Well I got a free flat screen monitor today. It is an Optiquest Q9 Model VS11201.This thing is made by Viewsonic I think. I just can't seem to get the brightness, contrast, and gama set just right to please me. What is so cool about a flat screen monitor that is pissing you off...LOL I have much more control over the monitor in my ATI 7000 software than I have at the buttons on the unit its self. Do I need to install drivers that may have come with this thing when new for it to work right? Went to the Viewsonic site and couldn't even find a listing for Model VS11201. In windows its listed as just a plug and play monitor. When I look at the choices windows Xp has in drivers for Viewsonic VS11201 isn't listed. I think I like my CRT better. It was getting weak but it didn't give me any grief.
Optiquest Q9 Monitor
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
"I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
John Paul Jones
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
Rod SerlingTags: None -
Re: Optiquest Q9 Monitor
Find out what its native resolution is, and set it for that. A monitor shouldn't need drivers. An older LCD monitor typically looks horrible in resolutions other than their native.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
The native resolution for this model monitor is 1280x1024. I agree with Topcat- keep this monitor at its native resolution. I found this info by searching for 'Optiquest VS11201'.Stupidity should be a crime, especially for drivers. I have NO patience for them.Comment
Yes I found that too. 1280x1024@60Hz. God my Icons look like stars in the winther sky! This isn't going to work at all! Is there a 17" or 19" flat screen that works well at 800x600??? Things do look good now but its all way to dang small. The Brightness is also busted on this thing. Contrast works well but the brightness does next to nothing.
Mark Twain
John Paul Jones
Rod SerlingComment
get used to the icons... its not that horrific... i did...sigpic
(Insert witty quote here)Comment
Set it in its native, and then tell windows to use large fonts and icons if you're having hard time seeing them. Trust me on this, once you get used to it, you'll never look back (no pun intended).Originally posted by Junk PartsYes I found that too. 1280x1024@60Hz. God my Icons look like stars in the winther sky! This isn't going to work at all! Is there a 17" or 19" flat screen that works well at 800x600??? Things do look good now but its all way to dang small. The Brightness is also busted on this thing. Contrast works well but the brightness does next to nothing.
Team : 49813
Join in!!
Team StatsComment
didn't think of that, sorry to be blunt in the last post.sigpic
No this thing isn't worth it. I'm back on the CRT. When I get the bug to mess with the flat screen again I will redo the fonts and Icons in windows. I just expected more. The fact that the Viewsonic took a five foot dive to the floor before it was given to me may play into it not working so well. Sometimes "new" is the way to go.
Mark Twain
John Paul Jones
Rod SerlingComment
Ok I got the Optiquest working good to 800x600 and below. It was locked in a RGB mode. The only problem is that the brightness is still almost non-functional. There are also some scratches, and smudges on the screen. Since these things are so cheap these days I don't think the cost of a repair job on the brightness would be worth it."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
Works for me. I can't see anyway so 800x600 is good. I'll bump it up if I'm watching a wide screen movie. Now how do you all see anything at 1280x1024??? At that resolution the icons look like potters marks on Old English Wedgewood. Text looks like fly shit on the screen. I guess I'll go get new glasses one day but my Doctor already said its nerve damage from MS, and it can't be corrected for."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
i would say that it depends on the size of the screen. I have a 17 CRT monitor and to me, the 1280x1024 is a bit too high, I can still read it, but just a tad bit too small for me.. but if i had a 17" to 19" LCD, then that might add enough for me to go to those resolutions. To me 1024x768 is a good size.Originally posted by Junk PartsI can't see anyway so 800x600 is good. I'll bump it up if I'm watching a wide screen movie. Now how do you all see anything at 1280x1024??? At that resolution the icons look like potters marks on Old English Wedgewood. Text looks like fly shit on the screen.
just a thought, but if your eyes are that bad, then did you ever think about just hooking up your computer to something like a TV instead of a monitor? might make things bigger for you so easier to read?Comment
One thing you can do if your video card supports it is run at half (technically quarter) resolution. It usually looks OK on an LCD as the pixels are simply doubled in each direction.
For your 1280x1024 monitor that would be 640x512 which might be too small. We have a user at work with severe vision problems. We run her 1920x1200 monitor at 960x600 and she can work fine.Comment
This thing measures 19" diag. I can deal with it at 800x600. Since I looked at the manual and set it up right its much better. Loading the real ATI drivers for my card helped too. Did some Netflix streaming this morning and it was fine. Did have some jerky motion but that same movie played off a DVD flowed just fine."It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
John Paul Jones
Rod SerlingComment
I'm going to try and swim in the deep end of the pool right now. Going to see if I can resize everything in windows so I can use the 1280x1024 resolution. There is also some color management software that came with this thing that I don't have yet. Some reds are displayed a little to to orange side on the desktop.
Mark Twain
John Paul Jones
Rod SerlingComment
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
by keepreadHi there!
Someone gave me their old monitor, it's Dell S2715ht.
The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs... -
by wattageHello Badcaps Community,
The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...-
by ant3202Hi Everyone
Lately I am experiencing the deja-vu incident on one of the led monitor like this.
https://www.badcaps.net/forum/troubl...lashing-on-off
The monitor is HP 27es LED Monitor
https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
The monitor will randomly blackout and display no signal and will recover again.
Sometimes need to power and off again to restore the display but...-
by Rick_1234Good evening, gentlemen.
I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
https://drive.google.com/file/d/1L6S...ew?usp=sharing
Things I tried
- Bought a new AC adapter thinking that was the problem but the problem...-
- Loading...
How do you even see anything, sure it is big but nothing fits on that resolution anymore.
