Aaaaaand flash is dead!
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    http://hothardware.com/news/adobe-ef...imate-cc-suite
    Yep, faildobe is even done with it!
    Follow the white rabbit.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Aaaaaand flash is dead!
    I read it as Adobe wanting people to know that their software doesn't just create Flash it does HTML5 also. The video is from Adobe and explains it better than the biased article.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      I'm still on the side of optimism here, adobe put its own framework/media container format off to the side of html5 in there own software.... It's dead... If not it will be fast!
      • diif
        • Feb 2014
        • 6978
        • England
        No, this is not them pushing Flash to the side. They have incorporated Adobe Edge (HTML5 creation) into one creative package. Flash will be around for a while yet i feel. There are still a few video sites that have yet to switch over.
          • 31070
          and half of japan still uses it for web-pages!
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            I hope that it fades away, the sooner, the better. Good riddance.
            A working TV? How boring!
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              HTML5 is even slower on older PCs...
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                exact opposite for me... Flash is laggy and crappy on my toughbook CF19 MK2 and HTML5 performs beautifully!
                • SteveNielsen
                  Retired Tech
                  • 2327
                  I don't have problems with HTML5 either, only with crappy websites, and all my hardware is old stuff.
                  • goodpsusearch
                    • Oct 2009
                    • 2850
                    • Greece
                    I was talking about youtube. Have you compared CPU usage?
                    • fzabkar
                      • Mar 2009
                      • 772
                      Can we now get a 4th option?
                      • Install now
                        Remind me later
                        Don't install
                        Piss off and don't ever bother me again
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        No because there hasn't been any reason to. I see no performance hit.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Good to hear this. But I still hope YouTube keeps their players backwards-compatible with Flash 10.3 or 11.x.
                          +1
                          I am still using Flash 10.3 on many of my own PCs (many of which are Pentium 4 or AMD equivalent).
                          The difference between Flash 10.3 and HTML5: I can still play YouTube in 720p without lag on Flash 10.3. With HTML5, even 480p is choppy.
                          That said, a PC with a Core 2 Duo or newer doesn't seem to have problems handling anything up to 720p in YouTube regardless if it's Flash or HTML5.
                          Also, I am not sure which version of Flash started to support hardware H.264 decoding, but at one point, I remember that one of my PCs with a Radeon HD2400 was able to play even YouTube 1080p fairly well. I think it was Flash 10.x again, but I don't remember. All I remember is I had to upgrade my Flash for an online University class, and then the hardware H.264 on my Radeon HD2400 stopped working.
                          • lti
                            • May 2011
                            • 2551
                            On my computer, HTML5 has higher CPU usage and lower GPU usage, but videos play at the correct frame rate with no dropped frames. When YouTube still used Flash by default, all videos played at 10FPS with lots of dropped frames, no matter what video resolution I chose.
                            • mockingbird
                              • Dec 2008
                              • 5484
                              I like Flash because it only buffers ahead on Youtube to a certain degree, checks if you've actually watched up to that point, and only then continues buffering...
                              This is very important if you have bandwidth limits...
                              But yes, it has been lagging on my old laptop... I wouldn't recommend running the newer versions on anything less powerful than Intel G4x video.
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                Well, if your PC has an Intel G4x video, then the CPU is probably also a Core 2 Duo or better. So in that case, I would say don't bother with installing Flash.
                                I set up a laptop for my uncle last summer. Was debating whether or not to put Flash player on there. But since the laptop had a C2D T9xxx CPU and Intel HD 3000 GPU, I decided to leave it without Flash. With HTML5 in Firefox 41, I could run YouTube 1080p without any lag at all. Didn't notice problems with any other websites either. My uncle is really happy with it so far. Huge upgrade from his Pentium 3 laptop with 384 MB of RAM (imagine that !)
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  I usually compare CPU usage at clients' laptops with and without Flash Player. Most of the time they are 2007-2009 Intel Dual Core cpus.
                                  With Intel integrated GPU, CPU usage is higher than 50% with Flash Player @ YouTube 1080p. With HTML5 it's around 70-80%. This is bad, because most users tend to listen music from youtube and surf on the web at the same time and/or chatting in FB/Skype/Viber etc. So, you would like to lower CPU usage to be confident that they would have a smooth user experience.
                                  With AMD/Nvidia discreet GPU supporting Hardware Decoding, CPU usage with Adobe Flash Player is as low as 15-25% @ YouTube 1080p. HTML5 is a bit higher, IF I remember correct it's around 30-35%.
                                  I don't know what happens when the GPU does not support Hardware Acceleration (for example Nvidia 6000 series) and the CPU is dual core.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Last I heard, HTML5 can't take advantage of hardware H.264. So perhaps YouTube player is using something else with HTML5, which would explain the higher CPU usage. I guess I have to look it up.
                                    Then CPU does all of the work.
                                    ... in which case, you might want to use Flash player if keeping the CPU usage low is your goal (such as on a laptop, where battery life and cooling can be points of concern).
                                    • ChaosLegionnaire
                                      HC Overclocker
                                      • Jul 2012
                                      • 3264
                                      • Singapore
                                      u guys are lucky dxva even works for you. for some weird reason on my pcs, i simply cannot get dxva in flash to work properly. i've tried all kinds of video cards, amd and nvidia, none of them work properly. what happens is that a few minutes or even seconds into playing a flash video, windows blue screens with a video driver stuck in an infinite loop error msg. this error does not appear in and i have no problems playing h264 videos in mpchc with the built-in dxva filter enabled.
                                      since this problem appears on all my pcs and they use different brands and models of video cards and dxva works fine for me in mpchc, i concluded that flash player is focked up with shitty coding and just disabled dxva in flash on all my computers. i'm soooo glad that fockassh player is gone. its screwed up my pcs enuff!
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Hmm... I was trying YouTube with HTML5 (Firefox-ESR38) in Linux on a P4 3GHz (32 bit) with i865G CGC... I only wanted to see the video in the little window (versus fullscreen). I was kind of surprised it wasn't too bad, oddly enough. I recall some other older machines that had trouble with flash for youtube in a small window so that's why this was a bit surprising to me...
                                        Thank goodness no more crashplayer...
                                        • what_1282105
                                          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
                                          by what_1282105
                                          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
                                          02-14-2025, 07:27 PM
                                        • spmetroil
                                          Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                                          by spmetroil
                                          I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                                          The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                                          I have a CH341A programmer and I already attempted the following steps:
                                          1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                                          2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                                          3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                                          Yesterday, 09:23 AM
                                        • abajor
                                          Canon VIXIA HF S10 A read data from inernal flash memory.
                                          by abajor
                                          Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
                                          Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
                                          The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
                                          I think my best shot is to figure out a way to read the internal flash memory outside...
                                          07-20-2024, 12:04 AM
                                        • Ihandyrepair
                                          4 red flash led 65X950G boot Sony and android logo but then black
                                          by Ihandyrepair
                                          HI guys
                                          I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                          here is the issue
                                          I have Sony and android logo. but then 4 led red flash lights front of the tv
                                          I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                          but then I get black screen and 4 red flash light at the front LED
                                          but I get 3 led flash on the LED driver board.
                                          I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                          so I tried...
                                          07-11-2024, 01:45 AM
                                        • ikarusx3
                                          Thinkpad T440p dead after bios flash
                                          by ikarusx3
                                          I have a Thinkpad T440p and it has severe connectivity issues. So to install a different wifi card i wanted to remove the whitelist and got me a programmer with bios clip.
                                          This is what i did so far:
                                          - Laptop was working
                                          - bios chip is winbond W25Q32FV, 32Mb, was detected correctly by programmer
                                          - Dump bios file 2 times, comparing and checking for FF FF, this worked well, all dumps are the same (attached)
                                          - following this: https://notthebe.ee/blog/removing-the-wifi-whitelist/
                                          - modified the dump, signed it
                                          - flashed back...
                                          11-16-2022, 11:46 AM
