For crying out loud MSI...
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Re: For crying out loud MSI...
    Wow definitely too much thermal paste! But I guess that as long as you apply enough pressure with the heat sink it should just slide off the cpu, but that's not really a good idea.
    Keyboard not detected, press F1 to continue...
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      reminds me of a new at the time athlon xp 3200 and mobo i got free.
      metallic based compound all over the cpu l bridges and all.inside the socket too.
      spent a while cleaning up the mess but it worked when i was done.ran it a few years myself.
        master hoarder
        • May 2008
        • 12170
        Originally posted by Compgeke
        Acetone might also eat the CPU socket and any surrounding plastics.
        Wouldn't recommend myself.
        Yes, if you drench the motherboard with it. I usually moisten a very small piece of paper towel and use that to clean the die only.
        As long as you don't try some of those so called "diamond" compounds. My friend bought some of that stuff one time. It is supposed to have diamond dust in it (ha, year right!) and thus have the best thermal conductivity of all thermal compounts. But it was so viscous and thick that it was impossible to apply a thin layer of it. Result: a thick layer of the "diamond" compound resulted in pretty much the same temperatures as before (and in some cases even worse). A big gimmick and waste of money if you ask me.
        • edgars_ab
          • Nov 2014
          • 22
          • Latvija
          Oh my gooooosh, this seemed a bit nasty. I think it would be more original to create a video about what to NOT use as an alternative for a thermal compound.
          I've seen it all - a foundation (makeup) cream, a hand cream, a toothpaste, even a super glue on the cpu. Why the hell they don't make videos about this?
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            That does look like a lot, but I wonder though... stock thermal pads that come on AMD coolers are also quite thick but they work well. Maybe this paste they used is one that needs more than others... wouldn't bet on it though!
            Reminds me of when I built my first computer and wondered why the CPU was always overheating...
            -David VanHorn
              master hoarder
              • May 2008
              • 12170
              #26
              I've only seen the toothpaste one, and initially, it appeared to work sort of okay. Of course, as the toothpaste dried up, its efficiency was greatly reduced.
              On that note, I think just about any liquid that doesn't dry up with heat or time could work (more or less). Many liquids have 5 to 10 times the thermal conductivity of air. Water alone has about 20 times the conductivity of air.
              On a CPU with a large cooper heat-spreader, this could work. But on a small CPU with exposed dies (such as laptops and older CPUs like Pentium 3 and socket 462 AMDs), it probably won't.
              I've noticed the same thing too.
              Moreover, you can remove the heatsink from the CPU and install it back on multiple times without re-applying thermal compound - and it still works just as good as it did before that!
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                #27
                It does seem pretty resilient to re-use. But anyone wishing to do so should be aware to twist and break the bond before pulling up or you rip the CPU from the socket!
                -David VanHorn
                  master hoarder
                  • May 2008
                  • 12170
                  #28
                  I ripped the CPU from the socket out like that *only* twice. Got lucky both times and didn't damage the CPU pins nor the socket (and the second time, the CPU actually fell on the desk - how it managed NOT to land on the pin side and bend nothing, I don't know ).
                  So for that reason, it's a standard procedure for me to twist-and-break (sometimes requiring multiple attempts) if I know the CPU has a heat-spreader.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    That's one thing I like about s775 and newer Intel CPUs. It's impossible for the CPU to come out with the heatsink.
                      • 30985
                      i ripped a p4 out on the heatsink once and had to split them with a screwdriver & a small hammer.
                      it's amazing just how much normal silicon grease can hold stuff together when it's totally dry.
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4951
                        • New Zealand
                        #31
                        I managed it once on my first Athlon 64 (socket 754) Lucky everything survived though. Was used to Socket A where that never happened...
                        -David VanHorn
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          I use a 3/4 inch artist flat brush to spread the compound on both surfaces and use isopropyl alcohol to clean the brush.
                            master hoarder
                            • May 2008
                            • 12170
                            #33
                            That wastes a lot of thermal compound IMO. I use everything down to the last little smidgen. At the rate I am going, though, that cheap 30g tube of thermal compound will never end .
                            • harp
                              Metod for removing glued heatsink from fragile component
                              by harp
                              I have peltir element glued to heatsink with something thick and sticky like putty... it cant be separate with force or heat without risk of breaking ceramic or damaged semiconductor layers due to force (eg if try twisted, pulled, lifted)... method that I am using is a single thread for needle (thin and firm thread of pure polyester that cant break with bare hands without glowes), and using it like a saw between heatsink and peltir. I holding a heatsink with knee against table. It slowly cut throug putty and release glued parts. It is slow proces, but preserve undamaged component and heatsink....
                              06-23-2025, 02:01 PM
                            • Ven
                              Seeking Advice on Enhancing Heatsink for Main Processor on SAMSUNG TV Motherboard
                              by Ven
                              I'm looking to upgrade the heatsink on the main processor of my TV's motherboard for better cooling performance.
                              The current heatsink is a square-shaped one (2.8cm x 2.8cn) with a basic design, and I believe a more efficient heatsink could help with thermal management and potentially extend the life of the TV.
                              I'd appreciate any advice on the best type of heatsink to use, specific product recommendations, and tips for installation.
                              If you've done a similar upgrade, I'd love to hear about your experience and any challenges you...
                              07-08-2024, 09:32 AM
                            • aidanmo
                              Philips 43PUS7506/12 - Loud blown out sound
                              by aidanmo
                              I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                              I thought maybe the speakers got damaged, so I replaced them - no dice.
                              • Using the internal speakers, it always happens.
                              • Using the headphone jack, it never happens.
                              • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                              02-28-2025, 03:13 PM
                            • harp
                              can fanless heatsink replace poor original on RX26PG2
                              by harp
                              I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
                              06-25-2025, 10:56 AM
                            • mon2
                              Crate guitar amp with extremely loud static on power on (no input)
                              by mon2
                              Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                              07-18-2025, 06:40 AM
