Need guidence for buying new RAM
  • Captain Bill grace digger
    • Jul 2015
    • 70
    • India
    • Do RAM sticks from well known manufacturers like G.Skill tend to perform better than other not so well known RAM stick manufacturers.
    • Do RAM sticks from well known manufacturers come with any additional features than a heat sink.
    • Does a heat sink on a RAM stick accelerate performance.
    • Is type and speed of RAM your system board can accept sufficient when selecting a new RAM.
    • Does processor compatibility need to be taken into consideration when buying new RAM.
  • RAMSELECTRONICS
    ATARI boy
    • Jul 2015
    • 48
    Re: Need guidence for buying new RAM
    > It's depend with the motherboard configuration and QVL (Qualified Vendors Lists) to match.
    > Heatsink does not help performance as much.
    > Brand name have lot good names.
    > Try look up at www.newegg.com
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      1. Not generally speaking, but lesser quality RAM tend to have higher failure rates.
      2. Other than being higher quality, no.
      3. If it allows you to over-clock it due to it running cooler then yes, otherwise no.
      4. Yes, that's all you need to spec out RAM for the board.
      5. Not directly. The compatibility is determined by the chipset and the chipset is matched to the CPU. In other words by the motherboard as a unit.
        • Jul 2015
        • 70
        • India
        Thank You.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Is G.Skill a "good" RAM module manufacturer?
          I cant believe I got a *shorted* RAM module from G.Skill (bought from NewEgg). Fortunately I got RMA and a new set of modules, but I would have thought shorts should not get past QA.
            • 31156
            i dont care who makes the module,
            i pay attention to who makes the chips.
            my prefered chips are samsung.
              • Jul 2015
              • 70
              • India
              How can you know the maximum amount of RAM that can be installed in your system also the maximum amount of RAM that can be installed in each slot.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Look it up in your motherboard owner's manual.
                Sometimes you can go beyond what is written but usually they're spot on.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  The board does make a difference sometimes, with these high speed signals, one mishap wiring a signal can mean marginal timing problems...
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    IIRC gskill has a policy where if there is only one or two bad locations on a module they will still sell it as "good." I'd avoid it.
                    sigpic
                    (Insert witty quote here)
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Corsair is another one to avoid IMO. I've never had one that didn't either cause instability and/or fail memtest since DDR3 came out. Kingston are my preferred brand nowadays, although Crucial/Micron seem to be OK too.
                        • Jul 2015
                        • 70
                        • India
                        I have a branded computer from Dell so maximum RAM capacity is not mentioned in any of the product documents. Is there any other way of finding it out.
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          Go to Dell's website and look up the model specs.
                          • lti
                            • May 2011
                            • 2555
                            Cheap RAM has lots of compatibility issues. They sometimes cut costs by making high-density RAM (fewer chips) or using chips that require higher supply voltages to pass testing (either because they're defective or being overclocked).
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Go to crucial.com they have two ways to tell you what memory is suitable for your Dell.
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Avoid Corsair - JUNK! G.SKILL is not so great either. Seen lots of dead G.SKILL memory that was never overclocked. They use fancy heatsinks to cover up generic crap memory chips. Crucial is your best option for quality RAM. Have bought 100+ sticks 0 DOA or coming back bad. That's in servers, desktops, and laptops. Kingston is also very good but usually not cost effective. Mushkin is good too just not very common.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  man i've been using nothing but gskill and have gotten like 2 bad sticks out of like...50, one ddr2 one ddr3. Its really the best bang for your buck, and yes, i've even overclocked it too (but those were more expensive sticks)
                                  and as an answer to your signature, what happens is you get blood on your toast
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    I have gotten a lot of crappy noname modules in the past, of the ones that were branded or recall the brand, I think I have nothing but praise for Crucial (including HP rebranded and Ballistix) and Kingston, no bad modules yet - I somehow have a lot of these two brands, maybe for good reason.
                                    I think rounding out the rest,
                                    PQI - 2/2 good modules
                                    Spectek - I think I got 1/1 good module
                                    G.Skill 3/4 good modules (RMA one set of 2)
                                    These probably compose most of my DDR/DDR2/DDR3 modules.
                                    Most of the other modules I have (mostly SDR, 72-pin EDO, FPM modules, etc.) I don't remember what brand they were if they weren't Kingston or Crucial branded. The bad modules were mostly from the nonames.
                                    I have one noname 256MB PC133 module that I stuck into a P5 "TX" chipset board. Running at PC66 speeds, it still fails memtest86 just like how it fails on another SiS board at PC133 speeds. Fail.
                                    Oddly enough the first RAM module I've ever had known fail on me was a 64Kb x 1 16-pin IC. I was so mad at that chip that it caused random parity errors. It ran hot too, much like the others in that bank. It had "MT" printed on it and I had sworn never to buy from that manufacturer...
                                    But today I guess I did an 180 degree turn, still buying chips from them.
                                    • lti
                                      • May 2011
                                      • 2555
                                      PNY RAM is also good. However, some of their modules cost twice as much as similar RAM from another company.
                                      I consider Mushkin to be one of the cheap brands. They're one of the companies selling RAM that requires higher supply voltages.
