Some serious security bug in INTEL CPUs?? Since Westmere possibly
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Some serious security bug in INTEL CPUs?? Since Westmere possibly
    Originally posted by Topcat
    Westmere is older than 5....but yea, typical Intel. I guess the world will explode, I'm not gutting systems over this. This whole thing totally reeks planned obsolescence scam to begin with.
    But at least, Intel don't appear to be as low as they were with 1993, 1994 and 1995 Pentiums... (The mid-1990s were their lowest point, so far!)
    That incident required physical hardware replacement, you were required to dump your CPU chips per-se!
    IIRC, Intel said that the Pentium 133s and higher, don't have the hardware bug...
    The mid-1990s Intel incident, was a lot worse than "Meltdown" and "Spectre".
    IIRC, late-1990s' Windows NT 4.0, had a work around for such Pentiums detected, but then the Pentiums will act like OC'ed 486 SXes, LOL.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Behemot
      • 4845
      • CZ
      #162
      So when I get such old Pentium, it is likely it still has the bug? There is always somebody who does not get the replacement. I think that all systems check for the affected CPUs and in case they find them, they apply patch, no? At least Linux kernell does anyway.
      • bigbeark
        • Jan 2010
        • 661
        Re: Some serious security bug in INtel CPUs?? Since Westmere possibly
        Originally posted by tom66
        The performance bug is actually *really* interesting, and also fucking terrible because there's literally *no way* to patch it on any processor without completing changing how CPUs work.
        Effectively, processors perform "speculative execution" and "out of order execution" where upon hitting a branch instruction in code, may decide to execute instructions ahead of time, before the result of the branch is known. This is a performance advantage, because in many cases the branch could take many cycles to evaluate (if it needs to read from arbitrary memory, then up to 300 cycles on a modern i7). So the processor executes these instructions and then if it finds out later that the branch was wrong, it rolls back the results. This is completely transparent to the user: incorrect data is never visible or committed.
        Spectre seems to work by exploiting speculative execution, which processors have had for about 15 years. You can write code that will trick the branch prediction logic into executing a block of malicious code. The code will run speculatively - but the catch is, it's not possible for the CPU to prevent reads to protected areas of memory, like other processes or the OS kernel. The CPU sorts this out *after* the speculative execution has finished, and it can check which areas are OK and which are no go (it must do this check afterwards because it can't be sure of the memory map yet). Now, normally this is not a problem because the malicious code cannot "output" anything - it remains transparent as the results never get committed because the addresses are found to be prohibited. But, by inserting timing-dependent code into the speculative execution block, you can "leak" data out of the execution path. You could make it take 10 cycles to process a "1" and 2 cycles to process a "0", then time many hundreds of executions.
        The example Google provided can read out any memory at 11KB/s, which isn't fast, but it's more than fast enough to exploit a system within ~10 minutes. You only need to find the Windows/Linux kernel process table, then you know the addresses of each application and can go to town on reading passwords, security keys, etc.
        It's a complete bombshell, and I'm frankly surprised INTC and other companies aren't feeling a stronger hit.
        So Intel will create a BIOS patch for newer CPUs first. I suspect Intel will have to supply an updated BIOS for any CPU less than 3 years old, since that is a standard lease term and there will be millions of these machines still in use in large organizations. Given it's market dominance, Intel could be viewed as an "essential service". Intel will be fully supported by the US govt to get this fixed for current machines. I suspect that anything older than 3 years will probably be "use at your own risk".
        People that cannot afford to replace their systems will need some workaround. Perhaps using an AMD machine as a file server for their unprotected Intel boxes.
        How is this accomplished and would it work?
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I know corporations still using pentium4-era stuff....I still get things that old in for repair by businesses.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            • 31200
            intel does not produce bioses. (except for it's own boards)
            they produce microcode and modules - updates are regularly put out.
            it's upto the motherboard maker to bother compiling an update or not.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Correct
              Team : 49813
              Join in!!
              Team Stats
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                If you have a P120 or newer, it should not have the fdiv bug.
                It may have the F00F bug but it can be worked around and thus not recalled.
                As per post 140, I have experimentally verified my Core2 Quad (and also Core2 Duo) that predate all of the Intel-listed processors are at least affected by Spectre.
                I do wonder how hard it is to find the process table if all kernel addresses are random with ASLR within physical memory... Searching may be very time consuming, and the slower machines are even worse: I would think that the older machines (PPro to P3) are even more difficult to exploit beyond their inherent slowness because they have poor time measurement capability and lack state resetting capability within userspace, albeit they are still vulnerable. Chips starting with the P4 and Pentium-M and anything newer start to gain these things and thus are more dangerous.
                I would suggest that any machine that is subject to new, arbitrary code frequently to be most vulnerable (think: new apps, scripts, javascript, flash, ...). In this respect, other than the fact servers are not monitored, as long as servers run the same code over and over again and only download trusted code, they are safe. In any case, at least for Linux, the Meltdown fix (KPTI) is available for 64-bit and soon available for 32-bit x86; so after that patch, it'll be as safe as AMD boxes that may be affected by Spectre.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Originally posted by Stefan Payne
                  Look at the Link to Arstechnica.
                  For Ryzen that's not true, RYZEN is not suceptible to Spectre - the same as Samsungs EXYNOS Processors as well.
                  I'm just worried that we possibly have another first-gen-Phenom-like-severity bug again! Where you were required to replace the CPU chips per-se!
                  IIRC, for the first gen Phenoms, the solution is to replace your processor with a model having the suffix "50"... (And thus, for example, "8750" is in the clear, and "8700" is the faulty one!)
                  Arc A770 16 GB
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    I thought these CPU bugs were gone the way of the dodo.
                    I remember the "KAP" processor which was supposed to be a SPARC clone, but had so many bugs fixed in the OS/software that it can't run SunOS anymore...
                    And around the same time was the more or less flawless(?) 486? What 486 bugs were there?
                    • Curious.George
                      • Nov 2011
                      • 2305
                      • Unknown
                      #170
                      A colleague buys virtually every piece of big Sun iron that he comes across. In his case, it's cheaper to pay some ridiculously inflated "spares" price (and hope the SURPLUS stuff actually works!) than it would be to rewrite the software that runs their enterprise. I often wonder what they could save on just their electric bill, alone, if they moved to more modern hardware!
                      [If you don't upgrade for a few decades, the prospect of upgrading is closer to sheer terror than anything else!]
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        #171
                        This is not remotely exploitable, you need a way to put code on a victims system.
                        For example Javascript in a browser from a shady website.
                        Or malicious code via some other entry point like e-mail or such.
                        None of this should be running on a fileserver so that wont even need to be patched technically, because walled off properly it could never be exploited.
                        If the fileserver runs in a Virtual Machine with many other systems I'd be very afraid of exploitation though!
                        • Behemot
                          • 4845
                          • CZ
                          #172
                          Of course, there are things like CNC machines or embedded stuff using that. Even Pentiums III, I think it was Per Hansson repairing such device recently and posting it here?
                          Curious.George: what kind of Sun HW are we talking about? Anyways, it is not only about the SW, which is huge price today, it is also the whole HW ecosystem. Also remeber that big corporations have totaly different price of electricity, that's one of the last things which actually impact anything if we are talking about some industrial machinery.
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16958
                            I repair a lot of that stuff too... Seems like the CNC guys loved Soyo P3 & P4 boards, with ISA of course.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Behemot
                              • 4845
                              • CZ
                              #174
                              Have not actually had such in my hands, but I judge so from the volume of Pentium 4 (478) CPUs which I still resell. You get it pratically for free so even few bucks is nice sale (when the only work is cleaning it and making the advertisement).
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                #175
                                I repair allot of older stuff too, industrial stuff never becomes obsolete per se.
                                As long as you can find components or repair the old ones the customer will keep using the machines...
                                Of course I don't post very frequently about these repairs, but some I do post about.
                                https://www.badcaps.net/forum/showthread.php?t=39747
                                https://www.badcaps.net/forum/showthread.php?t=37091
                                http://www.jonnyguru.com/forums/show...78&postcount=5
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Well, it's apparently not remotely exploitable, unlike the Blaster virus incidents of 2003, and Sasser of 2004 (and maybe later in 2003)
                                  All you had to do to get exploited, with the 2003 and 2004 incidents, was to hop on the internet without a firewall!
                                  You could get exploited within seconds on 56K, IIRC!
                                  Arc A770 16 GB
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16958
                                    If I posted about everything I repair, there'd be a gazillion threads/posts about it all....I may post about something unusual now and then...but otherwise bore people with my kooky boredom builds.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      It was the dark ages of computing! The period that made Topcat put his feet down, due to widespread bad motherboard caps! (Also includes the period of the widespread-bad-Antec-PSU-caps-problem...)
                                      Arc A770 16 GB
                                        • 31200
                                        a guy on eevblog has a good solution.
                                        The only way to fix this situation, is to take about 10% of the top management of Intel and Microsoft, and kill them. Give the companies 30 days to open source the entire platform and a year to remove all the spying bullshit, on pain of the next 10% getting the same treatment. And so on.
                                        sounds good to me, but 25% may be more effective!
                                        • mariushm
                                          • May 2011
                                          • 3799
                                          #180
                                          Yeah, the problem is you don't know how many of these bugs were required by NSA and other organizations to be put there in the first place , or how much money Intel received to NOT fix some of these bugs.
                                          Or how many things Intel is forced through non disclosure agreements and other national security letters and laws not to reveal.
                                          There's even rumors that NSA has people inside Intel working as programmers or managers with agenda to make such exploits possible.
                                          But the most likely reason why such problems exist is just arrogance and bad attitude and managers pushing chip designers and programmers to make something faster and with less money, rushing everything to release new stuff every one or two years.
                                          • Nebukadnerzar_V
                                            Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
                                            by Nebukadnerzar_V
                                            Hi guys!
                                            I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
                                            It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
                                            I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
                                            Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
                                            Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
                                            I have attached the Dump of my machine.
                                            S/N: SRW2K4J
                                            Reg Model: DCTR...
                                            09-27-2024, 02:43 AM
                                          • ducky29
                                            Working with Bga chips especially CPUS
                                            by ducky29
                                            Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
                                            Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
                                            Thanks in advance.
                                            09-23-2024, 03:56 PM
                                          • ugamazing
                                            Procedural question about BGA rework and removal of CPUs
                                            by ugamazing
                                            I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                                            I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                                            I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                                            07-12-2022, 03:11 PM
                                          • SuperAman
                                            PS5 EDM-010 3 Beeps
                                            by SuperAman
                                            Getting 3 beeps only when console is plugged into power, no lights. I was thinking a possible NOR issue but the uart codes are leading to something possibly more serious? EDM-010 disk edition. I didn't try clearing the error codes yet, wanted to backup the NOR first, CH341A programmer comes tomorrow.
                                            Error code: 80810001
                                            Description: General Power Failure (Peripheral, GDDR6, APU, Data Line Short)
                                            Error code: C00C0002
                                            Description: VRM Controller Failure, Check Mosfet (6414A) Located Side-A, Below Sony Interactive Entertainment Inc. Check Infineon XDPE14286A...
                                            09-06-2025, 08:25 PM
                                          • zklgfs
                                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                            by zklgfs
                                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                            08-11-2025, 02:14 PM
