DIY smart TV or replace tv main board with newer model
  • elpres
    • Apr 2016
    • 11
    What I have been wondering about is if anyone has ever tried replacing the main board in their older led/lcd TVs with a newer one or even with some android tv capture device thing?
    He reason is that I have some older model tvs that would be nice to get away with a low cost (hopefully) upgrade and thought that maybe replacing the main board with one from a newer model might be the way to go.
    As I don't have much knowledge in this area I came looking for the information I need and stumbled into this community.
    I know in one of the tvs I have it uses an lvds connector, are they standard sizes, would a straight swap work?
    Any help/info is appreciated.
  • mmartell
    • Oct 2013
    • 3189
    Re: DIY smart TV or replace tv main board with newer model
    There are some that can be drop in upgraded but I would guess that's the exception not the rule since there are other systems involved.
    • R_J
      • 9549
      as an alternative, Raspberry pi model 3 with Kodi has hdmi-cec so you could use the tv remote to navigate, might be cheaper than a new board. just my 5 cents (no more penies)
        • 31044
        or an ODROID-C2
        much better than a Pi.
        • elpres
          • Apr 2016
          • 11
          From my brief research into lvds so far, it should be doable at the most using a bridging board(?) to line up the correct pins. There may be more to it beyond that but that's what I've found this far.
          • craciant
            • Jan 2017
            • 5
            I would imagine that many TVs have room in the case somewhere to take the guts out of a roku and wire it to an HDMI input internally. Of course, then you would be losing an HDMI input and the solution would be hardly more elegant than simply using a roku or chromecast as it was meant to be used. I figured it would be worth mentioning since the higher end rokus have radio remotes and (I think) hdmi-cec, so you wouldn't have to deal with the IR remote stack at all... could even remove any associated IR remote hardware to make room
            • srhofmann
              • Aug 2016
              • 135
              • usa
              In theory you can, but as you already pointed out a bridging board or custom cable will be needed. The connectors may be standardized but the pinouts aren't. It can be a challenge to get the panel schematic and the board schematics to make them. Also, you run the risk of not having correct colors. Manufacturers can tweak the mainboards(firmware) so they "display" and output the correct colors based on the panel type.
              It's going to be simpler, faster, easier and safer to just get yourself a cheap media player or a tablet and drive your existing device.....
              • GeorgeBlitz
                • Oct 2017
                • 24
                Hang a Roku off your TV. Especially if you aren't electronically and mechanically inclined.
                That said, I stuck a Roku3 and HDMI->VGA converter inside an old Panasonic plasma 50. I added two USB-A jacks, a coax audio jack, and an RJ-45 Ethernet jack, all where the VGA jack used to be. The metal case hosed up wifi reception, so I stuck a pigtail antenna out the vent and taped it.
                Note that WiFi is adequate for most stuff, but MKV movies encoded w/ DTS-MA need Ethernet.
                This bought an old set w/ no HDMI at least another 4 years.
                When testing electrolytic catzappers, you should always wear an OSHA approved safety squint.
                - Friedrich Nietzsche
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  You can't replace a Main Bd of an older TV with a new Main Bd for another model. First off, the panel Nos. would be different and so the T-CON Bds will be different and most of all the software will be different. If you don't want to buy new TVs try the ROKU stick or AMAZON fire-stick. That will convert your non-smart TV to a semi-smart TV. You'll get youtube, Netflix and every thing else. You just would not be able to surf the net.
                  • desert-rat
                    • Mar 2014
                    • 4103
                    The problem with a lot of modern consumer electronics is that its cheaper to buy a new t.v. than to fix an old one .
                    • NeedsMoreFlux
                      • Oct 2017
                      • 121
                      • California
                      I'd rather use a laptop with a wireless keyboard and mouse.
                      I had been trying to fix a tiny laptop(got for free-used to have a tablet on top) so that I could install it inside my Samsung 55" T.V. case.
                      Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
                      I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
                      Some of the things I've fixed:
                      60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
                      • desert-rat
                        • Mar 2014
                        • 4103
                        Yes you can watch the big game on a 15 inch screen and a few years ago most people were happy with a 19 inch rca/ zenith. Most people today want the bigger tv.
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          I think a practical approach is to treat the TV as a "dumb display" and migrate all of the "smarts" to something outside the case.
                          Here, I drive the TV's with computers and source material from:
                          • media tank (incl. optical media)
                          • "network" OTA tuner (e.g., HDHomeRun)
                          • internet portal
                          In each case, I have control over the data going in and out of the house instead of wondering what some crippleware/spyware in the "smart" TV wants to do/say.
                          And, I have control over how the media is "consumed" (e.g., route it to a PVR vs. live viewing)
                          • Badee
                            • 7
                            I agree that it can be a lot cheaper to buy a new TV than fix an old one but if you have the time and resources, then go for it
                            • amelbye
                              • 46
                              • Norway
                              I've had a similar thought. I have a high end TV, but it's 10 years old. Picture quality is good enough for me, and I have it hooked up to both a chromecast and an ubuntu-machine running kodi, so it does most the stuff modern tvs do, but without the glitches and poor performance that I've seen at my friends houses.
                              What bothers me is more about aesthetics. First gen LCD screens have huge bezels, and if TVs are anything like computer monitors, that bezel is completely un-neccessary. I'm sure the only reason they put it on there was so that they could remove it on a future model and sell you (more or less) the same TV once again. So what I'd like to do is strip off all the un-neccessary plastic and reframe it.
                              Whatever it's gonna cost, this is not about saving time and money. It's about making it your own. If there was a proven route to repurpose your panel with newer electronics, I'd be doing that as well, while I had it all apart.
                              • TechGeek
                                Computer Geek
                                • Jan 2015
                                • 2254
                                As others have said, it's not really feasible to install newer hardware into it. The best you can do (and it still be reliable) is take something like a Chromecast or something like that and hook it up and hide it INSIDE the TV. Or just connect your computer to it and do it that way.
                                Permanently Retired Systems:
                                Kooky and Kool Systems
                                sigpic
                                • Curious.George
                                  • Nov 2011
                                  • 2305
                                  • Unknown
                                  "Smart" TVs are notoriously crappy. Part of it is the delusion that manufacturers operate under wrt software development: "We can JUST use all this FOSS and cut our development costs!" Then, CUSTOMERS discover that the software isn't ready for prime-time -- and the manufacturer no longer offers updates (cuz it's LAST YEAR'S model!).
                                  Or, that internet accesses are routed through a secret proxy (and you can't use the set on your own "private" internet)
                                  There will always be some aesthetic aspect of it that you'll dislike. And, you'll quickly find yourself unable to "compensate" with your limited fabrication skills.
                                  "Oh, it's too THICK..."
                                  "Oh, it's too HEAVY... (for the lift that I wanted to put it on so it would drop into a piece of furniture when not in use)"
                                  "Oh, the screen isn't CURVED..."
                                  Best bet is just to live with the structural analysis that the manufacture did for the case and bypass as much of the "smarts" as possible -- treating the various video inputs as high level interfaces and ignoring all of the other cruft in the set.
                                  This is the approach I've been taking, here. Treat all "video displays" as DUMB displays and design a network interface to them that lets me push whatever video I want down the pipe (so, even a "computer monitor" can be repurposed as a modest-sized "TV") without having any kit lying around near the "set".
                                  (I.e., move the STB into the wall so you just have a video connection on a wall plate)
                                  • petehall347
                                    • Jan 2015
                                    • 4427
                                    • United Kingdom
                                    there is an external box to plug in and go now .
                                    such as this ..https://www.argos.co.uk/product/8661221
                                    • Curious.George
                                      • Nov 2011
                                      • 2305
                                      • Unknown
                                      Yes, but it doesn't handle OTA, the contents of your media library, the video from your PC and let you see who's at the front door (let alone all at once!)
                                      • alfatv
                                        • Sep 2020
                                        • 353
                                        If TV has HDMI input, the best thing is Amazon firestick 4k. It's remote can be programmed to control TV as well. Essentially TV becomes Smart TV.
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • Lee M.
                                          Samsung UN75RU8000FXZA bad main board?
                                          by Lee M.
                                          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
                                          11-08-2023, 07:46 PM
                                        • edugimeno
                                          LG 43LJ594V main board not providing stby power
                                          by edugimeno
                                          I there!
                                          I have this TV set that doesn't even light up the st by led. I fully checked the PS board and this one is fine, it provides 8.9V when Stdby and 13V when ON (forces by DRV_ON pin according to service document)
                                          So I checked the main board and it is not able to even light up the stdby led and of course it won't obbey to ON button or remote signals
                                          I checked all caps on board, none of them is shorted. I took some voltages at those caps, some of them have 8.9v on one side, some don't have any voltage. I see some coils and smalls IC's near banks of SMD...
                                          05-14-2023, 12:41 PM
                                        • edugimeno
                                          Anyone with experience repairing a bad MAIN board?
                                          by edugimeno
                                          Hi There! I already had another post with this but it got no attention from anyone so I'm starting a new one with a probably more descriptive subject
                                          I have an LG 43LJ594V that would not even power up the stdby led. I checked the PS board and its 100% good. Provides 7.8V when STBY and 13V when ON, I checked it forcing DRV_IN input to high.
                                          So all the other subPS's should be in the main board. The TV won't show any life in it'¡s stby led, won't turn on when pressing the phisical ON button nor the remote. My guess is that some subPS inside the MAIN board is bad....
                                          05-16-2023, 12:36 PM
