Some serious security bug in INTEL CPUs?? Since Westmere possibly
  • Stefan Payne
    • 1267
    Re: Some serious security bug in INTEL CPUs?? Since Westmere possibly
    Originally posted by stj
    let me give you a quick abreviated version.
    if you use Intel and/or m$ your pretty fucked.
    if you use AMD with Linux you probably have a smile on your face.
    Ähm, no.
    From what we know right now, it seems that it isn't as bad as with Linux.
    The Security Scientists said something like everything under Linux could be read and most things under Windows.
    Most is a bit better than everything.
    • Stefan Payne
      • 1267
      Originally posted by lti
      AMD CPUs are affected by Spectre, so you need to switch to VIA.
      Spectre 1 but that is something that hits ALL CPUs with speculative excecution...
      But _NOT_ Spectre 2 and not Meltdown...
      So it would be nice if we would stick to the facts and not try to downplay this shit.
      • diif
        • Feb 2014
        • 6978
        • England
        #63
        Originally posted by eccerr0r
        I also have an N270 Atom in my eeePC. I'm glad, it doesn't need to get any slower than it already is...
        Lol, you're not kidding. It was an amazing bit of kit back in the day though. Mobile computing anywhere and it's wasn't the weight of a brick.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          #64
          Best describes my 2008 Core 2 Quad "Kentsfield" Q6600 at around 3.0 Ghz. LOL.
          When it comes to heating the house, I use the BladeServer (dual 3.6GHz Xeon, 8GB RAM and 144GB of disk space per blade, 14 blades). Have to unplug the clothes dryer to use the damn thing
          I think each of the fans ("blowers") draws 50W...
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            #65
            No, it also relies on having access to a sense of time and the ability to run arbitrary/untrusted binaries directly on the hardware. Deny any of these and the exploit falls apart.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Honestly it's only firefox that's really miserable on it now. But I still find use in it as a shell box with a normal keyboard (granted, it's still a bit small for my fingers, but much better than a touchscreen virtual keyboard that wastes screen real estate...)
              I do wonder how much slower it'd get if I set up full disk encryption on it, along with the pending recompile of all binaries so I can keep up with the linux distribution (it's the cost of not requiring a reinstall every few years and stlil stay up to date)...
              • RJARRRPCGP
                • Jul 2004
                • 6304
                So you're in the Americas and it uses 240 V input? (or 220 V, maybe 208 V, if the poco you have, has an old transformer, IIRC)
                In the Americas, at least north America and central America, (probably) use 2 120 V legs for 240 V.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • Curious.George
                  • Nov 2011
                  • 2305
                  • Unknown
                  #68
                  In most american homes, the only places to conveniently access BOTH legs are:
                  • electric stove/range (if you cook with electric)
                  • air conditioner (typ central air as MOST window units are 110)
                  • clothes dryer (if you don't use gas)
                  A (central) air conditioner is a dedicated branch circuit and won' t have an "outlet" that you can conveniently access.
                  The outlets behind the stove/oven and dryer require moving a large appliance to gain access. Most homes can live without a functioning dryer (AND a dryer that has been moved away from the wall to gain access) but pulling the stove/oven out usually meets with some stiff resistance (from female household members).
                  Some homes are wired with 12/3 w/GND in their kitchens. As such, you can conceivably access both legs from any outlet (half of the outlets are wired to one leg while the other half are wired to the other -- a net saving in copper). And, the countertop branch circuits must be 20A so this ensures you can feed the 2KW power supply in the server. But, any semi-permanent arrangement (i.e., something that you could use, again) like this would probably raise lots of eyebrows with building inspectors (and fire marshalls in the event of a fire... in someplace like a KITCHEN! )
                    • 31200
                    if you do your own wiring, fit some 16A CEE17 connectors.
                    http://cpc.farnell.com/pce/113-6/16a...skt/dp/PL15600
                    http://cpc.farnell.com/pce/313-6/p-m...30v/dp/PL15608
                    http://cpc.farnell.com/pce/013-6/plu...30v/dp/PL15567
                    i just picked up a couple of IP67 ones for the garden
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      #70
                      It's not a question of having the skillset and components to "make it work" but, rather, the legal/liability consequences of doing things that aren't to Code.
                      Of course, you can do damn near anything you want inside your home -- no one is going to come knocking to inspect it! OTOH, have a fire or similar and you can't roll back time to undo those Code violations so they aren't visible to the insurance/fire "incident" inspectors.
                      [Of course, there's a REASON for all those Code requirements/constraints so you should be asking yourself, "what do the writers know that I don't?"]
                        • 31200
                        code??
                        those are globally recognised standard connectors with all the usual aprovals.
                        go down to your nearest McDonalds and see them hanging from the ceiling.
                        (just dont eat the "food")
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          #72
                          code??
                          Doesn't matter if the components are NEMA, etc. There are use questions involved.
                          E.g., I wanted to put a 220V 60A outlet by the air conditioner compressor and a "plug" on the end of the cable to the compressor. Plug the compressor into the outlet, arrange for the outlet to be encased in a weatherproof housing, etc.
                          Then, put a similar plug on our electric kiln.
                          When we wanted to use the kiln, unplug the compressor and plug the kiln into the circuit. Instead of running a separate circuit for just the kiln (which is rarely used).
                          Electrically, everything is kosher -- kiln doesn't draw more than the branch circuit is rated, grounding issues are correct, weatherproofing, etc.
                          But, local Code doesn't allow this. Compressor must be on a dedicated circuit... a circuit dedicated to the compressor (not "generic 220V 60A loads").
                          Likewise, wanted to put an electric "instant" hot water heater located under the sink on the kitchen circuit. Had to run a separate circuit for it as the counter circuits are not to support any "fixed appliances".
                          In each case, everything would work as expected, circuit breakers (and GFCI's) would provide required protections, etc. but Code doesn't allow.
                          I am free to ignore that and do as I please -- until something goes wrong and I'm found to be out of compliance (will insurer pay if signs of obvious code violations? how long will city give me to have a LICENSED electrician bring things up to Code? will they allow occupancy while that is happening? etc.)
                          OTOH, it is normal for an oven or a clothes dryer to have a 30+A 220V outlet to connect the appliance. And, there's no law against operating a server out of your kitchen or laundry room in lieu of said appliance (it just "looks odd")
                          • Behemot
                            • 4845
                            • CZ
                            #73
                            Oh my, glad we have normal line voltage here and while the laws and regulations are also sack of shit already, it's still not so bad. Yet.
                              • 31200
                              land-of-the-free.
                              you need to do a bit more swamp-draining.
                              pretty damned funny considering some of the dangerous crap that is permissable or common.
                              like insulation-displacement connectors and those laughable domestic power outlets.
                                • 31200
                                oooo.....
                                i bet Intel paid a lot for this "feature" to be included.
                                it's just too perfect to be an accident.
                                http://www.theregister.co.uk/2018/01...d_powered_pcs/
                                so now they can tell people to stick with "reliable" Intel shit!!
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  #76
                                  Just because they are RULES doesn't mean they are followed!
                                  Walking around the neighborhood, I can see plenty of cases where NM cable is stapled to the exterior of facia boards without even running it through conduit or liquid-tight. But, an inspector driving by isn't going to get out of his car and write the guy up -- they'll wait for the house to catch fire from some other cause...
                                  And, there are plenty of licensed electricians who will gladly look the other way if financially motivated.
                                  • retiredcaps
                                    • Apr 2010
                                    • 9271
                                    #77
                                    Just watched the first two minutes of Intel's CEO keynote. I didn't hear the word sorry or aplogize. Just see Intel not taking any blame with the slide that shows all CPU architectures are vulnerable. Brian also doesn't strike me as a likeable or sympathic guy. I don't see him doing well in crisis control mode in public scrutiny.
                                    https://www.youtube.com/watch?v=f71yokde704
                                    My E8400 is vulnerable. Patch for Lubuntu is supposed to be released Jan 9.
                                    Spectre and Meltdown mitigation detection tool v0.17
                                    Checking for vulnerabilities against live running kernel Linux 4.13.0-17-generic #20-Ubuntu SMP Mon Nov 6 10:04:08 UTC 2017 x86_64
                                    Will use vmlinux image /boot/vmlinuz-4.13.0-17-generic
                                    Will use kconfig /boot/config-4.13.0-17-generic
                                    Will use System.map file /boot/System.map-4.13.0-17-generic
                                    CVE-2017-5753 [bounds check bypass] aka 'Spectre Variant 1'
                                    * Kernel compiled with LFENCE opcode inserted at the proper places: NO (only 42 opcodes found, should be >= 70)
                                    > STATUS: VULNERABLE
                                    CVE-2017-5715 [branch target injection] aka 'Spectre Variant 2'
                                    * Mitigation 1
                                    * Hardware (CPU microcode) support for mitigation: NO
                                    * Kernel support for IBRS: NO
                                    * IBRS enabled for Kernel space: NO
                                    * IBRS enabled for User space: NO
                                    * Mitigation 2
                                    * Kernel compiled with retpoline option: NO
                                    * Kernel compiled with a retpoline-aware compiler: NO
                                    > STATUS: VULNERABLE (IBRS hardware + kernel support OR kernel with retpoline are needed to mitigate the vulnerability)
                                    CVE-2017-5754 [rogue data cache load] aka 'Meltdown' aka 'Variant 3'
                                    * Kernel supports Page Table Isolation (PTI): NO
                                    * PTI enabled and active: NO
                                    > STATUS: VULNERABLE (PTI is needed to mitigate the vulnerability)
                                    --- begin sig file ---
                                    --- end sig file ---
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      From what I understand, this behavior is not exactly "wrong" based on the specification, but rather "undefined"... unfortunately it's the worst possible undefined behavior.
                                      Anyone here still run 32-bit Linux? As far as I know, nobody has really looked into getting a fix for meltdown for these machines yet. 64-bit has a patch for meltdown.
                                      The current PoCs out there either do not work on 32-bit or work poorly on them, especially pre-P4 machines.
                                      • Curious.George
                                        • Nov 2011
                                        • 2305
                                        • Unknown
                                        #79
                                        I think that would fall in the realm of lawyer-talk.
                                        The protection domains exist for the express purpose of isolating userland from kernel (in this case). Anything that can be exploited to violate that functionality would be a breach of faith -- in the community that will ultimately be buying your product(s).
                                        [I.e., try to claim it's "unspecified" and they'll remind you that their dollars are similarly "unspecified" and could just as easily patronize your competitor.]
                                        You can claim that the TRANSPARENT GLASS walls in the dressing rooms in your store serve to isolate customers from each other and safeguard their belongings (from theft). But, I suspect most folks would say the primary reason for walls in dressing rooms is to interrupt the flow of photons!
                                        • eccerr0r
                                          Solder Sloth
                                          • Nov 2012
                                          • 8701
                                          Yes this is lawyer talk. This means that you can't sue intel or AMD or ARM or whatever because the user (implicitly the computer system designer) accepted the document that defined how the CPU operates... There was no declaration on what the CPU should do in the situation that the code given.
                                          It's the equivalent that you had a chance to see the transparent glass when you built the store, but you didn't see it. So, you think it's okay, and kept going. Now the customers come in the store and find out they can see through the transparent glass if they push this button, slide this cover to the other side, grab a piece of polarizer, and place it in this certain position at the right time...
                                          There is no question that this is indeed improper behavior. However, if people start suing hardware companies for mistakes like this, it just will mean hardware will get more expensive as insurance will start being necessary for covering these problems... now the question should software companies also be liable for unexpected behavior, like due to buffer overflows? What about unchecked bounds?
                                          Then what about the software that is written incorrectly that exposes a hardware bug, if you write it a certain way then the hardware bug isn't exposed?
                                          It's just opening a can of worms.
                                          • Nebukadnerzar_V
                                            Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
                                            by Nebukadnerzar_V
                                            Hi guys!
                                            I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
                                            It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
                                            I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
                                            Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
                                            Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
                                            I have attached the Dump of my machine.
                                            S/N: SRW2K4J
                                            Reg Model: DCTR...
                                            09-27-2024, 02:43 AM
                                          • ducky29
                                            Working with Bga chips especially CPUS
                                            by ducky29
                                            Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
                                            Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
                                            Thanks in advance.
                                            09-23-2024, 03:56 PM
                                          • ugamazing
                                            Procedural question about BGA rework and removal of CPUs
                                            by ugamazing
                                            I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                                            I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                                            I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                                            07-12-2022, 03:11 PM
                                          • SuperAman
                                            PS5 EDM-010 3 Beeps
                                            by SuperAman
                                            Getting 3 beeps only when console is plugged into power, no lights. I was thinking a possible NOR issue but the uart codes are leading to something possibly more serious? EDM-010 disk edition. I didn't try clearing the error codes yet, wanted to backup the NOR first, CH341A programmer comes tomorrow.
                                            Error code: 80810001
                                            Description: General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
                                            Error code: C00C0002
                                            Description: VRM Controller Failure, Check Mosfet (6414A) Located Side-A, Below Sony Interactive Entertainment Inc. Check Infineon XDPE14286A...
                                            09-06-2025, 08:25 PM
                                          • zklgfs
                                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                            by zklgfs
                                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                            08-11-2025, 02:14 PM
