best cheap/free scores 1.1
This is a sticky topic.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: best cheap/free scores 1.1
    TV testing (still in the back of a van, I haven't got to moving the beast yet):
    All was done using HDMI from my laptop.
    Other than some flicker at 1080P (less noticable at 720P), it looked good to me. The tilt issue btw was fixed with a settings adjustment.
    Comments?
    sigpic
    (Insert witty quote here)
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      #1282
      dont mess with tilt,convergence,purity till you get it out of the van.
      i once swapped a crt in the back of a truck and delivered it to the customer.
      they saw it play fine on the inverter.a few days later they got around to hooking it up and it looked awful.sure enough we set it back in the truck and it looked normal.
      took it back into the customers place and set it up again.then it was fine.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I know, it's an easy adjustment. TBH there is another adjustment out as well (whichever flattens the edges, it's kinda curvy at the top and bottom)... but I'll fine tune it when it's out of the van.
        sigpic
        • TheSolarShed
          • Apr 2012
          • 19
          • South Africa
          #1284
          Re: Your Best Dumpster Finds
          Picked up these from the rubbish pile a few months ago...
          A 4W Coherent Enterprise II kryton ion laser:
          And a 60mW Spectra-Physics Model 127 helium neon laser:
          I dare not power up the 4W laser for fear of destroying my eyesight, and my house's wiring.
          TheSolarShed
          Project CapRep
          Good cap replacement finder
          2354 caps in database so far
          • Behemot
            • 4845
            • CZ
            #1285
            Anything over aprox. 1 mW can damage your eye permanently so even that 60 mW is very dangerous. The 4W one is so powerfull it can burn your skin or other things.
            • TheSolarShed
              • Apr 2012
              • 19
              • South Africa
              #1286
              Yeah, I was very cautious around it and definitely didn't play with the beam. It's a Class 3B.
              As for the 4W laser, it requires water cooling and the power supply is 10kW. Yes... These krypton ion lasers are at most 0.04% efficient, apparently! I want to at least power up the unit to get the run time from it, but I worry that the inrush current alone will trip breakers and melt switches. >.<
              TheSolarShed
              Project CapRep
              • Behemot
                • 4845
                • CZ
                #1287
                Man you can possibly built a cutter with such thing…yeah, will need much work and you possibly cannot do it alone, but it's definitelly worth it…
                • splur
                  • May 2014
                  • 9
                  TheSolarShed
                  4W laser?! What in the world, who throws that out into a dumpster!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    http://www.ebay.com/itm/271619041755
                    Not my best score, but considering that my Weller W60-P took a hike (in a box somewhere) and my old stand's base rusted to oblivion (I had rigged it using the lid to an old gateway (newton) PSU), I think it's good. from the pictures, It looks like either another W60-P or a W100P (beefier 100W version), as the end of the elment is grooved like the end nut of said models (uses temp controlled tips). Besides, it's a heavy cast iron base... heck yeah!
                    Edit- Apparently they redid the base design at some point and the new version of the same model is $15 new... BUT, the W100P is specced as the matching iron and has a larger element barrel (and tips?) which this seems to have... New W100P's are $55-$75 new, so IMHO this is a score.
                    sigpic
                    • Compgeke
                      • Feb 2014
                      • 524
                      Picked up some goodies today from a couple places. Thankfully everything fits into the box (except the laserdisc player).
                      All together I got:
                      Pioneer CLD-980 Laserdisc Player
                      Quantum Viking II 9.1 gig hard drive with the Adaptec AHA-2940
                      Boxed and sealed copy of Kings Quest
                      Boxed copy of Civilization (1)
                      Office 2000 Standard Upgrade
                      Photoshop Elements 3 for Windows
                      A bunch of shellac records, a couple 7" 4-track tapes and some blank casettes
                      Star TSP143 thermal receipt printer w/ cutting blade in it
                      Partner Tech Corp CD7220 RS232 20x2 VFD
                      and a Thinkpad R52.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        FAIL!
                        It's an old W60P that fell apart due to rust when I tried the change the tip out... TBH I had to do some work with a vice and vice grips to even get anything to budge. IDK how one makes an iron rust like that... like salt water or bleach got caught up in the tip holder and rotted that and the end nut to oblivion...
                        The seller gave me a full refund (I only asked a partial since the stand is fine) and isn't requiring a ship-back... So it's a win but I sorta feel like a schmuck. And I STILL don't have in-house soldering capabilities (unless my lost box turns up, one can pray).
                        sigpic
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Back on topic:
                          $5: Canon Powershot A610 w/factory case. Decent shape, needed the lens cover rebuilt (which I did). Not a fan of the lens cover design but seems to be a nice (albeit battery hungry, 4xAA) design otherwise. The only other issue is the preview switch doesn't quite work (stuck in shooting mode, could be worse).
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Back on topic:
                            Good news: Got the bad switch to work
                            Bad news: the lens cover went to shit, went to re-rebuild it, and a spring flew off to never never land. I ended up pulling the rest of the cover springs/covers and storing them as extra parts, as this camera is honestly too bulky to use as a pocket camera (other than the flip out screen I don't see anything better than my A540 other than it not having a broken battery latch)
                            (now if only old DSLRs weren't still $$$ on ebay...)
                            sigpic
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16958
                              My source for goodies is sending a goodie box of stuff in trade for some caps.....pretty useless crap except for this: Supermicro X8DTI motherboard!!
                              http://www.supermicro.com/products/m...5500/X8DTi.cfm
                              <--- Badcaps.net Founder
                              Badcaps.net Services:
                              Motherboard Repair Services
                              http://folding.stanford.edu/
                              Team : 49813
                              Join in!!
                              Team Stats
                                • 31185
                                lol
                                the ram suppliers are going to love you!
                                i'v not seen a board populated like that since i worked on SGI stuff!!!
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  You and SM boards... lucky bastard.
                                  sigpic
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    They sent me one last year too, its still in use in my office machine, dual LGA771 5400 series Xeon workstation board (no onboard video). This one will do the 5500 and 5600 series, LGA1366. It is more of a server board, has onboard video....but also has a 16x PCI-E, so I'll be able to run a video card of my own and disable the onboard. I'm sure I'll be able to pound it into a workstation.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Mine still has SLI so at least I have you owned in one place, LOL.
                                      Although I'm still using DDR1 (albeit PC3200 FB 2GB's)
                                      sigpic
                                      • Topcat
                                        The Boss Stooge
                                        • Oct 2003
                                        • 16958
                                        The one I got last year was a brand new X7DWA-N, still in its original box. I stuck a pair of quad core 3GHz 1600MHz FSB E5472 Xeons with 16gb DDR2 FB memory. it's been a solid system....and will continue to be, its not going anywhere. If this board is good, which their stuff tends to be good, I may scrub my paxville build and fit this in that other SM case...you know, the one with the spare X5DAL...
                                        Team : 49813
                                        Join in!!
                                        Team Stats
                                        • Topcat
                                          The Boss Stooge
                                          • Oct 2003
                                          • 16958
                                          Holy dogshit!!! the package arrived today....along with the X8DTI, there is another X7DWA-N in there they didn't tell me about. Brand new in its retail box!! God I love these people!!! Totally wasn't expecting that!! These cost me about $100 bucks worth of caps....based on the site prices anyway.
                                          Yup, that decided it, totally dumping the paxville build!
                                          Team : 49813
                                          Join in!!
                                          Team Stats
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
