I bought a mac air 2012 very cheap, because the customer didn't want to fix. After reflowing the ram chips the laptop works fine, I tested the ram and no error. But The fan goes at max speed after few seconds. Running the Apple diagnostic finds an error 4SNS/1/C0000008: Th1H--124. and the cpu usage is like 300%, After disconnecting the webcam cable that on the 2012 model is on the IO board, the laptop, the laptop runs fine, and running the apple diagnostic finds no errors. So the problem is related with the webcam, but I suspect the problem is no the webcam but the light sensor. Connecting the webcam cable runs very slow and if I test the webcam work but the light sensor no. Removing the problem cures the problem. I´m not going to chenge the screen in this 2012, I can either leave it without the webcam or maybe if there is anyway to disable the light sensor, maybe there is a resistor or something next to the camera connector. And yes I already replace the io board and the cable, same problem.
Thank you.
Thank you.
It's cold here at times in Canada, but not that cold!
Easy solution is to go to AcuRite website and purchase the sensor. Right?...
