Marantz NR1508 USB firmware update image
  • pp74
    • Apr 2021
    • Polska
    Does anyone happen to have the latest firmware for the NR1508? Marantz took their update server down and customer support refuses to provide the image to flash over USB.
    Regards
  • frankusb
    • Apr 2015
    • 110
    Marantz sucks for doing that. I am looking for the latest firmware for the SR5007. I contacted an authorized repair center and they were able to provide older versions but not the latest.
    • Faluky
      firmware for Marantz SR5008 stuck in update loop
      by Faluky
      After an update it stopped playing audio and video, I have reset it as it says in the manual and tried to reinstall the firmware over the internet but logging failed each time and I tried to download the firmware to install it by usb but it does not appear on the official page, could you help me? Since it would be a shame to have to get rid of him, European version Thank you very much
      Best regards.
      Anyone got their hands on firmware for Marantz SR5008 stuck in update loop
      01-17-2023, 04:33 AM
    • TheUser
      Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
      by TheUser
      Hello to everyone ,
      This is my first post here, and i would like to share with you a small story in case you can help me.
      Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
      All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
      I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
      02-10-2024, 02:07 PM
    • Daniel Larsson
      Firmware file for Marantz NR1501 needed
      by Daniel Larsson
      I picked up a Marantz NR1501 that the seller said did not produce any audio, but was starting up just like normal. This was indeed the case and the hunt for damaged components started.
      After confirming all voltages and replacing all caps on this godforsaken HDMI-board I finally got sound from the AUX input, but all digital inputs are still dead.
      The service menu shows no DSP version so I desoldered IC1604 that should have the serial flash DSP firmware on it and made two dumps that turned out identical.
      The content of these seems to be useless as far...
      05-23-2025, 04:11 AM
    • akwky
      by akwky
      Hi!
      04-14-2025, 01:56 PM
    • frankusb
      Marantz SR5007 USB firmware update image
      by frankusb
      Does anyone happen to have the latest firmware for the SR5007? Marantz took their update server down and customer support refuses to provide the image to flash over USB. They offered to let me pay a service center to do the update (has to be over USB).
      Thanks.
      02-20-2024, 11:29 AM
