Internet problems...
  • stevo1210
    • Oct 2006
    • 4156
    I just bought an Asus eeepc for my brother. It;s the 701 series with a 4GB SSD hard drive and Windows XP home. I bought it second hand from a friend as he is selling everything off before joining the army. I got it for only $100 when these would retail for at least $200 second hand.
    Anyway, all is fine and well... but I can't connect to the net. Through wireless or wired connections, I still have no success. I ran IP config though the command line and it seems to be able to see my modem, the IP address and domain exactly the same as my desktop PC reports back to me.
    I have tried both Mozilla firefox and Internet explorer with no success.
    What do I do to fix this issue?
    Usually I'd just reinstall Windows, but this thing doesn't have a cd drive which is the problem.
    Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: Internet problems...
    Wait. is it possible to reinstall windows through the onboard card reader? it's classified as a hard drive in the "hard drives" section of the BIOS.
    • washu
      • Jul 2009
      • 310
      Any firewalls or "internet security" suites besides the built in Windows one? Remove them. Don't disable, uninstall.
      If that's not it try running Spybot in advanced mode and see if there are any LSP hacks.
      You can re-install from the card reader. A USB CDROM is the easiest. If you have a USB HD you can usually hook up a regular CDROM drive of the same type to it as a temporary solution.
      • stevo1210
        • Oct 2006
        • 4156
        There's only a Windows firewall and that's it. Even with that off, I still cannot connect to the internet. I do have an external 3.5" IDE HDD enclosure, and I shall use the controller on that for a cd rom drive. Good thinking mate! I didn't think of that earlier...
        Thanks.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          try other drivers
          i remember with same model could not connect the wireless using that stoopid driver utility. worked ok with windows utility
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Does it have the DNS information?
            Can you ping an external IP address?
            Ludicrous gibs!
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              make a bootable sd card... for a 700 series i'd recommend ubuntu netbook remix. test using that. windows is a poor choice for a 700 series.
              sigpic
              (Insert witty quote here)
              • stevo1210
                • Oct 2006
                • 4156
                I think I'll just use washus suggestion to run an external cd drive and reinstall windows... There's a bunch of registry errors on bootup which may also explain these issues?
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  need to nlite
                  4gb is very small
                  • kaniki
                    • 514
                    the other thing that nobody noted, usually there is a place to connect extra ROM's on the board and extra power supply connectors. If worse comes to worse, you could always open the computer up and manually connect a Rom inside, if nothing else, long enough to get windows installed. that is if the USB CD ROM does not work.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      nlited xp sucks, btw. thats why i advised the use of ubuntu netbook remix... it was designed for one of those
                      sigpic
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        why, there is lots of crap to remove. i have one friend still happy with nlited on 8gb eeepc
                        • washu
                          • Jul 2009
                          • 310
                          You don't need to nlite or any of that. Just make sure your disk is slipstreamed with the SP you want. SP2 or SP3 as you desire. That way you don't have the SP uninstall files wasting space. Then delete all the patch uninstall dirs after running windows update.
                          If you do that XP will fit just fine in 4 GB if you don't load a lot of extra stuff. You can always compress some files too. With the slow SSD on the 701 that might actually make some things faster.
                          • stevo1210
                            • Oct 2006
                            • 4156
                            I installed a copy of Windows XP Pro slipstreamed with SP2 on that eeepc today, only to find out that there was a Windows XP home CD in the box!
                            Anyway, I'm not going to reinstall windows again just because of that. Everything works now, but I have like 1GB of free space left lol.
                            Not to worry, there is a 4GB SDHC card in there so we have more room now.
                            • kaniki
                              • 514
                              one thing that you could think about doing for more room. If you dont have too much running on the computer (programs running in the background) and if you have large enough amounts of ram, you could always lower you amount of page file space and that could free up a little space if needed. but like i said, take into consideration the amount of ram before you do.
                              • NxB
                                • Feb 2009
                                • 1595
                                The 4g is spacious. The 2gb model is not. You even have to delete the install files for the drivers.
                                If you can ping but can't browse, its a DNS issue.
                                • stevo1210
                                  • Oct 2006
                                  • 4156
                                  Um. I dunno if this is a good idea... but I turned off the paging file/ virtual memory completely because there isn't enough room. Instead I will add 1GB of RAM to make it 1.5GB of RAM... is this recommended?
                                  So far, I see no perfromance differences with 512MB of RAM.
                                  • stevo1210
                                    • Oct 2006
                                    • 4156
                                    Actually, I take that back, I've had to re-enable the paging file, though only allowed to 128MB. This is because skype won't work...
                                      • 30956
                                      you cant turn it off anyway, you can only tell it your "preference",
                                      it will still use it sometimes.
                                      • kaniki
                                        • 514
                                        actually, yes you can turn off the page file.. but not really recommended.. I was saying more like make the minimum amount to something like 100 MB or something like that.. You can turn off the page file but if you do and you run out of RAM, then your system is going to crash. On the other hand, if you are just doing small thing like the internet with it, 1.5 gigs of ram is more then enough and the page file will not be needed. but with 512 MB, i would definitely leave it on. The way windows figures the page file is that it starts at 1.5 times the amount of RAM installed and goes up to 3 times that amount installed. So if you have 512 MB, then the page file should start out at about 768 MB and go up to about 1.5 GB or something like that.
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • HeatElectronics
                                          PS4 Slim SAD-002 Won't shut down. Only reboots...
                                          by HeatElectronics
                                          Hello Everyone! Im dealing with PS4 Slim SAD-002. It came with the SU-42118-6 error. I found F6202 damaged so i replaced it. I was able to run the update without problems. After some time i decided to turn it off and surprise! I can't turn it off. The issue happens when the console is about to shut down, the beep sound can be heard and it reboot into O.S. What could be causing that? I disconected ODD, power button, wireless antennas (in case some device was forcing it to turn on), also HDMI disconected without success. I also did a full and clean reinstall in another HDD (in case of disk damage)...
                                          05-09-2023, 11:24 PM
