PS2 port failure
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: PS2 port failure
    Originally posted by PCBONEZ
    Check +5v at PS/2 port both before and after the keyboard 'goes away'.
    Check from under the board at the solder joints so you don't have to disconnect to check the volts.
    Far chance your problem is the +5v on the PSU you are using drops below the threshold for the IC chip inside the keyboard.
    Mann-Made Global Warming.
    - Dr Seuss
    • kaniki
      • 514
      Originally posted by stj
      you shouldnt rip or break anything off - ever.
      you risk ripping the tracks up doing that.
      and you dont short anything together afterwards either.
      that is what i kinda thought. that is why when i read that they fix was to take it off, my first thought is "if you take it off and dont short it out, you kill the power source, so how does it work if you kill the power?' that was my thought at least.
      From what i have read about it, it is the same problem with this board as the TUSL2-C board. I did take the cover off the PS2 port and nothing was broke or bent or shorting out in there, I also checked the solder joints under the board and all was solid there too. The power supply is a 300 watt but that should be enough to power a 1 gig processor system. there is not much extra in it and i did pull out the pci cards and tried it that way too. still the same.
      Do you know if the whole c151 chip thing was a hoax or was there some merit behind it?
        • 31250
        it may not be a hoax,
        i'v had acade pcb's that use ceramic aray's on the inputs.
        think a line of ceramic's between the signals and the ground.
        it's for noise suppression, but sometimes one goes short and the input looks stuck on.
        if you get one of these ps2 problems, try metering the resistance between ground and the clock,data & reset pins.
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          I desoldered the C151 eight leg capacitor, did NOT "remove it by force" as suggested in the Asus forum
          That board is in storage most of the time, but its PS/2 ports do work fine every time I use it
          better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
          • kaniki
            • 514
            so someone has had luck with doing this then.. I guess I will give it a try and hope for the best. If all it does is act on behalf of the PS2 and it messes somehting up, well... they dont work now so no harm done. Ill let you know how it turns out.. probably wont get to it till more towards evening..
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              I wasn't suggesting your PSU is too small, I was suggesting it's bad and doesn't hold voltage on +5v.
              Also P3 boards pull CPU power from +5v so if that's a "P4 PSU" you may have too much load on +5v and too little on +12v for it to regulate properly.
              - Dr Seuss
              • kaniki
                • 514
                #27
                well, it is the same power supply that has been in there for years. and it just stopped working one day. I removed the extra stuff like the roms, hard drive.. well i disconnected everything but the motherboard and processor and fans and tried it again same response.. and by that point in time, there is nothing to overload even a P4 power supply. I did check the power readings per voltage and they were all within 0.1v of there rating. also just for the heck of it i tried a different power supply.. 400 w this time.. same response.
                • kaniki
                  • 514
                  #28
                  Ok. I got the chip out and that did it. Removing that c151 chip did it. Both PS2 ports are now working. I just wish that they put it in a better place. If it was just a little better positioning, then i would not have had to take the motherboard out. But i did not want to damage any other parts since they were so close so I had to remove it. Fun!!! I think i read that there were something like a half dozen or so boards that this was a problem with.
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    May be useful for someone Googling, to know it works on CUSL2, as well as TUSL2
                    • kaniki
                      • 514
                      #30
                      I did find this while searching
                      After later look at ASUS's NetQ Forum found that the problem in Asus motherboards in certain types or the more common, these motherboards models include CUSL2, CUSL2-C, CUSL2-M, CUSL2-C-BP, TUSL2-C, TUSL2-C, CUV4X, CUV4X-C, CUBX, A7VPRO, etc., with the motherboard model and also having this problem
                      so obviously it is a problem in a lot of asus motherboards.
                      Did i ever say how much i dont like asus motherboards??? I said it before.. I have had nothing but problems with any model i have ever bought.. funny thing is that it is the only brand that i have had major problems with..
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        if the CUV4X series is also affected, this may also apply to the Medion 2001 Mainboard (which is an Asus CUV4X-VM (microATX) just without the temp. monitoring)
                        kinda shocked though that they say the CUBX is affected. was one of the last Asus boards i've had (and still have somewhere) that was absolutely rock solid and glitch-free.. (much like the "legendary" Asus P3B-F slot 1 boards).
                        after that board generation, the quality took a massive nosedive (imho)..
                          • 31250
                          asus dont make the capacitor array, this could effect a lot more than asus and a lot more than motherboards!
                          clearly there is/was a big batch of defective arrays made.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Asus hasn't been good since the 90's.
                            CUSxx and TUSxx were right about when Asus turned bad.
                            - Dr Seuss
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              Can't disagree with that
                              P4P800-E Deluxe I have, has CRAPacitors in the VRM (OST or Elite, can't remember which), which get pretty warm, along with the Mosfets
                              Been considering a pre-emptive re-cap
                              • kaniki
                                • 514
                                #35
                                well, i guess i do have to give some credit to this one.. it is a good running system.... rock solid... and this was the first problem.. considering it is a P3.. that isnt all to bad. but like they say, it was about P4 and up that went to crap.. and all the systems i built with ASUS boards were all P4 and up. I had 1 board that I returned 3 times to get it fixed. they still could not get it right. after that i just gave up. what i find really funny is i have had decent luck with cheapo boards like elitegroup, biostar, MSI and gigabyte. They are all cheaper boards that i used, and no returns, but every ASUS board that i got, which had longer warranties and higher prices are the ones i always had problems with..
                                as for the list of bad boards or effected boards. I did not do any research to them. I just found that on the net and copy and pasted the info. I can not say to how much if them is actually faulty and / or if any are any good.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Some of Asus brand new boards [last 2-3 years] seem to be having stability problems because they went nuts using 100% polys 'for show' and they lowered ESR too far in the non-VRM areas of the board.
                                  If you don't have -some- ESR [or other resistance] then the board looks like a dead short to the ripple in the PSU and all that ripple current makes a bee-line for the mobo instead of getting filtered out before it reaches the board.
                                  Looks to me like Asus just stuck polys in were the designs called for electrolytics [rather than -designing- boards for polys from the ground-up] and that's pulling PSU noise [and ripple CURRENT] that shouldn't be there out to the chipset and slots.
                                  100% poly in the VRM is fine [we know this from experience] but taking a design that calls for [say] 6 lytics out by the slots and sticking in 6 polys is going to -encourage- ripple current to bypass the PSU caps and go through the board to the slots where the ESR [aka 'resistance'] is lower. - That's just going to heat-up the traces on the board as well as destabilize the voltages along the trace's path.
                                  - Dr Seuss
                                  • paul_h
                                    • Oct 2007
                                    • 86
                                    #37
                                    From the intel side of the fence, but I had an a7v133 and a nforce2 asus that were alright. They went bad after that for AMD though.
                                    The a7v133 was overclocked and overvolted it's whole life, so died a gallant death. The asus nforce2 was killed by an antec SP
                                    • kaniki
                                      • 514
                                      #38
                                      Originally posted by paul_h
                                      ...so died a gallant death. The asus nforce2 was killed by an antec SP
                                      did you give it a good salute and burry it with honers?? kinda reminds me of one of those movies where a knight dies defending a town from evil beings..
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        you could pull a c hegge and cremate it!
                                        sigpic
                                        (Insert witty quote here)
                                        • npielawski
                                          MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                          by npielawski
                                          I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                          I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                          10-15-2025, 01:53 AM
                                        • fredyjbi
                                          please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
                                          by fredyjbi
                                          I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
                                          if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
                                          I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
                                          if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
                                          On the type...
                                          07-09-2024, 11:28 PM
                                        • Scarfycake
                                          ASUS proart Studiobook h7600ZW; Had DC in port replaced and all the sudden it isn't charging but is the charging sign is on!
                                          by Scarfycake
                                          I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...
                                          05-21-2024, 08:16 AM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • eliemgh
                                          Dell Latitude 7410. The USB Type-C port is not working
                                          by eliemgh
                                          I have a Dell Latitude 7410 with an Intel i7 10th Gen CPU. The USB Type-C port is not working, and since it's the only charging port on the device, I'm unable to charge the laptop.
                                          I inspected the motherboard and found that the IC labeled TPS65988 had a short circuit. I ordered a replacement IC from Alibaba and replaced it. The short issue is now resolved, but the laptop still doesn't charge, and the Type-C port remains non-functional.
                                          After doing some research, I found out that the TPS65988 needs to be programmed after replacement in order to function properly.
                                          04-14-2025, 04:20 AM
