Zandrax cleverly drew my attention to the following issue
but i have ST31000340AS with SD15 firmware not SD14
as per this thread HDtune still identifies cache n/a after update. i have cache n/a but i also have less burst than i would expect. for the previous firmware drives update of firmware corrects cache issue
BUT i find this thread which shows that SD15 drives get issue early that make them in permenantly busy state with 0gb detected or not detected by bios. new thread after old one closed by seagate
which is VERY dissappointing...........
Originally posted by Zandrax
- Below are the Barracuda 7200.11 model numbers. If the bold digit is any number other than those shown, Seagate recommends that you update the firmware on your drive:
Model numbers
1000 GB
ST31000340AS
750 GB
ST3750330AS
500 GB
ST3500320AS - If the drive bears one of the model numbers above then no action is required. If you do have an incorrect model number, please download SeaTools to determine your serial number.
- Once you have your serial number contact Seagate Technical Support to receive the AD14 firmware update.
