Allied AL-A400ATX 120mm PSU (recapped)
                                        2nd:
                                        ECS G31T-M7 v1.0 (poly caps from factory on VRM, OST on RAM and other low power stuff)
                                        Pentium Dual Core E5300 2.6GHz
                                        1GB RAM
                                        Windows XP SP3
                                        Delux MT375 case
                                        1x LiteOn DVD-RW
                                        Samsung HD161JJ 160GB SATA HDD
                                        Delux ATX-450W P4 PSU (recapped)
                                        3rd:
                                        ASUS P4B533 (recapped)
                                        Pentium 4 2.8GHz (Northwood)
                                        1GB RAM
                                        Windows XP SP3
                                        JNC FQ-70 case
                                        1x H-L DVD-RW (white bezel)
                                        Radeon HD3450 AGP 512MB
                                        80GB WDC WD800BB IDE
                                        L&C LC-B350ATX (recapped, thick heatsinks)
                                        4th:
                                        Gigabyte GA-8I848P-G (recapped with Rubycon MBZs)
                                        Pentium 4 2.8GHz
                                        512MB RAM
                                        Windows 7 Ultimate x86
                                        JNC RJA52 case
                                        1x Samsung DVD-RW
                                        Palit GForce FX5500 256MB AGP
                                        80GB WDC WD800JB HDD
                                        Modecom FEEL-400ATX (Deer built - recapped with Rubycon MBZ)
                                        5th:
                                        Biostar P4M80-M4
                                        Celeron 2GHz Northwood
                                        512MB RAM
                                        Windows XP SP3
                                        JNC 4JA-52 case
                                        1x Sony CRX-300E DVD-ROM
                                        ABIT Siluro FX5200 64MB
                                        80GB Hitachi SATA HDD (laptop drive)
                                        no PSU yet
                                        Main rig:
                                        Gigabyte B75M-D3H
                                        16GB DDR3-1600
                                        Delux MG760 case
                                        • llonen
                                          • Sep 2014
                                          • 495
                                          • hampshire
                                          #700
                                          Main box consists of
                                          Striker extreme main board
                                          Intel quad core extreme clocked at 3.2gig
                                          cosair 1200 watt psu
                                          16 gig ram
                                          2 x gtx780ti (SLI)
                                          250 gig ssd system
                                          2 tb data drive
                                          Win 7 professional
                                          2 LG optical drives
                                          I am not sure what brand the tower is
                                          • canadaboy25
                                            Drive SMART status not showing up through RAID controller?
                                            by canadaboy25
                                            Hey guys,
                                            I have an Asus M5A99FX Pro R2.0 motherboard with AMD RAIDXpert. I set up a 1000GB RAID1 array on it. This was about 8 years ago. Every once in a while, a power outage or something would knock one drive offline and degrade the array. After a reboot the drive would be back online and it would rebuild just fine.
                                            Recently, a drive dropped offline and the array became degraded. I figured it was no big deal and rebooted then set it to rebuild overnight. The next morning I took a look and both drives had dropped offline at 70% rebuild. Uh oh.
                                            I rebooted...
                                            09-24-2021, 01:56 PM
                                            Announcement: The Win-raid forums are closing
                                            by SMDFlea
                                            https://winraid.level1techs.com/t/wi...uncement/38021
                                            The win-raid forums are closing at the end of this year,its a sad time for all who have used the site to gain knowledge from some of the really talented members there.
                                            11-20-2021, 10:21 AM
                                          • bmxlovah
                                            Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                                            by bmxlovah
                                            My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                                            11-24-2022, 06:29 AM
                                          • tbalint3
                                            Abit ST6-Raid repair
                                            by tbalint3
                                            Hello All,
                                            I am trying to repair an old Abit ST6-R motherboard.
                                            The symptoms are the following:
                                            I got it in a non-working state. I was told that it sometimes turned on, but many times just the CPU fan was spinning and no other signs of life, the board didn't POST, and now it doesn't POST at all.
                                            It was full of bulged electrolytic capacitors, so I replaced all of them with new Low-ESR ones, but it didn't solve the problem.
                                            If I install a CPU in the S370 socket, only the fans are spinning and no POST. There are no beep codes even if the RAM DIMMs...
                                            09-01-2024, 10:03 AM
                                          • canadaboy25
                                            Getting Windows to boot after changing SATA from RAID to AHCI
                                            by canadaboy25
                                            Hey guys I'm wondering if anyone has any ideas on how to get Windows 10 to boot up and install drivers after changing the bios settings for the sata port from raid to ahci.
                                            My motherboard is an Asus M5A99FX pro R2.0 and when I built the PC I set all of the sata ports to raid mode. There is one setting for ports 1-4 and one setting for port 5 and the esata port. I currently have 4 drives set up in two raid 1 arrays on ports 1-4. My ssd containing Windows 10 is plugged into port 5. I also have an external esata enclosure with a 2tb drive that I use as a Windows backup plugged into...
                                            12-02-2018, 02:17 PM
