Some serious security bug in INTEL CPUs?? Since Westmere possibly
Re: Some serious security bug in INTEL CPUs?? Since Westmere possibly
They don't package the updates individually anymore.
https://blogs.technet.microsoft.com/...ows-7-and-8-1/
https://blogs.technet.microsoft.com/...d-windows-8-1/"The one who says it cannot be done should never interrupt the one who is doing it."Comment
So, my strategy going forward should be to apply monthly rollups -- after first imaging the system to give a rollback point -- until I encounter something that I "don't want". Then, fix that point in time as the last practical update for the OS?
[IIRC, 7even is nearing EOL so I won't have to worry about this for much longer; I'll just avoid any application updates that require a newer OS!]Comment
Probably because it's just you assessing your personal risk and being comfortable with it. E.g., I won't even bother installing any patch as most of my machines aren't "exposed" for the exploit to take hold.
OTOH, if you were a corporation that had product based on those devices in the market, you'd be worrying about your financial and legal exposure. Imagine someone using this exploit to hack all the PC-based cash registers that are in use and being the company that manufactured them!
Or, if you had 3000 seats running on that hardware in your business and suddenly had to worry about all of them being potentially compromised. Or, all being potential attack vectors to other systems in your organization.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I suspect it is a real nightmare for those folks -- deciding whether to apply the patch, applying it and then adjusting the "planned" normal equipment upgrade schedule to reflect this "bump" (maybe there will be a sudden surge in equipment discards -- could be a windfall for me, personally!)
Have to feel sorry for the folks who do that sort of thing for a living; always being the dog's tail...Comment
I was aware of the monthly rollups (I use them to expedite building W7 systems -- instead of applying hundreds of individual updates like the XP days). But, I had thought one could still "fetch" individual updates, as well. E.g., via WUA.
But seriously this is getting quite off topic now!"The one who says it cannot be done should never interrupt the one who is doing it."Comment
OTOH, if I naively install an update that decides to FORCE me to move to 10 (or other), then I need to be sure I can roll that back -- i.e., by having saved an image (not a "restore point" cuz the OS still has control over that!) prior to applying the unfortunate update.
As most MS updates seem to be for "security" and to protect from external/remote exploits, I can gladly live without them (machines are air-gapped/not routed). I'm already living with the inherent deficiencies of the OS's that MS hasn't considered important enough to fix ("just reboot!")Comment
Full details and research papers and source code: https://spectreattack.com, Spectre Attack.pdf research paper
Meanwhile, Raspberry Pi is not affected. Hurrah.Comment
I suspect my SPARCs are troublefree -- but, I don't want to sit next to a spaceheater just to browse the web!Comment
AMD CPUs are affected by Spectre, so you need to switch to VIA.Comment
Which MIPS CPU? The scalar ones should be safe from Spectre as well. I don't know about the R10K, someone should test one of these (which may be tricky as the code currently is specially for x86/amd64 SSE2 right now).
I've been trying to find someone with an Alpha AXP to try Spectre, which may also be affected. However, 486's should be safe as it's a scalar processor...Comment
I also have an N270 Atom in my eeePC. I'm glad, it doesn't need to get any slower than it already is...
I need to rebuild all its binaries too, ugh. The pains of running a source based distribution that decided to make an across-the-board change...
Yes, the R10K will need to be tested. I think the R4000/R4400 were scalar and shouldn't have these issues.
And I just patched my i7 (linux) for Meltdown... it's not dastardly slower, fortunately. Unsure about Spectre yet. On the good side, machines that don't constantly download code (or is forced to download code) is "safe" for now - so fixed job (i.e. not ssh or other shell box type) servers are OK to leave unpatched temporarily. Client machines and shell boxes, however, must be patched ASAP as likely they will be fed new code on a continual basis (like javascript...)Last edited by eccerr0r; 01-07-2018, 03:53 AM.Comment
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Hi guys!
I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
I have attached the Dump of my machine.
S/N: SRW2K4J
Reg Model: DCTR...-
09-27-2024, 02:43 AM -
by ducky29Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
Thanks in advance.09-23-2024, 03:56 PM -
by ugamazingI have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%... -
Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
tags:...07-28-2025, 07:26 PM -
by EnderFFXHello!
I bought a P15 Gen 1 as defective and without much hints to its history.
Was sold as "cannot start, weird stuff on screen".
So i bought a replacement GPU (2070 Super) and BOOM it worked immediatly, i got lucky.
Only that error 2203 every single time with beep loud enough to wake the kids is annoying.
I sincerly tried to read up and got a U One to work (3.5.40, that update tool will always say 3-5-40 is latest on cloud althiugh i ran it 3 times, it updated once from 3.5.30 to .40. Is that a problem? P15 Gen 1 is old anyways...)...-
Channel: BIOS Requests ONLY!
- Loading...
