Finds at recycling drop-off
  • Gendo Ikari
    • Jun 2008
    • 62
    Hi all!
    Long time no..post?
    Anyhow, I took a buttload of dead hard drives, board's, and old AT desktop's to the recycling drop-off a few towns over. Of course, I couldn't help but look through the treasure that had been left, and this is what I reclaimed;
    *a Sony VAIO PCV-RZ32G minus the hard drive, and also missing the bottom northbridge heatsink clip loop thingy on the motherboard. If anyone knows how I can fix this?...
    *A generic Socket 462 system with an Audigy soundcard. Turns out the socket 462 was a duron 650mhz, ick... But 256MB's worth of 133mhz ram, non the less! It also had an ATI Rage 128 AGP card, LOL!
    *A Geforce 2 AGP card. One of mine just died and I have no more. =3
    *Three or four sticks of 32-64MB PC100 RAM
    Other stuff that I saw but didn't take include a 286 machine, a 486 packard bell( I took the 486 CPU lol) WITH windows 3.1 manual (thick!), a wierd satellite tv thingy that looked like a NAT storage devices, or like two external zip drives stack on one another, connected with a printer cable, but it also had a USB port? Most of the stuff there consisted of HUGE CRT montiors, some of them four years old or less, as well as VCRs, DVD players, and tuners.
  • Logistics
    • Apr 2007
    • 721
    Re: Finds at recycling drop-off
    Choose a very common, easily obtainable heatsink + fan combo; use Arctic Silver thermal adhesive!
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      I believe its called artic silver ceramique?
      • stevo1210
        • Oct 2006
        • 4156
        If only computer recycling places exist here in Australia.... I'd probably be there everyday to find something good....
        Ugh, here in Australia no one gives a damn about computer recycling.... you've actually gotta pay a large amount of money to get old stuff dispose. Obviously no one wants to do that so it just goes in the garbage bin or onto the sidewalk for others to pick up or smash to bits....
        • pentium
          • Mar 2006
          • 2778
          Recycling here is very territorial.
          They call the cops on me when I come asking.
          It must be because I always want the old stuff and it is always the most gold rich.
          That leaves me searching through the landfill for computers but I usually find other stuff as well.
          Find Nedry!
          Check the Vending machines!!
          • arneson
            • Sep 2005
            • 1267
            What a pertinent topic, because
            I always come away from the dump with as much as I bring.
            I've scored a lot of UPS's because there's a whole section of APC's.
            That Viao is a good find, hope you restore it.
            I'm a real trash hound.
            Jim
            • Gendo Ikari
              • Jun 2008
              • 62
              Isn't that dangerous?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                so you scratch big brown delivery trucks backed up by armored personell carriers?
                • Wizard
                  • Mar 2008
                  • 2296
                  No. Arctic Silver thermal adhesive as someone said.
                  It is 2 tube and have to mix equal amounts and apply, use what is needed and store the tubes for next use. It has extreme short pot life once the glue is mixed. So get items prepared first then mix up then squeeage some on, clamp the heatsink on. And leave it overnight to cure fully.
                  Fixed toshiba DTR's loose heatsink bent up heatpipes and slightly mashed fins on the heatpipes by taking it apart, repair everything then, took about 8 sessions of mixing to get all fins on (every 6 to 8 fins) due to pot life is so short. A caution: don't let this cured thermal glue freeze, bonding failure occurs.
                  Cheers, Wizard
                  • Gendo Ikari
                    • Jun 2008
                    • 62
                    Well, I talked my parents into taking me over to the Recylcing center again, since I had a box full of stuff buried under some stuff next to my bed.
                    This time I found an HP system with a 1.3GHz Athlon, and a snazzy 2.53GHZ Celeron system from '04, at least according to the best buy stickers on it.
                    I also got a bag of goodies, since the people who dumped the HP sytem left a zip lock full of manuals, cables, and an optical USB mouse and keyboard. =3
                    I also pulled a tower with room for 9 HDD's, no side panels thou. =/ I climbed over a couple of large cardboard containers to get it thou. Maybe I should have dug for side panels, but I didn't want the people there to get upset ;;>_>
                    I pulled two DLINK 100mbps NIC cards out of an ANCIENT pentium machine, looks like it might have been a server or gateway/router of sorts. It was a tower, but the PCI cards and ISA were mounted on a daughterboard above the motherboard. Very strange...
                    I also saw a HUGE tv, like...40inch?, which smashed some poor monitor underneath it, a couple pans, a motor, and a HUGE printer, like 4ft wide at least, apparently used to print out blueprints? O_o Oh, I saw a Macantosh LC as well! LOL And a whole assortment of gutted laptops, stripped to the bones.
                    • 370forlife
                      Large Marge
                      • Aug 2008
                      • 3112
                      Cheers, Wizard
                      You mean like this:
                      http://www.newegg.com/Product/Produc...82E16835100005
                      Cheap way to cool overheating northbridges, put a old p3 heatsink on it.
                      • pentium
                        • Mar 2006
                        • 2778
                        Geez, that place seems pretty cool.
                        If you ever see a PDP or a DecTape drive, please let me know.
                        Find Nedry!
                        • dood
                          Deputy dood
                          • Mar 2004
                          • 2462
                          At my local recycling center they prosecute it as theft if you remove anything from the premises.
                          Ludicrous gibs!
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16955
                            I have some decent inside sources at the electronics recyclers. If anything later model stuff comes through, they set it aside and we come get it. landed a lot of good stuff that way.
                            <--- Badcaps.net Founder
                            Badcaps.net Services:
                            Motherboard Repair Services
                            http://folding.stanford.edu/
                            Team : 49813
                            Join in!!
                            Team Stats
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              damn... i need some HDDs.. could you get me a few 20GB+ ones ?
                              jk ^^
                              • Gendo Ikari
                                • Jun 2008
                                • 62
                                Huh, what are those? o.o pics please?
                                Also we usually ask before I climbing thru the mountain of stuff in the cargo container...
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Woah. O_o
                                  Here is a PDP-8 (an /e version):
                                  ...and here is a DecTape drive:
                                  Actually Topcat, you think you could pull a few strings and see if your sources can locate one?
                                  Same here. Either that or they are just fed up with me taking the good stuff.
                                  Find Nedry!
                                  • jpdoe
                                    • May 2007
                                    • 237
                                    What a coincidence! I was watching "the three days of Condor" the other day, and in the first scenes there was an oriental woman operating a DecTape drive. I've never seen one, so I was was wondering what kind of tape drive it was.
                                    • Newbie2
                                      • Sep 2005
                                      • 885
                                      Pretty much everything at a recycling center is pretty much considered garbage from other people who don't want it, so why would they have such law?
                                      My gaming PC:
                                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                                      ASUS M4A77TD AMD 770 AM3 Motherboard
                                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                                      ASUS Xonar DG 5.1 Channel PCI sound card
                                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                                      Antec Three Hundred Mid-Tower Case
                                      Microsoft Windows 10 Pro 64-bit
                                      Microsoft Windows 7 Ultimate SP1 64-bit
                                      • dood
                                        Deputy dood
                                        • Mar 2004
                                        • 2462
                                        The recycling centers get money for computer stuff, plus there's liability of people crawling around the boxes.
                                        Ludicrous gibs!
                                        • Topcat
                                          Diablotek PSDA600 PSU
                                          by Topcat
                                          I did this one earlier in the week....but knew the server move was coming up so I waited before posting it.
                                          I have never heard of this brand of PSU. The system it was in wouldn't POST, but would power up....and when I saw this PSU, it was my number one suspect.... The system was a dropoff for recycling. I plugged in a test PSU, and the system fired right up....so yea, PSU isn't working right.
                                          Here's the PSU:
                                          It didn't feel like it was going to be of very good quality, but it didn't feel like an empty happy meal box like some of the really junky...
                                          05-05-2023, 04:10 PM
                                        • jeweemiah
                                          Soft spongy thingy
                                          by jeweemiah
                                          This on U6910 What is this soft thing? And what does it to? I knocked off mine and is this being sold too?...
                                          03-07-2022, 06:49 PM
                                        • mnciks11
                                          Interesting finds
                                          by mnciks11
                                          Hello guys
                                          I was playing around with a working board, i removed the bios and soldered a dead bios chip, guess what happened...
                                          The laptop came on and quickly shuts down
                                          Sometimes we struggle with such cases where the laptop is coming on and quickly shuts down, not only shorted to ground 5v creates this but even a bios chip causes such thing and some other components.
                                          Please guys you can share some other experiences as well they might help someone
                                          Thank you 🙏🏿
                                          12-12-2019, 09:56 AM
                                        • smic717394
                                          Mac Air A1466 2012 cpu 300%
                                          by smic717394
                                          I bought a mac air 2012 very cheap, because the customer didn't want to fix. After reflowing the ram chips the laptop works fine, I tested the ram and no error. But The fan goes at max speed after few seconds. Running the Apple diagnostic finds an error 4SNS/1/C0000008: Th1H--124. and the cpu usage is like 300%, After disconnecting the webcam cable that on the 2012 model is on the IO board, the laptop, the laptop runs fine, and running the apple diagnostic finds no errors. So the problem is related with the webcam, but I suspect the problem is no the webcam but the light sensor....
                                          02-06-2024, 03:26 AM
                                        • ShatterMasters
                                          75uq7590pub Has backlight no image
                                          by ShatterMasters
                                          I have a 75uq7590pub that was dropped off for recycling. The Tv powers on and has audio but no picture, the backlights are working. Here is what I have attempted so far. Replaced main board, tried connecting one ribbon at time and testing. Not sure where to go from here. Any ideas?
                                          Thanks!!
                                          05-29-2025, 02:09 PM
