Optiquest Q9 Monitor
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Well I got a free flat screen monitor today. It is an Optiquest Q9 Model VS11201.This thing is made by Viewsonic I think. I just can't seem to get the brightness, contrast, and gama set just right to please me. What is so cool about a flat screen monitor that is pissing you off...LOL I have much more control over the monitor in my ATI 7000 software than I have at the buttons on the unit its self. Do I need to install drivers that may have come with this thing when new for it to work right? Went to the Viewsonic site and couldn't even find a listing for Model VS11201. In windows its listed as just a plug and play monitor. When I look at the choices windows Xp has in drivers for Viewsonic VS11201 isn't listed. I think I like my CRT better. It was getting weak but it didn't give me any grief.
    Mark Twain
    John Paul Jones
    Rod Serling
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Optiquest Q9 Monitor
    Find out what its native resolution is, and set it for that. A monitor shouldn't need drivers. An older LCD monitor typically looks horrible in resolutions other than their native.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • delaware74b
      • Apr 2009
      • 628
      The native resolution for this model monitor is 1280x1024. I agree with Topcat- keep this monitor at its native resolution. I found this info by searching for 'Optiquest VS11201'.
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        Yes I found that too. 1280x1024@60Hz. God my Icons look like stars in the winther sky! This isn't going to work at all! Is there a 17" or 19" flat screen that works well at 800x600??? Things do look good now but its all way to dang small. The Brightness is also busted on this thing. Contrast works well but the brightness does next to nothing.
        Mark Twain
        John Paul Jones
        Rod Serling
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          get used to the icons... its not that horrific... i did...
          sigpic
          (Insert witty quote here)
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16958
            Set it in its native, and then tell windows to use large fonts and icons if you're having hard time seeing them. Trust me on this, once you get used to it, you'll never look back (no pun intended).
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              didn't think of that, sorry to be blunt in the last post.
              sigpic
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                No this thing isn't worth it. I'm back on the CRT. When I get the bug to mess with the flat screen again I will redo the fonts and Icons in windows. I just expected more. The fact that the Viewsonic took a five foot dive to the floor before it was given to me may play into it not working so well. Sometimes "new" is the way to go.
                Mark Twain
                John Paul Jones
                Rod Serling
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  Ok I got the Optiquest working good to 800x600 and below. It was locked in a RGB mode. The only problem is that the brightness is still almost non-functional. There are also some scratches, and smudges on the screen. Since these things are so cheap these days I don't think the cost of a repair job on the brightness would be worth it.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • Sparky
                    High voltage
                    • Jan 2007
                    • 234
                    You use your PC at 800x600?? How do you even see anything, sure it is big but nothing fits on that resolution anymore.
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      Works for me. I can't see anyway so 800x600 is good. I'll bump it up if I'm watching a wide screen movie. Now how do you all see anything at 1280x1024??? At that resolution the icons look like potters marks on Old English Wedgewood. Text looks like fly shit on the screen. I guess I'll go get new glasses one day but my Doctor already said its nerve damage from MS, and it can't be corrected for.
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • kaniki
                        • 514
                        i would say that it depends on the size of the screen. I have a 17 CRT monitor and to me, the 1280x1024 is a bit too high, I can still read it, but just a tad bit too small for me.. but if i had a 17" to 19" LCD, then that might add enough for me to go to those resolutions. To me 1024x768 is a good size.
                        just a thought, but if your eyes are that bad, then did you ever think about just hooking up your computer to something like a TV instead of a monitor? might make things bigger for you so easier to read?
                        • washu
                          • Jul 2009
                          • 310
                          One thing you can do if your video card supports it is run at half (technically quarter) resolution. It usually looks OK on an LCD as the pixels are simply doubled in each direction.
                          For your 1280x1024 monitor that would be 640x512 which might be too small. We have a user at work with severe vision problems. We run her 1920x1200 monitor at 960x600 and she can work fine.
                          • Junk Parts
                            Court Jester
                            • Jun 2006
                            • 8953
                            This thing measures 19" diag. I can deal with it at 800x600. Since I looked at the manual and set it up right its much better. Loading the real ATI drivers for my card helped too. Did some Netflix streaming this morning and it was fine. Did have some jerky motion but that same movie played off a DVD flowed just fine.
                            Mark Twain
                            John Paul Jones
                            Rod Serling
                            • Junk Parts
                              Court Jester
                              • Jun 2006
                              • 8953
                              I'm going to try and swim in the deep end of the pool right now. Going to see if I can resize everything in windows so I can use the 1280x1024 resolution. There is also some color management software that came with this thing that I don't have yet. Some reds are displayed a little to to orange side on the desktop.
                              Mark Twain
                              John Paul Jones
                              Rod Serling
                              • NxB
                                • Feb 2009
                                • 1595
                                I always try to use the highest res possible and just bump up the size of the icons/fonts. My CRT is at 1920x1600.
                                Also can't really stand 60hz refresh rate on most screens. I can pick it out on any crt monitor.
                                  by momaka
                                  03-15-2023, 10:17 PM
                                • wattage
                                  by wattage
                                  Hello Badcaps Community,
                                  07-13-2025, 04:41 PM
                                • ant3202
                                  HP 27es - LED monitor - Monitor Flashing On - Off
                                  by ant3202
                                  Hi Everyone
                                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                  https://www.badcaps.net/forum/troubl...lashing-on-off
                                  The monitor is HP 27es LED Monitor
                                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                  The monitor will randomly blackout and display no signal and will recover again.
                                  Sometimes need to power and off again to restore the display but...
                                  03-20-2025, 07:30 PM
                                • Rick_1234
                                  by Rick_1234
                                  Good evening, gentlemen.
                                  Things I tried
                                  06-22-2024, 04:44 PM
                                  Wise Wing F199 19'' LCD monitor - recapped
                                  by momaka
                                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                  When I saw the Craigslist post, I wasn't...
                                  08-24-2020, 10:58 AM
