XP installation won't start
  • pentium
    • Mar 2006
    • 2778
    Well after a bit of a squabble regarding ram I'm finally ready to start installing stuff onto my system.
    Unfortunately, I can't even get XP installed.
    I insert my XP Pro SP2 disc, it checks my system config and I get the blue setup screen with WINDOWS SETUP in the corner and that's it. I wait and wait and nothing happens.
    I thought the disc could be bad or something so I tried my older pre-SP1 XP pro disc and again, blue setup screen with WINDOWS SETUP in the corner and nothing else.
    I then went and tried my XP Home disc and still no dice.
    I then tried live booting ubuntu and that went well until my monitors decided to not like my monitors and just give me a blinking green/amber status light but it did at the least start a live boot session (I heard the classic ubuntu login tune so it was getting to a live session desktop).
    As a last resort, I tried my Windows 2000 Pro disc and success! It gets into the installer no problem.
    I'm totally confused now. What would be preventing the installer from starting? I was having issues with the ram earlier (sometimes it was passing memtest 86 +, sometimes it was not) but I thought I combed that out after I cleaned the contacts. The system is at least not hanging at the POST anymore.
    Find Nedry!
    Check the Vending machines!!
  • pentium
    • Mar 2006
    • 2778
    Re: XP installation won't start
    Well, the Windows 2000 installation went flawless so that is at least working.
    Still, why no Windows XP?
    Find Nedry!
    • Newbie2
      • Sep 2005
      • 885
      Can you do another Memtest86+ test if you haven't already?
      The RAM might actually be bad beyond the dirty contacts that you've dealt with.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • Newbie2
        • Sep 2005
        • 885
        Also, what power supply are you using?
        L&C, Deer, Powmax, or other generic lightweight power supplies might cause odd issues regarding system reliability.
        My gaming PC:
        • lucky13
          • Aug 2007
          • 412
          Pentium,
          I trust you have already checked for bad caps near the memory controller?
          Do run another Memtest like Newbie2 suggested. Run overnight or at least 10 passes.
          I experienced something similiar before and it was flakey RAM. For some reason, XP install put more stress on the RAM.
          • Wizard
            • Mar 2008
            • 2296
            try prime95 torture test.
            Also, I ran into similar problem with dodgy optical drives. Replace it and is all well. Ditto on power supply and cooling.
            Cheers, Wizard
            • pentium
              • Mar 2006
              • 2778
              A: I'm running a Corsair VX550 PSU. There's more than enough juice being delivered.
              b: there are little OST caps around the ram as well as a few larger green caps from which I can only make out "KZE" on them. the VRM seems to use UNC as well. Not too too bad but it sure isn't like my old K7N2. It had rubycons everywhere.
              If bad comes to worse, I can RMA and return all three sticks and get replacement ones mailed to me.
              I'll fire up memtest again and let it run for the night and get back to you.
              I know the opticals are good. I use them in my last system and as stated, just used them to install Windows 2000.
              Also, I really can't cool this system down much more. Outside the house it's like 40c, inside the case is 43c and the CPU is hanging at 61c. I'm doing whatever I can to get air into the case and onto the hardware that needs it the most.
              Find Nedry!
              • Wizard
                • Mar 2008
                • 2296
                Hmm.. That's hotter than hades. At least managed to keep things cool.
                I had used memtest it does it's job but it is not very hard on memory. I use prime95 torture test mode that stresses cpu and memory at same time. This is where much of problems show up. I used prime95 on dimension 8300 to test if my recap job was sufficient and was not good (errors) because of flying wires remember that? Redid this correctly with quality caps that fits. Passed it.
                • Newbie2
                  • Sep 2005
                  • 885
                  Try testing one stick of RAM at a time and see if your XP installation issue remains with each individual stick of RAM. It might help find the faulty stick (or sticks) of RAM.
                  My gaming PC:
                  • kikkoman
                    • Jul 2007
                    • 691
                    i've seen USB keyboards and/or the "USB compatibility" in the BIOS cause this.
                    alternatively you could boot into a WinPE environment (such as ERD commander) and start the setup from there.
                    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                    • bgavin
                      • Jan 2007
                      • 1355
                      There are some boards where Memtest fails and is not a memory problem. KG7 boards from ABit, 8K7A EpoX boards, etc, all based on the AMD-761 chipset.
                      That aside, any modern board should pass Memest86+ for 24 hours, error free. If not, you have BSOD 0x50 and other treats waiting in the dark to jump you.
                      XP has a super-set of drivers over Win2000, so if it installs on W2K, then XP should have the driver.
                      I assume you are not hung in something like SATA controllers, where you require an F6 diskette and driver. There is a huge caveat here, if you are using Intel MSM drivers. The published layout and required diskette layout are different. If you do not have the drivers installed in BOTH Root and \$OEM$\TEXTMODE, the installation will fail.
                      If you suspect hardware, boot a BART-PE cdrom or other self-contained OS on a cd. This will tell you if XP or the hardware is the cause. You can disable devices in CMOS before installing XP, to reduce its driver interaction.
                      • Newbie2
                        • Sep 2005
                        • 885
                        If you're desperate to get Windows XP on your computer, I'd suggest trying to upgrade Windows 2000 to XP Pro in Windows using the upgrade install option if you can do that.
                        My gaming PC:
                        • pentium
                          • Mar 2006
                          • 2778
                          I have a pretty good feeling that it is the ram that is causing me all my grief. Not the SATA controller and probably not the BIOS settings.
                          Find Nedry!
                          • pentium
                            • Mar 2006
                            • 2778
                            Stupid time limit...
                            Yep. I threw in a spare Crucial 512mb stick and the XP installation started right up no problem. The problem is indeed the result of bad ram.
                            Find Nedry!
                            • weirdlookinguy
                              • Sep 2007
                              • 1638
                              Your monitor is a Trinitron, isn't it?
                              • pentium
                                • Mar 2006
                                • 2778
                                Sure is.
                                20" IBM P201 with a Trinitron tube.
                                Find Nedry!
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  looks like 2 bad sticks.
                                  try the middle one by itself.
                                  when you get time test one at a time.
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    Even if I only have one good stick, all three sticks have to be returned in the RMA process so I'm not going to bother with finding out which sticks are bad and which one is good.
                                    Find Nedry!
                                    • Newbie2
                                      • Sep 2005
                                      • 885
                                      Hopefully your RMA process is quick and the replacements are not bad too.
                                      My gaming PC:
                                      • bgavin
                                        • Jan 2007
                                        • 1355
                                        Please upgrade your Memtest
                                        Your test version is 1.65 and v2.11 is current.
                                        There are newer releases for a good reason.
                                        • Junior††
                                          PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                          by Junior††
                                          Good Afternoon fellas,
                                          Issue:
                                          Disc is showing as not supported when a disc is put in.
                                          Here's what I've done, you can skip this if you just wanna know the question:
                                          - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                          - reflowed the disc drive connector
                                          -reflowed the chip in question (shown on image)
                                          - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                          Question:
                                          I...
                                          02-19-2025, 12:48 PM
                                        • duwane
                                          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                                          by duwane
                                          Hi All.
                                          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                                          The issue:
                                          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                                          10-26-2022, 07:02 AM
                                        • eltano4i20
                                          [HELP] SAMSUNG NP270E4E-K01AR
                                          by eltano4i20
                                          1) Error trying to enter the BIOS
                                          --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                                          Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                                          BOOT PRIORITY ORDER (img-05)
                                          1- Windows Boot Manager
                                          2- SATA HDD
                                          3- NETWORK
                                          4- Debian
                                          2) Error trying to access the BOOT MENU
                                          --> I restarted the notebook and pressed [F10] but the BOOT...
                                          07-04-2025, 12:39 AM
                                        • AppleLover123
                                          Acer Aspire A515-52G-53PU crashing during windows installation
                                          by AppleLover123
                                          Hello Guys,
                                          got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
                                          I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
                                          The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
                                          when i install windows 10 it goes trough until the restart and at "getting devices ready" it...
                                          03-08-2025, 05:05 AM
                                        • m4a2t0t
                                          Disc caps
                                          by m4a2t0t
                                          Can I replace a ceramic disc cap with a multilayer ceramic cap? I cant even find .047 uf disc caps at digikey, mouser or newark. The places I do find them want anywhere from 25c to $3 each, at any quantity, plus shipping....
                                          01-18-2024, 10:00 PM
