K8N no boot....
  • stevo1210
    • Oct 2006
    • 4156
    K8N no boot....
    I was given another computer today for free.
    Only problem is that it does not boot. The motherboard is an Asus K8N with an nvidia chipset. The original PSU was a Raidmax and had 2 bad caps in it.... in fact one cap blew its can off!.
    The cap that blew its can off is a 10V JEE cap which I can't see the capacitance. Another cap that went bad inside the PSU was a Rulycon 1000uf 6.3V IIRC.
    The CPU is an AMD Athlon 64 3400+ socket 754 and the RAM is two Super Talent 512MB sticks.
    Both optical drives wont work and are probably dead.
    So I replaced the Radimax P.O.S with an FSP FSP200-60ATV and I still get no boot from the PC. There are no beeps either.
    The light on the motherboard is green and not red.... which I think means the board is functioning? I once had an Asus board that died and emitted a red light instead.
    The motherboard on the other hand has a bad 1000uf 6.3V Ltec cap right next to the Northbridge/ Southbridge combo chipset.
    I have a feeling that could be the problem but I guess that the motherboard would have to emit some beeps or something....
    The Chipset does get pretty warm after about a minute.... not burning hot, but it is indeed hot enough that I have to take my fingers off it.... so I don't think that it is internally shorted like a few Intel ICH5 soutbridges running off bad DEER PSUs.
    Any ideas what could be wrong?
    Thanks.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: K8N no boot....
    I guess the first thing I would do is get all good brand caps on it. Then, if it's still not functioning, you can start playing taps.
    Bad PSU caps can wreak all sorts of havok.
    A man convinced against his will is of the same opinion still.
    • PedroDaGr8
      • Oct 2006
      • 130
      Re: K8N no boot....
      Thanks.
      Or bestec blow em up specials (Emachines I am looking at you)
      • Harvey
        • Apr 2007
        • 264
        Re: K8N no boot....
        Have you tested the RAM and CPU in another board?
        I don't like the sound of both optical drives being shot though, and if the PSU surged enough to zap 'em, I wouldn't hold out much hope of anything surviving.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: K8N no boot....
          that fsp200 likely doesnt have enough omph to run that board.
          something that old and low powered may not have enough on +12 or might not even have a p4 +12.
          get out a 350+ that you know is good.
          your opticals may not work if there is no pg or the board is in reset.
          unplug/pull anything not needed to post and try again.
          simple no post troubleshooting 101.
          • stevo1210
            • Oct 2006
            • 4156
            Re: K8N no boot....
            I tested the 1GB of Super talent brand DDR RAM in the system in another PC and they worked without any issues. I also tested the 128MB MX4000 AGP graphics card and that was also fine. I can't test the CPU because I don't have another socket 754 motherboard.
            The FSP200 series PSU has a 12V P4 plug.... but I have the same feeling that it may not be powerful enough.... but I also tried the board out of the box and only installed a CPU, board, graphics card, but the it still won't boot.... so I think I'll have to look for a more powerful PSU somewhere beause this is the only PSU I have available for now.
            Thanks.
            • Logistics
              • Apr 2007
              • 721
              Re: K8N no boot....
              Anyone else think this thread was about air filters just before they clicked?
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                Re: K8N no boot....
                @ stevo: nForce 3 chipsets are quite warm, sometimes hot, because they have both northbridge and southbridge in the same chip: I think they require a good airflow and it's quite strange Asus didn't put a fan on its heat sink.
                The green led should mean the board detects the power good signal, so at least the Asus hardware monitor should be working.
                The 200w Fortron can be a bit too low on 12v rails, so try a different psu.
                Basic troubleshooting:
                - do you cleared the cmos? Sometimes Asus board refuses to boot with a corrupted bios;
                - do fans spin, or the hard drive start when you swich on the board?
                - does the vrm function properly? (Amok's test)
                - are other caps looking good?
                @ Logistic: nope. I drive my byclycle, not sport cars
                Have an happy life.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: K8N no boot....
                  You're screwed if the BIOS is corrupted. If the BIOS is corrupted, expect BIOS access to be impossible!
                  If clearing the CMOS helps, then it's just a corrupted CMOS at the worst.
                  The symptom of a weak CMOS battery may be the following:
                  You're required to always clear the CMOS for it to boot or prevent Windows from giving you a nonsense message about the HDD or IDE controller firmware in the event log.
                  A weak CMOS battery may cause Windows 2000 and later to give you a nonsense message about your HDD firmware or IDE controller firmware being outdated in the event log!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • stevo1210
                    • Oct 2006
                    • 4156
                    Re: K8N no boot....
                    I havent cleared the BIOS yet.... so I will have to try that soon.
                    When the motherboard is booted up, all of the fans spin and the LED on the board is green. I haven't tested the VRM.... but I will look into that as well. Regarding the capacitors, there is only one bulging cap from what I can see.... the other caps look like they are still good. The caps on the CPU VRM output are 1500uf 6.3V Elite brand caps.... a brand that I haven't heard of before. The VRM input caps are Rubycon MBZ 1000uf 6.3V.
                    Every other cap on the board is Ltec 1000uf 6.3V and lower. Oh and i'll also look for a more powerful PSU than the 200w Fortron I currently have.
                    Thanks.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: K8N no boot....
                      Elite is bad.
                      I have an inverter full of bloated/vented ones.
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Re: K8N no boot....
                        I doubt the FSP has enough juice.
                        That CPU pulls like 90 watts all by itself.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Re: K8N no boot....
                          Might try with bare minimum.
                          No drives, one stick of RAM.
                          Might have just enough PSU to get into a BIOS screen that way.
                          - Dr Seuss
                          • stevo1210
                            • Oct 2006
                            • 4156
                            Re: K8N no boot....
                            I tried that as well, but it still won't boot.... so I'm going to find a higher wattage PSU that will pump out around 300W.
                            • zandrax
                              Hit and miss
                              • Dec 2007
                              • 1157
                              • Italy
                              Re: K8N no boot....
                              @ RJARRRPCGP: You're right, I meant a corrupted cmos of course - a corrupted bios is much more worse.
                              @ stevo: test the vrm before plugging another psu. It seems the board it's half functioning (fans do spin, so the hardware monitor didn't cut the current at boot and nothing important seems shorted), but I fear vrm's capacitors are almost dead.
                              Zandrax
                              Have an happy life.
                              • stevo1210
                                • Oct 2006
                                • 4156
                                Re: K8N no boot....
                                I have another question regarding the PSU.... the original PSU was a 500W Raidmax which in my opinion probably only pumps 200W at max strength?.... how did it manage to power the whole system in the first places? I'm surprised....
                                Also I had a close look at the Raidmax PSU and the input caps look pretty OK becuase they are 680uf caps.... though the are Jee brand.... it's the first time I've seen a China made PSU with input caps over 470uf....
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: K8N no boot....
                                  I usually see 330 or 470 but I've seen 680 and my 'otherwise piece of crap' Antecs have 1200's there.
                                  - Dr Seuss
                                  • stevo1210
                                    • Oct 2006
                                    • 4156
                                    Re: K8N no boot....
                                    I just had a thought.... I think I know why the optical drives won't start up.... I think it's because the FSP doesn't have enough power.... well looks like I've sorted out one problem.... well at least I think I have .
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: K8N no boot....
                                      Ah, yeah, that's why I said no drives in this post way back there.
                                      - Dr Seuss
                                      • stevo1210
                                        • Oct 2006
                                        • 4156
                                        Re: K8N no boot....
                                        I tried this configuration still without any luck....
                                        1x AMD64 3400+ CPU and HSF
                                        1x K8N motherboard
                                        1x 512MB DDR RAM
                                        1x nvidia MX4000 128MB
                                        1x FSP 200W PSU.
                                        I have a Dell/ Delta 250W PSU coming in at about 2 weeks. It has 17A on the 12V rail.... will that be enough yet? or will I need something more powerful like the Thermaltake XP480NP 430W PSU that's currently powering my gaming rig at home.
                                        • vallllliiii
                                          Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
                                          by vallllliiii
                                          Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
                                          08-18-2024, 09:21 AM
                                        • Bonaventure Vigil
                                          Variable DC Power Supply cannot boot motherboard
                                          by Bonaventure Vigil
                                          Hi there,
                                          Guys anyone here can help me. During troubleshoot the motherboard, my 1st and new psu unable to boot the motherboard. Even though i set the 20V, my old Compaq CQ42 motherboard had the led white light at charging port. When press on button, the led blinking to red and gone back to white state. But i change the oem hp compaq adapter which is i measure 19.45V. Using that can boot the motherboard and fan spinning. Then i reconnect psu and tried set the 19.45V, still blinking red. Anyone know what happen? Is it psu not compatible? All is check and voltage is there....
                                          10-17-2024, 12:16 AM
                                        • tech_guru
                                          Dell Alienware 17 R3 - LA-C912P Motherboard repair - 7 Beeps
                                          by tech_guru
                                          Hello.
                                          I am having a disappointing motherboard repair with this laptop and I need your help.
                                          This came in with water damage, doing absolutely nothing, and had almost all standby voltages shorted. I have already replaced all those shorted components:
                                          -UE5 SIO KB9022QD - Programmed spare one, when replaced, 3.3v short got out
                                          -PQ102 MDV1525URH
                                          -U17 AOZ1331
                                          -UE1 C8051F383-GQ
                                          -PU800 SY8032ABC
                                          -UI2 SY6288D20AAC
                                          -PU508 RT6220AHGQUF 7P=
                                          -PU100 TPS51225CRUKR
                                          -PU300 TPS51212DSCR
                                          Now, I get all the standby voltages, it turns...
                                          02-16-2024, 09:40 AM
                                        • FixItBill
                                          Acer Aspire Vero N20C5 Motherboard FH5AT LA-K092P No Boot
                                          by FixItBill
                                          Going over the pictures attached. I have an open circuit between ground and 19V at charger port. I have 5V and 3.3V at their respective inductors. The other three inductors near the CPU measure 1.8V except PLG1 which measures 0V. When the battery is plugged in I get around 9V on pins 7 and 8 at PJP201 but I believe it should be closer to 12~13V. I have the motherboard fully removed and disconnected from peripherals. Please let me know if you need additional information/next steps guidance. Thanks!
                                          Here's the link to the schematic: https://www.badcaps.net/forum/troubleshooting-har...
                                          Yesterday, 12:26 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
