XP installation won't start
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: XP installation won't start
    for a windows partition utility that could do what you want, well sorry to say but:
    there is none... if you edited the partition in windows you would kill the system. its kinda the same reason why you cant have a car jump-start itself. you have to boot form another source. just use a live linux cd (use an older vid card if you must) and edit it there. esay and effective.
    or find somebody with an sp2 cd and use that but enter your code. perfectly legal.
    sigpic
    (Insert witty quote here)
    • pentium
      • Mar 2006
      • 2778
      Okay, I gave up asking and went out looking so I got Partition Magic...censored censored censored...and now everything is fixed. Now I just have to wait for the replacement ram to arrive an a few weeks time.
      This was painful.
      Find Nedry!
      Check the Vending machines!!
      <----Computer says I need more beer.
      • Newbie2
        • Sep 2005
        • 885
        Okay good thing you're okay now pentium.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          sorry i tried to help.
          sigpic
          • NxB
            • Feb 2009
            • 1595
            #45
            Nobody mentioned hiren's boot cd? It has partition magic, acronis disk director and memtest 2.xx. 9.8 also has winPE on it.
            Acronis DiskDirector and Partition Magic will edit live partitions if you get them. Even your boot partition.
            As for slipstreaming XP, I use nlite. It walks you through it. Everything is SP3 and IE8 with common sata AHCI drivers. I wish I could integrate the .NET packages but it won't let me. I've never burnt any coasters but I did make MCE cds that couldn't install media center. So i *can't* slipstream MCE.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              he didn't want to burn a cd for some reason
              • bgavin
                • Jan 2007
                • 1355
                #47
                Originally posted by pentium
                WHY
                IS
                NOBODY
                LISTENING
                TO
                ME?!
                I DON'T WANT NO FUCKING LINUX. I DON'T WANT TO BURN ANY MORE GOD DAMN CDS, AND FOR FUCKS SAKE, I AM NOT REINSTALLING WINDOWS.
                I JUST WANT MY 130 FUCKING GIGABYTE PARTITION RESIZED BACK TO THE FULL TERABYTE THAT IS AVAILABLE ON THE GOD DAMN DRIVE. WHY IS THIS SO GOD DAMN HARD TO UNDERSTAND??!
                The solution has been provided for you.
                You can buy, or steal, Partition Magic 8.05.
                Put it on a diskette, do the Error Check (always!), then resize.
                If you try this on an obsolete machine that does not have the BIOS extensions, you will be limited to 137gb. This is a workstation limitation.
                I own PMagic and use the DOS version constantly.
                As long as you disabled the Defective Sector check first, and do the error scan first, it will do the job. The defective sector check is enabled by default, and will increase you run time to a few days.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  the linux was only to resize the windows. you don't have to install linux. only boot it and use the partition manager.
                  besides, what do you have against linux?
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    like i said, pentium, you cannot edit a partition that you are booted from. it is like performing open heart surgery on your self. it just is impossible. why are you scared of a re-install if you just installed recently. use your head for 5 min.
                    besides, why can't you burn a cd. its easy. all you need is a burner. the software is free- try infra recorder
                    it will burn the iso files no problem.
                    sigpic
                    • shadow
                      • Feb 2007
                      • 732
                      I think the main reason why I refuse to slipstream is that not only are CD's getting hard to find and I only got 20 left on my spool of 100 and I don't want any b0rked burns
                      ratdude747, I assume this is why he did not want to burn a cd.
                      The reason why he did not want to reinstall was because he installed Windows from an old disk which had SP1 integrated. He could only install it on a partition that was 130gb in size and after the install process he wanted to resize it to the maximum 1tb (his whole hard drive).
                      Hence why reinstall if he would have the same problem.
                      I assume that the old version of Windows did not support such large drives?
                      • 370forlife
                        Large Marge
                        • Aug 2008
                        • 3112
                        I can go to staples and get a stack of 100 verbatim cd's for $15.
                        Don't see why they are getting hard to find. Even so a dvd-rw drive is only about $22 now a days on newegg...
                        • Newbie2
                          • Sep 2005
                          • 885
                          I am still seeing at least 50 pack blank CD-R discs selling for a decent price around the stores I go to.
                          My gaming PC:
                          • weirdlookinguy
                            • Sep 2007
                            • 1638
                            #53
                            CD-Rs are plentiful 'round these parts.
                            • NxB
                              • Feb 2009
                              • 1595
                              #54
                              A hiren's CD is worth the burn even if you have 2 CDRs left.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                i agree.
                                btw, is hiren's cd free? i found a questionable site called hirensbootxd.net where i downloaded a zip file. had an iso and some keyboard patch crap. i use linux so no virus info. some advice onhweter i got lugit or luShit.
                                sigpic
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  #56
                                  hirens is free.
                                  it is considered "warez" due to its contents.by all means scan the disk after you burn it in case some clown tried to infest it with malware.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    i checked the iso. looks ok.
                                    sigpic
                                    • digge
                                      • Apr 2006
                                      • 296
                                      #58
                                      Know you already fixed your problem, but for future reference you can download the gParted Linux live cd from http://gparted.sourceforge.net/ for a free alternative.
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        OP didn't want to burn a cd.
                                        • ratdude747
                                          Black Sheep
                                          • Nov 2008
                                          • 17136
                                          op wanted to do the impossible.
                                          sigpic
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • Junior††
                                            PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                            by Junior††
                                            Good Afternoon fellas,
                                            Issue:
                                            Disc is showing as not supported when a disc is put in.
                                            Here's what I've done, you can skip this if you just wanna know the question:
                                            - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                            - reflowed the disc drive connector
                                            -reflowed the chip in question (shown on image)
                                            - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                            Question:
                                            I...
                                            02-19-2025, 12:48 PM
                                          • eltano4i20
                                            [HELP] SAMSUNG NP270E4E-K01AR
                                            by eltano4i20
                                            1) Error trying to enter the BIOS
                                            --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                            Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                            BOOT PRIORITY ORDER (img-05)
                                            1- Windows Boot Manager
                                            2- SATA HDD
                                            3- NETWORK
                                            4- Debian
                                            2) Error trying to access the BOOT MENU
                                            --> I restarted the notebook and pressed [F10] but the BOOT...
                                            07-04-2025, 12:39 AM
                                          • duwane
                                            A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                                            by duwane
                                            Hi All.
                                            Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                                            The issue:
                                            Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                                            10-26-2022, 07:02 AM
                                          • AppleLover123
                                            Acer Aspire A515-52G-53PU crashing during windows installation
                                            by AppleLover123
                                            Hello Guys,
                                            got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
                                            I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
                                            The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
                                            when i install windows 10 it goes trough until the restart and at "getting devices ready" it...
                                            03-08-2025, 05:05 AM
